Question about Mitsubishi WD-52525 52" Rear Projection HDTV
I turn on the tv and a few seconds it will turn off. It will not stay on for more than 5 minutes.
    Sergeant:
  • 252 Answers
Your horizontal output chip is going bad. It works fine untill it overheats and fails. Please have tech replace this for you.
Posted on Aug 27, 2010
TV will not stay on. It will turn on and after a
Problem with your TV's picture tube,Replaci it
Feb 15, 2011 | Philips 32PT5441/37 32" TV
My TV has been having a shacky picture when it first turns on for a few minutes, then clears up. the other day after using the TV for most of the day, it shut off unexpectidly, and now it will turn on and...
1. YOUR flyback is going bad 2. Peform a removal and replacement 3. check your error codes first to ensue nothing else exists 4. Proceed to change out the required parts 5. Observe all electrical risks 6. Order replacements from jimmyparts.com 7. Ensure to always remove power 8. Ensure to always use electrostatic wrist strap
Jan 31, 2011 | Panasonic PT-47WX49 47" Rear Projection...
My magnavox 42mf438b lcd tv will be fine for about 10 minutes when i turn it on, then the screen goes completely black but it still has sound. it stays like this even if i turn it off and back on. i can...
that set is highly rated by users .. it first came out in early 2009 (i think) so you might check to see if any warranty remains ... the display is illuminated by several lamps .. each lamp has its own high voltage inverter .. all the innverters are powered by an output of the low voltage power supply (often 18 volts)... i would suspect a problem with that low voltage power supply.. either a bad capacitor or a thermal issue .. .. ..
Apr 10, 2010 | SNK Magnavox 42MF438B/27 42 in. LCD TV
PIP will not go off.
Try unpluging the unit 5 min then pres and hold power button 10 seconds (this should reset ir!
Dec 13, 2008 | Sony FD Trinitron WEGA KV-32FS16 32" TV
RCA L32WD12 32in. HGTV LCD Television
I had the same problem happen this afternoon, so I took it apart, and the source of the problem is the key controller panel (behind the buttons). It's held in place by 2 screws, if you take the case apart, which is literally only 15 or 20 screws, and then loosen the 2 screws holding the key controller panel on, and then use a small screwdriver to space it out from the button caps. Tighten the screws, and put it back together. Just be careful not to let it go too far to the other side, or you'll have a problem with the menu going on and off at random, which is just as annoying.
Nov 07, 2007 | RCA L32WD12 32 in. LCD HDTV
DTD1363-CAR
Mine does this as well, I would really like to know a fix or if anyone has had any luck with getting theres replaced
Sep 08, 2007 | Disney DTD1363-CAR 13" TV/DVD
T.V WILL NOT STAY ON: JVC AV-27F702 27" TV
This sounds like a protection system cutting in. This happens if there is a major fault and continual use would lead to a fire risk.
Aug 09, 2007 | JVC AV-27F702 27" TV
Screen tuns black after 15 seconds and comes back after about 15 minuts
The solder joints on the vertical output IC have cracked. This is a very common problem on those sets.
Nov 14, 2006 | Panasonic CT-27G34 27" TV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
