Question about John Deere Garden
John deere 2003 x485 gas gauge works erratically usually not at all
5 Suggested Answers
  • 143 Answers
SOURCE: Have a John Deere L108 will run but stalls out
This sounds like the grassbox switch.Get someone to press down on the box at the back and see if it works, if it will you will have to adjust the switch.
Posted on May 15, 2009
  • 10865 Answers
SOURCE: john deere 420 trouble starting getting gas and
The engine needs air, so be sure the air filter is clean. If it is not, replace it.
The engine needs spark. Replace the spark plug and be sure that the battery has a complete charge.
The engine needs good fuel so be sure the gas is newly purchased, not gas that has been sitting around for months.
Posted on May 19, 2009
SOURCE: gas tamk removal john deere 115
I had the same thing happen. I got the tank out, but it wasn't easy. Take out the bolts out that hold the rear end on. Take off the two springs that support the seat. Take out the battery and the battery tray. Take out the 6 bolts that hold the black cowling and the front of the green platform to the frame. This will allow you to lift the seat platform far enough off the rear end to allow the tank to be pulled out through the side. You also have to remove the metal bracket which holds the front of the tank and has caused the tank to leak in the first place. New tank is $56.00 not installed. I used a soldering gun and melted the plastic back together. I think it will hold quit a while. I know this is a little sketchy, but It worked for me.
Posted on Jun 02, 2009
nova2nv
  • 197 Answers
SOURCE: I have a John Deere 116 not getting gas to the filter or carb
Fuel line is pinched between fuel tank and frame.You should see the line coming down the rear side of tank,grab it and see if its free to move.
Posted on Nov 14, 2009
How do you adjust a john deere 160 FC420V carburetor. It just backfires out of the carburetor and don't start
Hmmmm. Backfiring is usually a function of bad timing. Or check to make sure that the float is working and that the engine is not being flooded with gas.
Sep 09, 2017 | John Deere Garden
Deere x500 AM134432 hr meter/gas gauge. Gas gauge ok, hour meter erratic won't go past 20 hrs & resets at lower number
Check the connector to the meter and make sure it is fully seated to the meter, if it is I would replace the meter.
Nov 05, 2016 | Cars & Trucks
I have a JD D110 riding mower and the gas gauge always shows full. It worked for awhile and then I filled the tank and it now always says full. How do I fix this?
If the wire from the sender to the gage is shorted out to ground the gage will always show full. Other possible is a defective sender or gage,even on a new machine
May 28, 2015 | John Deere Garden
John deere x485
Bad fuel or clog fuel filter or fuel lines are bad
Aug 12, 2014 | Garden
Temp gauge goes erratic on 2002 dodge durango 4.7
I had the same issue with a oil gauge it was the sending unit
May 31, 2014 | 1990 Dodge Dakota
Gas gauge on a john deere x-475 does not work
Must be a common defect because I have same problem with my X475. Reading the forums it happens to the X 575 as well. It would be nice if JD addressed the defects in a forum
Jul 19, 2012 | Garden
Fuel gauge inop on a 2000 john deere 5310 tractor
Either the fuel gauge has given up the ghost or the sending unit is not properly grounded, in which case the fuel gauge would not work. Hope this Helps, Don
Oct 20, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Gas gauge always reads full
The unit that sends level info to the gauge is defective; this normally doesn't happen instantly but will show up usually as an erratic movement of your indicator.
The sender unit is a variable wire-wound resistor with a wiper attached to the float and the wire element does wear through sooner or later.
It is probably necessary to remove the gas tank from the vehicle to replace it unless the engineers were smarter than usual and provided an access hatch from inside the vehicle.
The senders are not expensive but depending on how twisted the removal and reinstallation of the tank is, the labor will be the larger cost item.
May 24, 2009 | 2003 Chevrolet Venture Passanger
Garden Logo
653 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
