Question about Garden
Hi, I have a Ariens 1740 ezr. Its about 10yrs old. The problem that I have is that the drives don't go the same speed. When you first start the mower, the mower is slow, but warms up and goes faster. Reverse has gotten really slow. If you try to tow a small yard trailer you can see a big difference in speed.\r\nDo the drives have a way to add oil or change the oil? Do the drives just go bad and you have to replace them, or? Thanks, Brent
4 Suggested Answers
SOURCE: My 1999 Ariens EZR 1742 will not move. Cranks and
if both belts are present are they both moving? Could be tensioner froze up and it is not applying tension. mine had and i had to remove and free it up.
Posted on Sep 29, 2009
  • 18 Answers
SOURCE: ariens ezr 1742 will not move
There is one common problen that causes this. Infront of the rear wheels there are two housings for the indepentent hydrostatic transmissions. There is one gold colored shaft with a ninety degree angle on it sticking out from EACH of the housings on the top front. Again these are on both sides and they each need to be pushed downward so that the rods can then be pushed backward into the transmissions to inguage them so both of the wheels are powered. Give this a try.
Posted on Jul 09, 2010
  • 640 Answers
SOURCE: I have a single cylinder,
The carburetor has debris in it or is dirty. You will need to clean it thoroughly, every passage, every hole and inspect all parts. There is a little trick that I have tried on my mower that worked years ago, I put some carb cleaning fuel additive in the tank and then ran it through the whole tank. It made a big improvement for me, but may not correct the issue. It is just a trick, maybe you will get lucky, if not work, the only solution will be to tear into the carburetor.
I hope this helps get you going soon.
Posted on Aug 05, 2011
Need deck belt diagram for Ariens ezr 1542
Go to the Ariens website for more information.
Sep 24, 2015 | Ariens Garden
My ariens 1648 ezr won't go straight
Sounds like you have some type of wear on your steering linkage. Carefully inspect the steering gear for abnormal wear or damage.
Jul 01, 2015 | Ariens Garden
I have a Ariens EZR 2048 Ridding Mower and want turn over even If i shorten it out by the siloniod
try jump it at starter if jumps start bad silinoide if no power to silnoid bad switch
Sep 08, 2014 | Ariens Garden
Ariens ezr 1540
Check your drive belt above blade belt
Dec 21, 2013 | Garden
Check to see if the solenoid is getting power. On the solenoid there are 3 wires. Two big, one from the battery, the other going to the starter. The 3rd wire is what activates the solenoid. Using a test light or volt meter. See if its getting power on the small wire when you turn the key. If no power, ignition switch, safety switches or fuses. If you are getting power replace the solenoid. If you have 4 wires. Test the two smaller ones.
Oct 17, 2012 | Ariens Zoom 42 In 165 HP Briggs Stratton...
When turning on pto blows the fuse
Look over the entire wiring harness wherever it may be touching metal as it probably is chaffed, simply tape and zip tie it away from the ground source.
Aug 03, 2011 | Ariens Zoom 42 In 165 HP Briggs Stratton...
Sep 26, 2009 | Ariens 34 In. Zoom Series Riding Mower
Looking for manual Arien EZR 1742
Go here:
Hope this helps
Jun 10, 2009 | Ariens 34 In. Zoom Series Riding Mower
Garden Logo
145 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
