Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Thanks for help
I got this: STK392-120 Hitachi replaces these with STK394-160, for other sets it may not be a good sub. They have been fine in the Philips sets so far. from this site: http://www.hometheatershack.com/forums/manufacturers-service-support/5600-crt-based-rptv-convergence-repairs.html#post43725 Do you think I may be alright by replacing the STK394-160 with what 120's? Or have I now fried the circuit and need professional help? My family is not happy, but I already got $50 in this project and would like to get it fixed. Thanks again!
  • roddy66 May 09, 2008
    It's fixed! I replaced the stk394-160's I installed with new stk392-120's.(same as I removed) I also replaced all the 6.8ohm resistors (12) as a precaution. Works like a champ. Thanks alot!!!
  • 121 Answers
The only thing you could have fried is your resistors in the convergence circuits that feed the convergence yolks you can safely go up to STK392-160's but you may need to replace those resistors I spoke about if you need anymore help e-mail me
Posted on May 08, 2008
Hello guys I have Hitachi tv, model 61sw10b, ser v1i003086. I turn it on and power cut off instantly, don't know what part I need to replace. Please help. Thanks.
I would check your PSON voltage and see if it is correct, if it isn't then chances are its the main if its good then the power board.
Nov 12, 2017 | Hitachi Televison & Video
HELP
have you adjusted your settings on amp.is sub actually good .
Nov 14, 2009 | Car Audio & Video
I have a problem with my hitachi. The picture has vertical blue/yellow stripes. Probably due to a green color split. Can you diagnose my problem?
You probably have a convergence circuit failure. Replacing the Convergence IC's and check for any open resistors for the Blue Sub Yoke located near the Sub Yoke Connector should cure the problem. Most of the IC's are
STK-392-110's, STK-392-120's, or STK-392-150's. Replace them as a set.
Hope this helps,
Skyassoc
Jun 25, 2009 | Hitachi 50FX18B/19K 50" Rear Projection...
Infinity Basslink
That popping you hear is most likely the voice coil blown and your not going to get much out of it now. Discontinue use of the unit so it doesn't blow the amp, and you can get the sub replaced if you don't want to toss it.
Good luck, hope this helps
Aug 02, 2008 | Infinity BASSLINK Car Subwoofer
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 06, 2008 | Sub-Zero 650 / O Bottom Freezer...
Hello
hello. the first thing you want to do .!!! is unplug the set.!!! then take off the back of the set and look for a fuse.!!! it should be around where the power cord come's out of the set. and see if the fuse is good . let me know if it's good or bad .!!! ok . " hope this help's you. "GOOD LUCK"
Jun 25, 2008 | Hitachi 50UX58B 50" Rear Projection...
Green convergance goes out when tv warms up tosh projection tv
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
STK392-110 replace with STK394-160
STK392-150 replace with STK394-160
***The 394 series replaced the 392 series and is cooler running. The subs listed here are the ones that I know to work in most sets.
· http://www.mouser.com/index.cfm?handler=home
· http://www.mcmelectronics.com
· http://www.bdent.com
· http://www.electronix.com
Feb 20, 2008 | Toshiba 42H81 42" Rear Projection...
Distorted red color
Feb 20, 2008 | Televison & Video
No picture, have sound
Dude, you dont have the same problem thanks for junking up my post.
Ok, so I have replaced the SUB power assembly and the SUB Defconvergence board, picture looks decent however magic focus just blanks the screen out and cannot adjust manually does the same thing.
Is there a way to enter the service menu and initialize the magic focus functions after servicing.
It must be using the saved ROM settings, but it wont let me adjust anything convergence wise.
Thanks,
Joe
Dec 28, 2007 | Hitachi 46F500 46" Rear Projection...
Purplish-reddish flicker on Hitachi
It seems you might have cold solder connections on the picture tube socket or on the picture tube drive board. If your not a tech please call someone to assist you with repair as you can be seriously hurt by the HI voltage insiode this set an or cauae more problems with the set. Good Luck
Aug 03, 2006 | Hitachi 43FDX01B TV
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
43 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
