Question about StarTech.com StarView SV211K 2-port KVM Switch
Firmware for starview5 b0x usb11 - StarTech.com StarView SV211K 2-port KVM Switch
    Scholar:
  • 100 Answers
<P>There doesn't appear to be any drivers available, per the manufacturer's website:</P><P><A rel='nofollow' href="http://www.startech.com/item-download/SV211K-2-Port-PS2-StarView-KVM-Switch-Kit-with-Cables.aspx">http://www.startech.com/item-download/SV211K-2-Port-PS2-StarView-KVM-Switch-Kit-with-Cables.aspx</A></P><P>&nbsp;</P><P>There is also a link for the documentation, if required.</P><P>&nbsp;</P><P>If I've helped with your request please give me the appropriate 'thumbs up'.&nbsp; Thanks and good luck!</P><P>&nbsp;</P><P>&nbsp;</P>
Posted on Aug 27, 2010
Tip
3COM 3CRWDR200A-75 Firmware Download - All Versions
Hello
If you want earlier firmware versions of 3Com 3CRWDR200A-75 then check this website:-
http://3crwdr.googlepages.com/
da4eeaf.jpg Firmware Router 3Com 3CRWDR200A-75 V.3.0.1
Firmware Router 3Com 3CRWDR200A-75 V.3.1 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.9b Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.9 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.8b7 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.8b6 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.8b4 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.8b Beta
_____
Regards
on Jun 29, 2008 | 3Com OfficeConnect Wireless Router
Stuck on please wait
Check your current firmware version before beginning:
  1. Turn on the camera.
  2. Tap the menu tab at the bottom of the monitor to display the setting controls and tap Setup (wrench icon)
  3. Tap Firmware Version in the Setup menu(wrench icon)
  4. The cameras firmware verison will be displayed.
  5. Turn off the camera.
Basic Download and Installation instructions: (New firmware versions contain all previous versions.)
Windows
  1. Create a new folder with an appropriate name on your computer's hard disk.
  2. Download F-S4300-V12W.exe to the folder created in step 1.
  3. Run F-S4300-V12W.exe to create the folder titled S4300Update, containing the following:
    • firmware: folder containing the firmware.bin file
    • firmware.bin : the firmware located inside the firmware folder.
  4. Insert the memory card containing the firmware folder into the camera and turn on the camera.
  5. Tap Firmware version in the Setup menu and follow the instructions displayed to upgrade the camera's firmware.
  6. After the upgrade is complete, turn the camera off and remove the memory card.
  7. Check the Firmware version item in the setup menu to confirm that the camera's firmware has been upgraded.
For detailed instructions, please see the PDF files below.
Macintosh
  1. Download F-S4300-V12M.dmg.
  2. Double-click the F-S4300-V12M.dmg icon to mount the disk image titled, F-S4300-V12M.
  3. A folder titled S4300Update, containing the following files, will be created inside the disk image:
    • firmware: folder containing the the firmware
    • firmware .bin: the firmware
COOLPIX S4300 1 2 firmware update Nikon Knowledgebase
Mar 28, 2014 | Nikon COOLPIX S4300
I need telephone number of Marvin D. Edwards, Environmental Services, 310 Morton Street. B0x 596, Richmond ,Texas 77469
You can try Google maps. You might also be able to see if you can find the sprinkler company in the yellow pages. If you are renting, your landlord should also have the number.
Elisa Jed ' http://www.dwestenterprises.com/irrigation.html
Mar 27, 2014 | Orbit Sprinkler System Power Source...
I got the error performing inpage operation on my hp external hard drive. I am running a chkdsk on it and it is now on stage 4 of 5 but just blinks at 0 percent. The external hard drive is blinking like...
if its a large 2 terra byte hard drive it will take quite a long time while the chkdsk utility perfoms the check
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
hope this helps
Jul 26, 2012 | Western Digital Retail Hp Simplesave 2 Tb...
Sv5
the ppv channel only comes in when there is a fight or wrestling on ppv otherwise you wont get it it remains blank/scrambled
Apr 26, 2010 | StarTech.com StarView SV211K 2-port KVM...
How to fix and/or find the fuse for my 1998 Mercury Mystique to reconnect the inside dome lamp and radio? I shorted it by accident with a wire.
I CANT REMEMBER THE # BUT THE FUSE YOU NEED IS INSIDE A FUSE BOX ABOVE BRAKE PEDAL TO THE LEFT. THERE IS A BUTTON YOU WILL PUSH AND B0X DROPS DOWN. ON BOTTOM ROW I THINK DOM LIGHTS ARE BETWEEN 3 AND 6 FUSES FROM END , LOOKING FROM LEFT TO RIGHT. GOOD LUCK!
Feb 16, 2010 | 1998 Mercury Mystique
Cant understand how to get firmware to flash starview 4 box please help
You will need a null modem cable DB9F to DB9F.
