I have a Linksys BEFSR41v4 router that resets itself every 12 hours which is annoying if I'm doing something online and I forget to notice it's about to do it.
  • 173 Answers
Try to update the router's firmware, plus make sure that the router is not experiencing any power interuption during the time you specified.
Posted on May 06, 2008
Every so often, my internet seems to crash. On my pc it has a yellow caution sign over the internet. The data send/receive lights on my modem flash but the others don't when this happens. I try un
If it works sometimes ? when you unplug it then replugging it back in something is wrong with the modem / router or they might need to be reset .
or firmware upgrade
Reset linksy router b> One of the most common fixes for Internet connectivity often involves resetting the source of your Internet connection. If you have a DSL or cable Internet connection, you may use a Linksys router to get on the Internet. When you reset a Linksys router, you'll likely solve your connection problem.
Turn off the power to your computer's modem. Use the switch on your cable or DSL modem to disable it while you reset the Linksys router. Find the reset button your Linksys router. Most Linksys models have the reset option on the back of the router. Use a pointed pen or pencil to press in the reset button on your Linksys router. Hold down the reset button for approximately 30 seconds. Watch the lights on the front of the router. After you reset the router, power will get restored to the Linksys router. Once power's available, you can switch the modem back on. Reconfigure your router. After you reset your router, you'll have to log in and reconfigure your settings. The login name is typically left empty with your password as "admin."
Reset a Linksys Wireless Router b> You may need to reset your Linksys wireless router if you are having Internet connectivity issues or other networking problems. You can reset the router to the default factory settings, such as the default IP (Internet protocol) address, username and password. However, after you perform the factory reset, you can follow the initial setup instructions to replace your previous settings.
Write down any important settings you may have--such as the router's password--before you reset the router. Locate the reset button on the router. Some Linksys models have a reset button on the back side. Other Linksys models have a small pinhole you may need to access by using the tip of a pen or pencil. Press and hold the reset button for a minimum of 30 seconds to perform a factory reset on the Linksys router. The Linksys router should lose power. Power on the Linksys router to initiate the configuration wizard. Reconfigure any previous wireless settings on your Linksys router.
Hope this helps.
Dec 28, 2012 | Computers & Internet
Trouble alarm every 12 hours
Here is a link to instructions to access web based control of alarm unit.
Hopefully you can log into it and find where to set time server, or at least set time/date.
Aug 14, 2017 | DSC Tl-150 Ip Communicator Lan Wan Network...
Im trying to install Linksys2000 to my computer , but keep being asked for Router password. What is the password. This router came with no software even tho the packaging says it does . Its damned...
Normally userame and password of linksys Router is admin and admin respectively, if it is not changed,
if still can't access, you can reset your router by pressing and holding reset button for few seconds,
Thank you, Please don't forget to rate me.... please
Aug 28, 2011 | Cisco Linksys E2000 Advanced WirelessN...
Linksys WRT350N Connection Problem and Power Light Flashing.
Are you trying to set up the router ? For this you don't need to use Linksys Easy link advisor. Easy links advisor has bugs in it. If you call the Linksys tech support, they will also not help you for Easy link advisor. All you need to do is, open the router set up page and check the settings of the router. according to the settings on the router, you can connect the new device to the network. is ther any computer connected to the router? use that cmputer to open the router set up page.
Apr 06, 2010 | Linksys WRT350N Wireless Router
My daughter is here visiting and she tried connecting her laptop to our wireless internet but instead created a new network. It changed the name of our network and is now password secure but noone knows...
there is hope if she did not change the default username and password of the physical router itself. because then you could connect to the router using the default ip address for linksys routers and connecting to it using the default username and password. Then you could probably restore the default network setting from within the router with probably a one button option in there. All depends on the router. Then you can reconfigure all the setting to go back to however you had it before...I won't even get technical with it because you'll probably need to have a tech or someone do it.
But before we get ahead of ourselves make sure that what you need isn't just the WEP key which can normally be found on the router itself. If this is all you need it will save you a ton of headaches.
