Question about Craftsman Garden
Need repair manual for a dana 4360-122 transaxle
2 Suggested Answers
  • 6468 Answers
SOURCE: Dana Transaxle how to change grease or oil
some are not set up to service
Posted on May 25, 2012
How do I replace the clutch?
step 2, remove trans-axle. (im assUming stick shift, as both have clutches.) it's only tedious no tricks or rabbits out of hat.
why not youtube others doing this first. see if its "easy for you" first.
so what does it say there. on that #2 step in FSM.book
answer for STICK shift car.
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Disconnect the negative battery cable.
  3. Drain the transaxle oil.
  4. Remove or disconnect the following:
    • Clutch operating cylinder with hose still attached
    • Gear control cables
    • All the wiring harness clamps and connectors involved with the transaxle removal, tag if necessary for location to aid during installation
    • Ground cable at the transaxle
    • Starter
    • Exhaust No. 1 pipe bolts
  5. Support engine with lifting device.
    • Engine under covers
    • Exhaust No. 1 pipe and exhaust No. 2 pipe
    • Lower stiffener
    • Left and right ball joints from steering knuckles
    • Drive shaft joints
    • Center shaft support and center shaft
    • Dynamic damper
    • Engine rear mounting
    • Engine rear mounting No. 1 bracket with No. 2 bracket
    • Transaxle to engine bolts and nut
  6. Support transaxle with a transmission jack.
    • Left engine mounting with bracket
  7. Remove any remaining attached parts from the transaxle.
  8. Pull transaxle out so as to disconnect the input shaft from the clutch disc and then remove it.
then the install.'
lots more steps and torque settings. RTM?
Apr 17, 2015 | 2006 Suzuki Aerio
Need parts for my dana transaxle d4360 140
The company is now Dana Spicer, there are no importers in the UK, it should not be a problem in the US.
Aug 06, 2013 | Craftsman Garden
May 22, 2012 | Poulan Garden
User manual for sauer-sundstrand transaxle?
This is the only provider of repair manuals on that transaxle on line. I normally get the manuals from the dealer or a local repair shop but this site should provide you with what you need:
http://hydrostaticpumprepair.com/html/sundstrand_hydrostatic_parts_a.html
Nov 25, 2011 | Danfoss Sundstrand-sauer-danfoss...
How to remove a automatic transmisson from a 1993 ford escort
you need engine support fixture or engine lift crane support engine when you remove transmission.you need all basic tools need floor jack and 2 jack stands.you need a haynes repair read chapter transaxle removal, you have right many things to move remove transaxle this is not a easy task you need a repair manual read entire procedure before removing transaxle, if its your first time you will need a helper.
Nov 12, 2011 | 1993 Ford Escort 4 Door
Troy-bilt model 13AN77TG766 wont go forward or backward. Belts seem to be moving fine. Please help, unable to find manual online.
The manual probably won't be of much help with this problem. Your transaxle may have seized up or failed due to the introduction of water into it. A lot of riders have had this problem, especially the ones with the DANA manufactured transaxle. I hope this is not your problem, and that the problem is in your shifter linkage between the lever and the transmission.
I am continuing to look for the manual. In the meanwhile, here is your complete machine with All parts, diagrams, breakdowns and part costs included. Hope this helps. It is sometimes tough to locate manuals as you have found.
http://www.partstree.com/parts/?lc=Troy-Bilt&mn=13AN77TG766+Pony+%282006%29
May 21, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
2004 Dodge Stratus coupe 2.4 L hard shifting on Manual Transaxle. How do I check fluid (Gear Oil) level?
There is a small pipe threaded plug on the drivers side of the tranny about half way up the body and aroun the rear center from front to rear. When removed,fluid should flow from the hole(providing the vehicle is level on all axises), if not, fill to top of the hole with new gearoil or tranny fluid whichever is specified in your manual. Thank you, Dana
Oct 04, 2009 | 2004 Dodge Stratus
1991 Chevy Cavalier Transaxle removal
you need to support engine.you need haynes repair manual. you have 58 steps to remove transmission.it would be easier to have repair manual.
Apr 13, 2009 | 1991 Chevrolet Cavalier
I just got a used murray riding mower model #30544X92A
Go to Murray.com and they have their manuals and parts list. If you don't see your model E-Mail them your model and ask for the info. I did this with my older model Murray and the next day they E-mailed me back with the manual and parts list..
Mar 22, 2009 | Garden
Garden Logo
207 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
