Question about Bosch SHU9915UC Dishwasher
No water going into never used bosch shu9915 dishwasher
  • Bosch Master
  • 43,501 Answers
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Posted on Aug 29, 2010
Hi my bosch washing machine is leaking water from underneath, in fact when you turn the water tap on, it sounds like it is filling up, but the machine is not even plugged in.
Welcome to FixYa.
Based on your description, " machine is leaking water from underneath... it sounds like it is filling up, but the machine is not even plugged in "... the issue is likely with the inlet/water valve.
**To remedy this you will need to replace the valve, not surprising for Bosch unfortunately**
This is what to look for..i.e.
As long as your model number is indeed SHU9915 series, this info below will be accurate.
I say not surprising because this part has been an issue for the B/S/H/ built machines in the past and as a result the original part number 189553 now substitutes to 425458. It usually retails for about $20 - $30USD at places such as "searspartsdirect.com" "repairclinic.com" to name a couple.
**Before attempting to repair the unit please turn off the power and the water supply to the dishwasher...safety first**
If you remove the lower kick plate/toe panel, you will see the inlet valve to your left...
i.e.
Replacing it is pretty straight forward. Here`s how...
1) undo the water line.
2) the two #20 torx screws fastening it in place.
3) the feed tube to the machine at the back of the valve and swap it with the new one.
and
Once the new one is in you should be good to go.
Let me know if you need any further assistance, otherwise good luck.
Thanks for visiting FixYa.
Regards,
Macmarkus :)
Nov 08, 2010 | Bosch SHU9915UC Dishwasher
No water is getting inside my Bosch dishwasher compartment. Water supply to dishwasher is ok. Checked hose at input of dish washer and water supply is ok. Could pump have packed in? Model 004 920 378....
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 08, 2010 | Bosch Dishwashers
I have a Bosch dishwasher model SHU66. Clean water slowly pools in the base when the dishwasher is not in use. We need to drain the DW every 12 hours or water will overflow onto the floor. Is this an isue...
IT SOUND LIKE IT IS A WATER VALVE ISSUE.DRAIN AND CANCELTHE MACHINE FIRST THEN TRY TO SHUT OFF THE WATER GOING INTO THE MACHINE PROBABLY UNDER THE SINK. SEE IF THE WATER IS STILL COMING IN TO UNIT. IT SHOULD NOT BE. THEN TURN ON WATER IF THE WATER STARTS TO FILL MACHINE THEN CHANGE THE WATER VALVE.
Mar 27, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
After washing a load of dishes/pots & pans in the dishwasher, there is a white film & gritty feel on everything. I use Finish dishwasher detergent (powdered) and Jet Dry rinse agent. We do have...
The problem is hard water. Go to www.dishwasherfilter.com and get their new product. It filters the water and takes out the hard minerals that cause spots and clog dishwashers. It is very affordable and has a money back guarantee.
Mar 17, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Says model # shu9915 not cleaning well .leaving residue on glasses almost easier to wash by hand and some food stuck on plates etc. and soap tablets not dissolving completely
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 14, 2010 | Bosch SHU9950 Dishwasher
How much salt should you use in a refill of a dishwasher in a hard water area
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Water hardness is measured in either European °E (clarks) or in the German °dH ( Deutsche Härte) you will find this on all Bosch Dishwashers here is the comparisons for the two.
If your water is Very Extremley hard then you will need to program your Bosch dishwasher using the Code
H:06 to give you maximum protection here is a comparison table for the codes and the Clark and Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Deutsche Härte with the standard Bosch codes.
I suggest that you use Calgon Dishwasher ( Sodium Carbonate formula Na2CO3.) tablets in the dishwasher every week this is a brand-named water softner that is essential to be used in areas of hard water which causes calcification and catastrophic failure. Use both the salt and the Calgon to suit your hardness.
If you live in a soft water area then set code H:01 as the extra is not required and only use Calgon tablets once a week use normal salt or tablet for the other washes.
Hope this helps
Sep 30, 2009 | Bosch 24 in. SGS43C12 Classixx...
Bosch Dishwasher pump keeps emptying
Disconnect the power to the unit. Remove the lower access panels and check the tray under the dishwasher. You will probably find it is full of water. Use a towel or a sponge to remove the water. There is a float that will stop the operation of the unit and run the pump if water is in this tray. Test the unit. If there are no leaks, check the drain hose under the sink. THE DRAIN HOSE MUST RUN UP TO ABOVE THE TOP OF THE MACHINE THEN TO THE DRAIN. If the hose is not set up like this, water from the sink drain will flow into the dishwasher and overflow into the tray under it.
If there is no water in the pan under the dishwasher there may be a problem with the pressure switch at the side of the pump housing but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
Go here for Bosch Dishwasher Parts: http://www.repairclinic.com/Bosch-Dishwasher-Parts
www.RepairClinic.com
Feb 11, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch SHU9915 Does Not Drain
faulty controls..the signals are apparently getting there, but the machine is intepreting them oddly..may need a new control board behind panel
Mar 09, 2008 | Bosch SHU9950 Dishwasher
No water in dishwasher
You need the check the water level switch which is located on the diaphram of the water fill assembly. This is located on the laft side of your machine behind the metal panel. if this switch sticks it will not allow water into the machine
Mar 03, 2007 | Bosch SHU9915UC Dishwasher
Bosch SHU9915UC Dishwasher Logo
258 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