Null Modem Cable
http://www.maplin.co.uk/Search.aspx?criteria=L71BT&DOY=2m6
If your pc does not have a serial port you will need a USB to serial port adapter to use in conjunction with the null modem cable.
USB Adapter
http://www.maplin.co.uk/Module.aspx?Modu...erial%20Adaptor
These two cable links are only for reference as they can be purchased alot cheaper on fleabay.
You will need to know if you have a clone or genuine
Count the vents on top
18x7 = Clone
25x7 = Genuine
13x7 = 1st Generation
Also looking from the front
Scart to the left = Clone
Scart to the right = Genuine
Also you can go here to see some pics
http://www.freewebs.com/dooby2oon
ST@RVIEW 1
You will need the GTromloader, (Starvi*w software Uploader), found in the Starvi*w software folder of the link.
You will need version CryptStar-v1.5-Core400only firmw@re for GENUINES found in "Starvi*w" firmw@re folder here.
You will need version CryptStar-v1.5-Core257 firmw@re for CLONES found in "Starvi*w" firmw@re folder here.
ST@RVIEW 2 - THE B0X
You will need the GTromloader , v4.03_051005, (Starvi*w Software Uploader), found in "THE B0X" software folder of the link.
You will need version thebox_h20081204_455eE_apifound in "THE B0X" firmw@re folder here.
ST@RVIEW 3 - THE B0X SUP3R
You will need version GTRom_Super_8.02e for THE SUPR B0X found in "THE B0X SUPR" firmw@re folder. (UFL = Unified Firmware Loader) here .
St@rview 4 - TheboxSuperUSB You will need version V1.07 for TheboxSuperUSB found in "THE B0X SUPR USB" firmw@re folder here.
Instructions SV4 Supr USB
To load the files just drag them on to a memory stick and then put the memory stick in the USB port at the back of the receiver.
Then press the menu button on the remote there you will see USB at the bottom of the screen.
Just highlight USB with the remote then you will see the (Box Super USB Bin file) appear on the screen.
Highlight "theboxsuperusb_v1.01_beta" with the remote and press the ok button then you will see the file start loading in to the Box.
Once that is complete, do that again but with the "TheBoxSuperUSB_BG_LOGO_080904" file.
Once that is done,
• Turn on the box, press menu and go to installation,
• Select correct provider i.e. NTL, C/W or TW
• Then automatic scan
• Once the channels are found, exit back to the blank screen
• Press menu then 1570,
• Go down to the bottom option and turn EMU to ON.
• Now exit 3 times and go to S*y Sports and let it update.
All firmw@re/loader can be found in the link at the end of my post marked EAMO'S LIBRARY.
Updating Firmw@re SV 1/2/3
Connect your box and PC with a Null modem cable and switch on the cable box and put it on STANDBY.
(The Starvi*w does not need to be connected to TV to update it with GTROM)
Open GTROM Loader software make sure that you set the correct COM PORT that matches the one that is being used
Make sure App file only is selected, then click b1n File & browse to the firmw@re where you downloaded it to on your PC.
Run the GTROM loader by pressing Download and you will see the % progress increase then Download completed message on your PC.
Wait until you see the DOWNLOAD COMPLETE p0p up on your PC before removing the NULL MODEM CABLE.
The Starvi*w will then reboot
Disconnect from PC and connect back up to the TV :)
Aug 27, 2009 | StarTech.com StarView SV211K 2-port KVM...
Anybody out there with new ntl codes for Dublin area 28/6/09
Not 100% certain that this'll work even if yrs is a starview5 box but just in case it is but this is what I did & hopefully it'll work for you too - good luck :- Even if not Starview3 it might give U a few tips ;o)
Subject: Star View 3 The Box Super when channels discappear ;o) 1. Press menu then Factory Setting & Enter code 0000 to reset. 2. Exit to main menu & enter 1570 to get into the CASS SYSTEM & turn EMU on 3. Reinstall channels (Goto Installation, Cable network (try TW first & if no channels try NTL then C & W and so on - I'm with Virgin & used the setings for TW) & Voila ;o) Nb: You may have to redownload channels so reconnect yr box to the computer & follow the link below http://www.4shared.com/file/76886028/fd4ac296/GTRom_the_box_Super_8102e_081129.html?err=no-sess & press download !!!
Jun 28, 2009 | StarTech.com StarView SV211K 2-port KVM...
How do u even put music on it
  1. plug it into the computer
  2. go to the windows media player that is on your computer
  3. go to sync.
  4. there will be a bar on the right that will have the name of your devise
  5. drag the music from your library to the bar that was spoken of in step 4
  6. once you have the music you want, click on the "start sync" button
  7. allow it to syncronize, and there you have it!
Jun 14, 2009 | Visual Land V-Touch Digital Media Player
StarTech.com StarView SV211K 2-port KVM Switch Logo
46 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