Dec 21, 2009 | Linksys Wireless-G Broadband Router
My router won't connect to my computer!
Try pushing and holding the reset button behind the router. This resets everyting to factory defaults. You do not need to install the software for your router. I own one of these routers and I did not install the software. If your computer is a desktop, make sure your wireless card is linksys and go to
This is the linksys router configuration page.
Make your wireless router password if you want. Chose the things you want or don't want.
Check the SSID of the router.
Change it to something you can remember.
Go on your iphone or ipod touch and search for wireless networks. click on the name of of your router, which is your SSID.
Type your password of the router you made if you made one.
If these steps don't work, go to to find support.
Nov 07, 2009 | Linksys Wireless-G WRT54G Router
Where do I find the Network Key?
It's either taped to the bottom of the router or :-)
There are 4 ways to implement wireless security in a Linksys router, Disable SSID (broadcast of wireless name), WEP (Wireless Equivalent Privacy), WPA (Wireless Protected Access), and MAC address filtering. These are probably listed in order of ease of use and degree of security and are covered here:
Not broadcasting the SSID doesn't make it invisible, it just doesn't send out the name. I guess an enterprising 12-year old could probably figure it out, but it does keep the casual user out of the network. MAC address filtering is the most severe, but it means that every user's MAC address has to be discovered and allowed in your network. Not much fun if you have friends over or test a lot of wireless equipnement.
In a Linksys, network keys come in two flavors, WEP or WPA. The link above explains the difference. The easiest one for most of us to use is WEP. It's not as secure as the WPA, but it keeps the casual user out of our networks. I imagine the "hacker" can break the code, but I'm just concerned about the neighbors. Both schemes will slow down the you're really going to notice :-). I still do my laptop drive synchronization to the file server via wireless and it runs overnight.
To implement 64-bit WEP, you need a 10 character HEX key. I pick something simple like 1011121314 or FACE123456. (hex being 0-9, A-F). In our Netgear routers, It stays visible in the router so if you forget, you can see it. I'm pretty sure that the longer the key, the more overhead is added to your transmission, but you can make your WEP key 128 bit if you think 26 characters is better than 10. If you use WPA, you can pick your key like (Wir3le55), but if you don't spell it right, or forget it, you have to reset the keys.
This visibility of a WPA key may not apply to Linksys, but it's something to check.
You can easily spend an hour or more on the Linksys link trying to understand what to do with security. When I did mine, I didn't find out until I was on vacation that I even needed it. We get activity reports of websites visited emailed to us, and the reports kept coming in! It turned out that one of our neighbors was using our internet while we were gone. I never found out which one, but we now have 4 or 5 networks to choose from LOL.
So, the quickest way back into the router is to turn on WEP, give it an SSID name, give it a 10 character HEX key, and save it, then go to your laptop, log into the Wireless with the same key and you're online.
Fast explanation to a long post.
Apr 15, 2009 | Linksys Wireless-G Broadband Router
Linksys wireless g router forgotten the password
you have to master reset the router
(notice in this case the configuration also will be reset)
to do this press the reset button (on the back) more than 10 seconds
need further help let me know
feed back plz
Apr 05, 2009 | Linksys Wireless-G WRT54GS Router...
I cannot find the security code for my Linksys system. Is there a way of retrieving it? I noticed that at certain hours of the day - especially at night, the added computer laptop functions with...
If you have forgotten your LinkSys router password, the easiest thing to do is to reset your router to the factory default settings.
To restore the router configuration to factory defaults, hold the reset button on the unit for 30 seconds.
Once your router is hard reset, you will need to login and reconfigure it again.
To reconfigure your LinkSys, connect a PC to one of it's Ethernet ports, load a web browser, and go to the URL This will take you to a popup box which asks you to enter a username and password to login to your router.
Logging in to a LinkSys Router
LinkSys Default Password On older LinkSys routers, the default username is blank and the default password is "admin." On newer Linksys routers, both the default username and the default password are set to "admin."
Once you are past the login screen, you are able to reconfigure the LinkSys router.
Jul 17, 2008 | Computers & Internet
Open Questions:
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
