Question about Mtd Garden
My riding mower won't start, it cranks but it won't start. I changed the spark plug and I am not getting arc, what could be the problem?
  • 183 Answers
It is likely one of the safety switches is cutting off the spark. They are designed to turn off the mower should you fall off the seat, or try to mow is reverse, etc. These switches get dirty and quit working. They are located under the seat, on the clutch/brake pedal, on the PTO lever (blade engagement), and on the trans gear selector. The least expensive repair is just to replace all of the switches yourself. A local repair shop will typically charge $60 per hour to figure out which switch is bad and then another $40 to $50 to replace it. Expect $200+.
Posted on Aug 27, 2010
Cub push mower starts but won't run. i changed fuel and spark plug. what next?
MAKE ADJUSTMENT TO CARBURATOR,TURN SET SCREW COUNTER CLOCKWISE, HALF A TURN,TRY STARTING MOWER,IF IT STARTS TURN QUARTER MORE,THAT SHOULD DO IT, GOOD LUCK
Aug 10, 2012 | Cub Cadet Street Sign- tractor lawn riding...
I have a snapper 28 hi vac riding mower that won't
first try and start it with carb cleaner or starting fluid with the air filter out if it fires then its a carb/fuel problem if not it could be a spark problem remove the plug connect hte wire back up and crank the engine over while looking for spark if no spark disconnect the kill switch wires from the side of the engine should be a single wire near the throttle cable if spark with that off the problem is in the wiring or safety switch if still no spark its the coil
Apr 23, 2012 | Briggs & Stratton Garden
Replaced sparkplug, solenoid, and battery - riding mower still won't start
check for spark if none remove the harness from the engine and crank it if you then get spark check the safety switches
Apr 22, 2012 | Garden
My scag mower won't run and spark plugs are not firing
unplug the harness and crank it over see if there is spark then is yes check the safety switches if not check the coils
Apr 12, 2012 | Briggs & Stratton Garden
My MTD Yard machines riding mower won't start.
Probably dead gas from sitting too long. Dump it out & put in fresh gas.Could have moisture in it. Pull out spark plug & crank it over several times after putting gas & let it sit a while to dry out or blow it out with compressed air. It should go.
Apr 04, 2012 | Mtd Garden
Won't start. Drained old fuel and added fresh; cleaned in-tank fuel filter; cleaned plug. Still won't start
i would take the plug out and and the spark plug wire on the plug and try cranking it over and make the plug is firing if there is no fire then the ignition coil is dead but if you have fire then its a carb problem rarely ever a timing considering most mowers are timed with key ways which prevent them from jumping time.but if you have fire your good their but my overall suggestion is to rebuild the carb and swap out the spark plug if the mower has set for a period of 6 months or longer.
Aug 26, 2011 | Garden
Murray riding mower won't starter, new solenoid, new spark plug and trying start it from the start turn over but won't start and try from the solenoid still no go.
You need to pull the spark plug out, connect the spark plug wire and ground the plug to the motor and see if you have spark. If you have spark (bright blue) then it is a fuel problem. A yellow spark is and indicator of a coil issue.
Aug 25, 2011 | Garden
Garden Logo
418 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
