Question about Dell Dimension 3000 PC Desktop
Installed Dell Dimension audio and video drivers in worng order. Now, no sound amonng other things. How can I unistall and reinstall the drivers and start over. The chipset and network drivers were in the proper order and seem to be working. Can I simply install the audio and video drivers again and in their proper order?
    Scholar:
  • 137 Answers
Try re-installing them in the correct order over the top first and see if that sorts it.
Normally though, it shouldn't matter in which order you install the sound and video drivers, they should still work.
if you are using windows xp you can go into control panel, system properties, device manager and delete the incorrect drivers from there.
Posted on Aug 27, 2010
Testimonial: " I found you were right-I simply had to reinstall the audio drivers over top of the originally reinstalled ones. Many than"
    President:
  • 2,571 Answers
It should not matter what order you put them in.
Try device manager, is there any yellow exclamation mark against your sound ?
Try uninstall your audio device and reboot.
If this still does not help, write back and we can try something else
Testimonial: "I found you were right-I simply had to reinstall the audio drivers over top of the original ones. Many thanks"
No audio after reinstall. Uininstalled and reinstalled chipset and drivers (in that order), went to services and disabled and reinabled audio,uninstalled and reinstalled modem, did all this in safe mode...
Have you actually gone into your sound and audio devices in the control panel and made sure that all the sound devices are correct and the volumes are up.
Also, back in the devices menu, you could try the option "Roll Back Driver"
Jul 03, 2010 | Dell Dimension 4700 PC Desktop
Dimension 9100 PC Desktop: no sound dell dimension 9100...
Make sure physical cables are plugged in correctly from speaker to audio ports. Check audio driver if installed, if not you can download the driver from the dell website:support.dell.com.If driver is propely installed check sound/volume settings, make sure nothing is set to mute...Hope this helps...Cheers!!!
May 17, 2010 | Dell Dimension 9100 PC Desktop
Dimension 8250 PC Desktop: Dell Inspiron 8250. I've re-installed Windows, bu...
Once Windows is reinstalled on dell computers you have to use resource cd that came with it and reinstall network and sometimes couple other drivers like video or sound. If you dont have the resource cd you will have to get some how to dell.com maybe from your friends pc or if you have another one and just download it from there. Go to dell.com,click on support then on drivers and software and choose your system and you will find all drivers right there. Hope this helps.
May 07, 2010 | Dell Dimension 8250 PC Desktop
I have a dell dimension 8250. I lost my sound, but
Either your soundcard driver has gotten corrupted or your soundcard has died. You can find both the driver & info on what card you have at www.dell.com. Click on the support link and you can either input your Dell Service Tag & get exact system info, or you can look it up using the system model #. The driver will be available for download. Try reinstalling an updated driver first. If that still doesn't work check your device manager to see if a soundcard is listed. If it is not then more than likely your card has died and will need to be replaced. Hope this helps.
Jul 11, 2009 | Dell Dimension 8250 PC Desktop
Laptop dell inspiron 1525 sound only when headphones connected
If you can here sound in headphones, but not through the speakers, most likely the phone jack switch is bad. The whole jack needs replacement.
Also, in some cases, it could be more then that, like Audio CODEC chip on motherboard is bad, but lets assume the best.
Apr 19, 2009 | Dell Inspiron 1525 Notebook
Dell e310 desktop, xp, unistalled unrelated program-no audio
Try to re-install your sound driver.
Download updated version of driver from following link.
Dell Dimension E310
Thanks
Mar 26, 2009 | Dell Dimension E310 PC Desktop
Windows Xp
In addition to installing the operating system (Windows XP) you will need to install the drivers for the system.  If you system is a Dell Dimension 1100 you can get the drivers from this link:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_CEL_1100&os=WW1&osl=en&catid=&impid=
Driver installation order is:
Desktop system software (R121089.exe) Intel Chipset Utility (R96614.exe) Intel Video Driver (R104515.exe) Audio Driver (R105155.exe) Network Driver (R105786.exe) Modem Driver (R133743.exe or R73044.exe)
Once you have all the drivers installed, then you can install your applications and configure your internet connection.
Sep 07, 2008 | Dell Dimension 1100 PC Desktop
Dell Dimension E510 Desktop
Also try to go to support.dell.com,click on drivers and downloads and enter the service tag of your system, then click on the audio driver.
Aug 23, 2008 | Dell Dimension E510 Dual Core 2.8 Ghz...
No videon
it sounds like an issue of driver installation order. If not installed in the correct order, the drivers may not function correctly. The correct order is:
Desktop System Software
Chipset Utility
Video Driver
Audio Driver
Modem Driver
Network Driver
My suggestion is to do a system restore to the 1st available restore point (The one created at boot after you reinstalled) then install the drivers in the correct order. (NOTE: Before you can play a DVD, you will have to install the DVD player too)
Jul 26, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Sound windows xp dimension 3000
hi if your motherboard have you install sound properly....Or not your sound driver you Go to driver Zone.com then download it
Jun 06, 2008 | Dell Dimension 3000 PC Desktop
Dell Dimension 3000 PC Desktop Logo
Alun Cox
