Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washer showing error code f33 and leaking water from the front
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. F33 is a pump drive system error which occurs when the connection between the pump and the Central Control Unit (CCU) are lost. To resolve this issue you’ll have to unplug the washer and then check the wire harness to the pump and CCU. If that seems to be fine and all the other functions are also working fine then the pump should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 28, 2010
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
What does f23 error mean?
Display shows an error code - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...error-code...w...
Whirlpool Home AppliancesCheck the following answers for error-code related issues you can correct: ... Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33.
What does error code f23 flashing mean on a Whirlpool ...
Nov 30, 2015 | Washing Machines
The waher quits working and F33 shows up on the front
F33 error code indicates a pump drive system error.
If the pump ohms out correctly and the harness is secure and working fine, I recommend replacing the CCU (central control unit).
Good luck.
May 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washer is flashing f33 what do i do
F33 Leak. If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed. Check your inlet valves for block, where the water comes to machine OR
If the control has turned the water valves on, and after 8 minutes, the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off, and the error code will flash.
Press 'pause' and 'cancel' twice to clear the display. Mains off the wall.
1. Check for crack or holes in the washer tub and pressure switch hose, which runs from the
bottom to the pressure switch.
2. Replace components if necessary.
Sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
Dec 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The washer is working now but every once in awhile, during the cycle, it stops and f33 shows up. Could it just be the wiring? The washer is a whirlpool duet.
The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit).
Please see the following image provided for instructions.
http://media.fotki.com/1_p,stwwfrggtqfbrbbxgtqsskgwtqkq,vi/wgtbwqwssxsbwkbdtfwxrbfbddwwf/1/1303472/5961857/image9159087223444281043img-or.jpg
Remember to disconnect power to the washer before attempting access.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question####
Sep 23, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Washer codes F01/F33, have cleaned the pump and
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Jun 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have an f33 error code on the whirlpool duet front loader please help me to fix this.
F33 = PUMP DRIVE SYSTEM ERROR
When the connection between pump and the Central Control Unit (CCU) is lost.
1. Unplug washer or disconnect power.
2. Check wire harness connections to the pump and Central Control Unit (CCU).
3. Faulty CCU < call for service >
Nov 10, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
F33 displayed in whirlpool duetsport frontloading washer
Press ‘pause’ and ‘cancel’ twice to clear the display. Mains off the wall.
Sites for spares:
RepairClinic.com (which is good)
espares.co.uk
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport. I am getting a f33 error code.
i would look for a small blak rubber tube running frim the pressureswitch tothe back ofthe tub, its possible that the tubing if either clogged or ripped, and is not able to detect current water level inthe machin causingthe F33. 3 screws from across theback will release the main top, from thereyou an locate the hose back right corner i believe
F33 error code
F33 System leak If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed.
OR
Press PAUSE/CANCEL twice to clear the display.
Possible Causes / Procedure
1. Check for crack or holes in the washer tub and pressure switch hose.
Jun 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
176 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
