Question about Toys
It is a double horse 6092 which i have flown twice i put new batteries in the transmitter and fully charged the battery pack when you push the control forward rotors try to move about half a turn ihave checked out the main motors and the tail motor and all three are working great dut when using the transmitter it will not turn apart from stops and starts when pushing the control back and forword
  • 335 Answers
SOURCE: 1996 chey blazer
Disconnect the connector for the fue injector on the left side front of the intake plenemn there are two wires on red one blue these are your fue injector wires, check for power on one wire with the key ON One has power with the key ON, and then take the test light connect one end on one of the wires coming out of the harness NOT the plenem and the other end of the testlight to the other wire in the same connector don't let them touch togother! sue a paperclip or cotterpin to let you connect the clip of the testlight to the connector.crank and you should see the light blink( I just want to narrow down the possibilities) If you see the light blink Good. Then make sure the PINK wire wire going going in the module has 12V KEY ON and also check the two wires inside the distributor that come from the pick-up unit make sure they are not broke the distributor pick-up unit failes commonly, its easier and less expensive to just get a used distributor that works and be done with it.
If this information is helpful please leave me a good rating and keep in touch let meknow how things go I'll be here to help all I can, here you will find and entry in the BLOG or FAQ that is just like your problem and how I fixed it.
Posted on Aug 10, 2008
SOURCE: Main Rotor Blade - spare part
Go to  You will need to contact them directly in order to purchase the parts because their website doesn't allow you to.
Posted on Jan 08, 2009
SOURCE: need spare part for double horse 9086 helicopter part, main rotor
Hi, you can get all the parts you need for this model from come from Australia but it is quick and a lot cheaper than anything you can get here if you're lucky.
good luck johna4941
Posted on Jan 10, 2009
  • 21 Answers
SOURCE: i have a double horse
Hi, Does the tail motor run freely (nothing wrapped around the motor shaft) if so have you adjusted the potentiometer on the circuit board. If niether of these work I would say you have a faulty circuit board.
Regards, Julian.
Posted on Feb 22, 2009
  • 156 Answers
SOURCE: john deer push pull tractor won,t work.
If you have a clicking problem, I would check the wiring on the foot pedal. something is not connected right, which is making the fuse click.
You can contact J&L at this link or call there toll free number.
They have switches and other parts for these peg perego gators, but I would talk to them to make sure.
Posted on Apr 08, 2009
Red light flashing very fast and not charging fully
How long is it charging until the light goes from flashing red (no charge) to yellow to finally green (full charge) ? If it's not at least 2 hours, sorry I don't have my Roomba papers available, so I'm guesstimating here, it's not getting a full charge. If you can put a voltmeter on the " fully charged" battery pack, that might tell you if the charger is the problem. Clean off the metal contacts where Roomba meets the two metal contacts on the charger. Also just because a battery pack or set is new doesn't mean it's functional. I had a new Apple battery for my laptop that didn't work when I replaced an older one.
Sep 26, 2014 | iRobot Roomba 530 Robotic Vacuum
My tmaxx goes out of control full open throttle and i'm standing 15 feet away. i don't think it's the batteries in the receiver.
Hello try to rebind your transmitter and esc, check your antenna to see if it's broke ,double check and make sure your batteries are fully charged on truck and transmitter,if that all checks out you may have a bad esc or transmitter. let me know what your results are thanks M.B. 2ce7b37f-06d5-47b8-bf19-47612dc686ad.jpg
Jun 17, 2014 | Traxxas T Maxx 3.3 Monster Truck
2007 bmw 525xi - will not start- battery new -fully charged-
put the battery in a warm place for at least 12 hours.
put it back in .
good luck.
Jan 10, 2014 | Charging & Starting Systems for BMW 525xi...
I would suspect poor quality batteries in the battery pack or memory in the pack from recharging a partially charged pack instead of letting it work to flat condition. New batteries take hours to fully charge so if you just plugged in the charger for a short time before use then the battery pack may nit have been fully charged to start with.
Jul 23, 2013 | Panasonic EY3530NQMKW 15.6V Cordless Metal...
My battery charges but only lasts about 20 minutes once it says it is fully charged. Just purchsed a new battery thinking it was old (laptop is about 3 years old) and the same thing happens.
