Question about Nintendo Rumble Pack for
I have an old N64 nyko HYPER>MAX+8 rumble pack and I would like to know what the stteings m1 m2 A & B mean.
4 Suggested Answers
SOURCE: N64 Expansion Pack Pak Use
im not sure but i know that on my zelda games it just pulls it when it needs it
Posted on Apr 19, 2008
  • 6 Answers
SOURCE: Can't play StarCraft - what kind of pack do we need and where do it go in the system
The rumble pak is optional, all it does is shake the controller during gameplay. The expansion pak is required to play the game. It increases the Ram inside the console to 8MB. Some games its is optional, While others it is required.
Donkey Kong 64, Perfect Dark, Starcraft 64, The Legend of Zelda: Majora's Mask all require it for all the feature to be accessable. There may be other games that use it but they do not require it for the most part
Posted on Jun 26, 2009
  • 291 Answers
SOURCE: Goldeneye 007 N64 constant framerate drop with Memory Expansion pack
Well try cleaning the gamepacks out with qutips and rubbing alcohal sounds like a glitch which can occur from and by dirtyness then.
Posted on Dec 26, 2011
Need to clear m1,m2 & m3
To clear any memory, store the value 0 in it.
Feb 05, 2014 | Texas Instruments TI-30XA Calculator
Password1752809
If you forgot your password and/or want to reset the router back to the default settings:
Step 1 Power the unit off by unplugging its power adapter.
Step 2 Insert a paper clip in to the reset pinhole. Press and hold the reset button with light pressure.
Step 3 Power the device back on by plugging it in. Continue to hold the reset button.
Step 4 Watch the lights on the front of the gateway. The M1 & M2 should come on solid. When the M1 & M2 begin to blink slowly, release the reset button.
The unit will reboot itself and should be at factory defaults. If the M1 light is not blinking about once per second, recycle the power on the gateway.
If the M1 & M2 continue to blink rapidly, you held the reset button for too long. Power the device off and repeat the reset procedure.
The default username for our routers is admin. The password is blank. If your router asks only for a password, use admin (lower-case). The default IP address is 192.168.0.1.
BEST OF LUCK
Dec 15, 2013 | D-Link DI-704P Router
How do you set the time and date on blood pressure monitor model DS-1902
Use memory M1 button to increase the flashing year and memory M2 to decrease the year. Press START button to confirm and go to the next step. Day flashes. Press M1 or M2 to adjust and then START to confirm. Month flashes. Adjust with M1 and M2 buttons and then press START to confirm. Hour flashes (the clock operates in 24hour mode). Adjust with M1 and M2 buttons and then press START to confirm. Minute flashes. Adjust with M1 and M2 buttons and then press START to confirm.
The clock is set and the unit is turned off.
Please rate if this helped. Thank you
Jan 15, 2011 | Mark Of Fitness DS 1902 Blood Pressure...
I don't know how to turn on wierless
> Vendor/Model-----------Type----------Location
> Dell D600 & D610-----KeyBoard-----Fn+F2
> HP nc4000 & nc4010-----Button-----Above Keyboard
> HP nc4220-----Button-----Left Side of Laptop Near USB Port
> HP nc6000 & nc6220-----Button-----Above Keyboard
> HP nx9010-----Button-----Front side of laptop
> HP Omnibook 6200-----Button-----Left side of laptop
> IBM T43-----Keyboard combination-----Fn + F5-----Click "Turn On"
> IBM X32-----Keyboard combination-----Fn + F5-----Click "Turn On"
> Toshiba M1 & M2-----Switch-----Left side of laptop-----Towards
> front
> Toshiba R100-----Switch-----Right side of laptop
> Toshiba TE2000-----Switch-----Left side of laptop-----By Vol ctrl
> Toshiba Tecra 2100-----Switch-----Left side of laptop-----By Vol ctrl
Or you can do that from device manager.
May 31, 2010 | Dell Latitude D610 Notebook
Clearing display
The M1 in the display remind you that the M1 memory contains a number that is not equal to 0. So, to get rid of M1, M2, or M3, you shoild store the value 0 in them.
0 [STO] 1 stores 0 in M1, and thus erases its contents: M1 disappears
0 [STO] 2 stores 0 in M2, and thus erases its contents:M2 disappears
0 [STO] 3 stores 0 in M3, and thus erases its contents:M3 disappears.
Feb 18, 2010 | Texas Instruments TI-30XA Calculator
M1 and m2 are in top left corner. How to undo it?
Press 0 [STO] 1 to clear the Memory M1. Indicator M1 will disappear.
Press 0 [STO] 2 to clear the Memory M2. Indicator M2 will disappear.
Dec 15, 2009 | Texas Instruments TI-30XA Calculator
May 19, 2009 | Nintendo N64 Expansion Pack for 64
Uniden Model EXP7900 How do I program button m1
One-Touch Dialing
Your phone is equipped with three .One-Touch Priority. keys for
instant dialing (m1, m2, and m3). You cannot store phone
numbers directly into m1, m2, andm3. They are only used
to dial phone numbers stored into memory locations 1, 2, and 3
on the keypad.
1. To instantly dial phone numbers stored in memory locations
1, 2, or 3, simply press m1, m2, or m3. (There is no need to
press talk, the phone will automatically dial.)
2. If no phone number was stored in memory locations 1, 2, or 3
on the keypad, pressing m1, m2, or m3 will do nothing.
I hope this helps.
Rollin CBs
Dean
Nov 04, 2008 | Uniden Cordless Phone
Turbo c source code
#include<stdio.h>
float add(float,float);
float sub(float,float);
float product(float,float);
float divide(float,float);
void main()
float n1,n2;
char sym,choice;
printf("This Program is a program for calculator\n\n");
scanf("%f%c%f",&n1,&sym,&n2);
if(sym=='+')
printf("\n%f",add(n1,n2));
if(sym=='-')
printf("\n%f",sub(n1,n2));
if(sym=='*')
printf("\n%f",product(n1,n2));
if(sym=='/')
printf("%f",divide(n1,n2));
printf("\nDo you wish to continue[y/n]");
scanf("%s",&choice);
if(choice=='y'||choice=='Y')
main();
float add(float m1,float m2)
return(m1+m2);
float sub(float m1,float m2)
return(m1-m2);
float product(float m1,float m2)
return(m1*m2);
float divide(float m1,float m2)
return(m1/m2);
Feb 21, 2008 | Computers & Internet
M1 m2 m3
STO the value zero into whichever memory has something stored and M1, M2 or M3 will disappear
Oct 25, 2007 | Texas Instruments TI-30XA Calculator
Nintendo Rumble Pack for   Logo
75 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
