Question about Olympus Camedia C-5050 Zoom Digital Camera
How to replace LCD monitor/screen in an Olympus C5050 camera
I need detailed instructions on how to remove the LCD montoir/screen from my Olympus C5050 camera, I broke the origina one in an accident and need to replace the screen
  • 593 Answers
Easy, remove the 9 screws that hold the rear case and pull the case apart,.remember there are 4 screws under the hotshoe base and 4 under the memory door and one under the USB cover. You need to pry and slide the hotshoe base back with a slim screwdriver and youll see 4 screws, remove the rear ones. There will be 2 ribbon cables attached to the rear case, the LCD and the buttons. These pull out carefully with gentle pressure. The LCD can be removed with screws and another ribbon cable connector that needs to be unclipped and then removed. replace LCD, Put it back together and make sure the ribbon cables are fully seated. Good to go.
Posted on May 12, 2008
Can I update firmware on an olympus camedia C5050z camera ?
There has never been an update for the firmware of the C5050 zoom. On Olympus they only offer some updates for Mac and Windows, to improve connection (driver) and a RAW plugin.
May 02, 2014 | Olympus Camedia C-5050 Zoom Digital Camera
Same lens error
The 4 megapixel Nikon CP4500
Nikon CP990.
The Canon G3 or G5
The Olympus C5050
Sony F717. Imo a g3, G5, C5050 or f717 would be a much better choice.
Regards, Waqar.
Aug 03, 2009 | Nikon COOLPIX S10 Digital Camera
Broken LCD - Need cost or can I avil Warranty as in Warranty period.
Unfortunately I would be pretty sure that the warranty wouldnt cover the cost of your screen as it would come under misuse... ie: you broke it dropped it caught it damaged it ?. and not covered under electronic breakdown or fair wear and tear , however dont despair a replacement screen is not that much and fitting it is relatively simple with the right tools and a steady hand and good eyesight ..Cost of a replacement is available on the Olympus website .. however if the screen just stopped working and you didn't break it then yes it would be covered under warranty .. Regards Vortash
May 12, 2009 | Olympus Stylus / mju 1060 Digital Camera
Olympus C5050
That's a crying shame.  I believe that spares are no longer available for this unit (which is, IMHO, one of the very best prosumer digitals ever built).
Your best bets would be to take it to a local camera service center, or, to look on eBay for a used C5050 or C8080 (8MP with most of the same capabilities and some improvements, but, not quite as good an aperture) for a very reasonable price in good condition.
I know that's less than ideal, but, after a great deal of research on a similar problem with my C5050, that's where I ended up.
Sep 22, 2008 | Olympus Camedia C-5050 Zoom Digital Camera
Battery cover
I'd suggest cardboard and duct tape. The same happened to me. You can also try gluing small pieces of Velcro to fasten closed that way. To the best of my knowledge, that clip can't be replaced.
Nov 05, 2017 | Olympus Camedia C-5050 Zoom Digital Camera
C5050 LCD repair
I have a spare LCD screen, they are easy to remove and install, from an Olympus d-595. I think it may work, it's 1.8" and has the ribbon interface and a power connector
May 28, 2008 | Olympus Camedia C-350 Digital Camera
LCD Screen Black/Blank. ? ? ?
Perhaps you have quick view turned off in the setup menus. There's no way the CCD is the problem as the camera takes pictures.
Feb 09, 2008 | Olympus Camedia C-5050 Zoom Digital Camera
Olympus C-8080 LCD wont work
Is the battery setting set to Battery Save mode. If it is then the view screen does not work.
Apr 07, 2007 | Olympus Camedia C-8080 Wide Zoom Digital...
Manual Focus Problem
Yup, the Oly C5050 MF leaves a lot to be desired... What I did was to use the AF to get a focus lock then while still holding the shutter half way I would change focusing mode to MF - it will keep the distance value of the AF... Hope this helps...
Sep 13, 2005 | Olympus Camedia C-5050 Zoom Digital Camera
Memory card compatibility
Can't be much help on this one I'm afraid. I too have a C5050 and have numerous cards the largest of which is 512MB. I wouldn't like to use anything bigger than this just in case the card fails. I don't like having all my eggs in one basket. I quite often change cards on a shoot well before they are full also for the same reason. . Not so expensive to replace as well when they do go wrong. I also have an XD card loaded at the same time and swap between the two frequently That said to date I haven't had a CF or XD card fail on me as yet, but theres always a first time. I've also never had any problems with the C5050 recognising any CF cards of any type up to 512MB in size and cannot see any reason why they would fail to use a 1GB or above.
Sep 12, 2005 | Olympus Camedia C-5050 Zoom Digital Camera
Olympus Camedia C-5050 Zoom Digital Camera Logo
386 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
