Question about Microwave Ovens
Bush AE6BFS Stainless Steel Built-in Electric Fan Oven
MicrowaveSvc
  • 9047 Answers
SOURCE: how to change the bulb
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Aug 12, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Stainless Steel oven door dent fix
The best repair is to take apart the door panels, bang the dent pout from the other side, then sand and polish it smooth.
Otherwise, there may be some dent filler you can use, then sand and smooth it.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Posted on Aug 24, 2008
  • 1214 Answers
SOURCE: GE Monogram ZMC1095 Built-in Microwave.
You can find the exploded view on the searspartsdirect.com website. You need to enter the complete part number, or ZMC1095BB001, and confirm colors befor eordering parts.
Posted on Feb 03, 2009
  • 400 Answers
SOURCE: how do u install a kenmore microwave oven over the
Installation instructions should have come with it. If not, do a Google search online to find the installation manual. Generally there is a plate that installs on the wall and the microwave hooks into it and fastens to the cabinet above. Try this website for a manual. http://www.pdfoo.com/result-kenmore-microwave-installation.html
Posted on Oct 30, 2009
jyackle5
  • 8197 Answers
SOURCE: VEDO5271SS Viking 27" Professional Ultra-Premium
You can get the manual on the link below.
http://www.ajmadison.com/ajmadison/itemdocs/m720042_f20362.pdf
Cleaning tips on this link below.
http://www.ajmadison.com/ajmadison/itemdocs/m90036_cleaning_tips.pdf
Good luck please rate 4 thumbs up and please leave a testimonial
Posted on Oct 14, 2010
Testimonial: "Response was in seconds. Wow! Thank you."
My electric lower oven doesn't get any heat.
Could be a lot of things, door lock switches, bad element, a fuse, the thermostat a broken wire or cold solder joint. etc
Good luck
Feb 20, 2014 | GE Profile 30 " Stainless Steel Built-In...
I bought a KitchenAid 24" microwave oven and trim kit.to replace an old KitchenAid 24" oven. The old oven set on the built-in shelf with a stainless steel trim panel around the oven to trim the cut-out. ...
As long as there is ventilation at the back and somewhere for the air to come out go ahead and use you imagination to make the trim kit look good to the eye. Making those tough decisions is what installers do.
Oct 17, 2013 | KitchenAid Microwave Ovens
Hot microwave door handle
I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
Jan 08, 2013 | Whirlpool Microwave Ovens
My whirlpool gold gt4175sps lights up and the control panel works but the turntable does not spin and it does not cook. No fan or cooking noise
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 16, 2011 | Whirlpool GT4175SPS Stainless Steel 1200...
I seasoned my new stainless steel skillet in the oven now I have built up oil stuck to the sides inside the skillet. How can I remove this without damaging the stainless steel finish? HELP!
You only need to season a cast iron skillet, not stainless steel. Soak it in hot soapy water and use something like a mister clean pad to clean it.
Dec 07, 2010 | Microwave Ovens
GE PEB1590 microwave oven. Interior light burned
Remove the screws from around the rear of the oven and slide the cabnet off to the rear. You should be able to access the bulb from here.
WARNING: any time you work on a microwave you have to be careful of the capacitor. Unpluge the microwave and discharge the capacitor with a large screwdriver with a plastic handle.
Be careful.
Dec 31, 2009 | General Electric PEB1590SMSS Stainless...
How do you install a built in whirlpool microwave oven
Whirlpool customer service is here and you can also enter your model number on that page to download your owner's manual, installation instructions, etc.
Nov 23, 2009 | Whirlpool GT4175SPS Stainless Steel 1200...
Amama 2.0 Cu ft. Radarange Microwave model# UXA3036BAB
This model does not list Stainless Steel as a feature. Stainless Steel is used in the interior (CAVITY) of a Microwave if it is a Combination Convection/Microwave Oven. The Convection Oven can reach temperatures of 400+ degreesF. This Temperature would MELT the paint off a painted interior.
Stainless Steel can be tested with a Magnet. It will not be attracted or "Stick" to Stainless.
Hope this answers your concerns!
Thanks!
Feb 05, 2008 | Amana ACM2160A Microwave Oven
Microwave Ovens Logo
132 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