From what you describe and assuming the new battery was "new", I'd say you have an internal short which is draining the battery over a short period of time. I'd also investigate the accuracy of the battery charge indicator. Download this free utility which will give you a more accurate picture of your battery:
I'm assuming you gave the battery a "commissioning charge" when you bought and used it?
If not, this is something you should do with all new LI batteries. This bit is reproduced from a website that sells batteries for the Toshiba satellite series:
"2. The new Toshiba Satellite a205-s4777 battery pack needs to be circled (fully discharged and recharged) three to five times to reach its optimum performance.
3. Toshiba Satellite a205-s4777 battery will undergo self-discharging when left unused for a long period of time. Thus, it should always be stored in a fully charged state and kept in a cool, dry and clean place.
4. It is normal if the new Toshiba Satellite a205-s4777 battery gets warm when being charged or used. However, please pay special attention if the battery pack becomes excessively hot. This may indicate there is a problem with the charging circuit of the electronic device. Please consult a qualified technician if necessary.
5. To maintain the optimum performance of Toshiba Satellite a205-s4777 battery pack, it is highly recommended to circle (fully discharging and recharging) it at least once a month.
6. New batteries are hard to be charged. Sometimes, your electronic device may indicate a fully charged condition about 10 to 15 minutes when Toshiba Satellite a205-s4777 battery pack is being charged for the first time. When this happens, remove the battery pack and let it cool down for about 10 to 15 minutes then repeat the charging procedure. Sometimes, the new Satellite a205-s4777 battery will suddenly refuse to be charged. If this happens, a suggested solution is trying to remove the battery from the device and insert it again. "
Jul 21, 2011 | Toshiba Satellite A205-S4777 Notebook
Even after putting a new fully charged battery camera shows battery empty
The reason you are still getting this error despite the fact that you've placed a new fully charged battery means that the battery is not compatible with the camera. The fact that it states this is because the battery isn't capable of handling the Olympus camera. I would suggest for you to buy a recommended battery pack by Olympus, or a rechargeable battery pack to avoid these errors.
Jun 30, 2011 | Olympus Cameras
I purchase s10-3 netbook. i had problem with its battery which only runs 2 hours if it is fully charged. please assist!
How long have you been using the netbook? If it's brand new, then your battery life is too short. First of all, remember the following for ensuring that your battery performance is optimal:
1. A new battery pack must be fully charged before it is put into use.
2. A new battery pack needs to be fully charged and discharged a few times before it starts performing at full capacity.
3. Batteries discharge when left unused. If you intend to store the netbook for a while, make sure that the battery is fully charged before you do so.
4. Fully drain and fully recharge your batteries every few months.
If your netbook is new, then try one or more of the following and see how your battery performance gets affected: 1. Turn down the LCD brightness of your portable device.
2. Use built-in power management on your portable device.
3. Turn off LCD or other unnecessary accessories when not in use.
4. Set screen saver blank to 1 to 2 minutes of your netbook.
5.. Add more RAM if you can, as this will reduce the usage of the hard drive which exhausts the power quicker.
Hope this helps.
May 24, 2011 | Lenovo Computers & Internet
I have a new syma S032 that has only been flown about 10 times. All of a sudden, it won't go higher than 1' off of the ground. The heli has not crashed so I thought it was a battery issue so I purchased...
You're likely doing one of two (or three) things:
Undercharging. Make sure to charge until light on charging unit is fully bright. If the light on the charger gets ANY brighter when you unplug the helicopter, then it's not fully charged. Note that if you are using a usb charger, that most laptop usb ports and front side desktop data ports are not fully powered to the required 5volts DC, and so can take several hours to fully charge the battery.
Over-discharging. Once you cannot maintain altitude, land helicopter and power it off. Draining a Li/Po battery fully, or even close to it, will weaken it's ability to hold a charge, and can ruin it entirely. Not like the old Ni/Cad rechargeable batteries.
Improper care. Batteries should be allowed to cool for 10 minutes after every flight, and 10 minutes after every charge. Like over-discharging, overheating will always weaken, and can destroy your Li/Po battery.
hope this helps let me know
Dec 28, 2010 | SYMA Toys industrial Syma S032 Ready to...
Toys Logo
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
