Question about Karcher 2500 PSI Pressure Washer
Pressure fails to engage
When I turn the washer on, it engages properly, but once I let go of the trigger, it will not re-engage. Water continues to come out, but with no pressure.
  • 33 Answers
Is this an a/c washer? if so sounds like press. sensor is screwing up.
Posted on Apr 21, 2009
No pressure once trigger is squeezed
We will have to just guess what this trigger is on :>)
AR Blue Clean - Spray Gun Trigger Squeezed, No Water Pressure
When the spray gun trigger is squeezed, water comes out but there is no pressure. ... The RED color must stay in the window once the button is released.
pressure washer won't start unless trigger is depressed - Shop Your Way Jan 11, 2012 - pressure washer won't start unless trigger is depressed ... Thank you for your question on the pressure not starting unless you have the trigger pulled. ... After about 4 or 5 pulls the pump has built up enough pressure to make it ...
Pressure Washer Troubleshooting In-depth Beginner's Guide Jul 5, 2017 - After holding the trigger to keep the water running through the machine ... (but not water supply) and release pressure by squeezing trigger gun.
Nov 21, 2017 | Garden
Pressure washer has no pressure at all
check for blocked jet at the end of the wand
this is the same as letting the trigger go and the pressure relief regulator is not engaging the pump to produce pressure
water just circulates around the pump
Jun 30, 2015 | Briggs & Stratton Garden
Why does the motor run when I do not pull the trigger of the gun after the high pressure washer is turned on? The motor is supposed to run only if the trigger of the gun is pulled and shuts off when the...
When water is running through system, the motor has to run to keep the pressure built up. So, if the water is leaking out, the motor think it needs to keep running to keep the pressure built up. The leak needs to be fixed to the motor will not run constantly.
Jun 16, 2014 | Karcher PSI Electric Pressure Washer
Poppet valve missing in gun
Not sure I understand. What is your model #.
pressure is created by forcing the water through the tiny hole in the spray nozzle. The gun is a simple open and close valve.
May 14, 2014 | Garden
The trigger on the wand of my Karcher model K 368 M will not re-engage for several minutes after the trigger is released. If I repeatedly squeeze the trigger for a few minutes, eventually the switch will...
it sounds like a flow switch that is installed in the inlet of pump can get stuck at times if you have a soap nozzle select it usually more flow moves the flow switch try and clean the flow switch if possible.
Aug 10, 2013 | Karcher K3.68MR Electric Pressure Washer
Engine will not start when the water is on. You can start the engine and then turn the water on but it will kill the engine. I have tried to clean the unloader valve.
To isolate whether or not the unloader valve is still stuck or sticking, try starting the unit with the wan trigger engaged water coming out to spray. If the unit runs while wan trigger is engaged and shut down when released your unloader valve isn't working. Hope this helps God Bless
Sep 18, 2009 | Garden
Troybilt pressure washer won't run
If you ran the pressure washer without water running through it on startup you probably got your pump.You are supposed to engage the trigger on start up with water running through it so as to release the pressure off the pump so it will start easier. Hope this might help you.
Sep 15, 2009 | Briggs & Stratton Prosumer 20324 Gas...
Unable to start check oil is full and gas tank is full
check spark & spark plug.if you have water on trigger must be engaged as you are turning pump also creating pressure this stops engine turning fast enough even if you pull rope hard as you like engine does not operate run cycle properly.
Apr 19, 2009 | Garden
Pressure washer stalls out when wand nozzle is released
common for not starting unless trigger engaged as you are turning the pump as well as engine creating pressure,as for stalling pump has unloader valve which is probably in need of grease(use good silicone grease)this allows water to ciculate when trigger released.
Apr 19, 2009 | Campbell Hausfeld Garden
When trigger is engaged under pressure nothing happens.
Make sure all of the water is bleed out of it buy holding trigger down with motor not running until theres is not more bubbles or air that comes out..Make sure where the inlet for waters screen is not plugged..You may have to back flush washer to clean out or to unstick the pressure valve..Hope this helps you and have a great day
Apr 06, 2009 | Garden
Karcher 2500 PSI Pressure Washer Logo
119 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
