Question about Canon i9100 InkJet Photo Printer
The black ink cartridges in my Canon i9100 printer will not print AT ALL. I have tried running two series of cycles with a black cleaning fluid cartridge and that has not solved the problem. I think it is a damaged printhead. Can the printhead be repaired or replaced, and what is the cost to do either task? Thanks for your input on this problem. Sincerely, Laura McConnell
  • 4,472 Answers
Http://www.google.com/products?q=Canon+QY6-0039&oe=utf-8&rls=org.mozilla:en-US:official&client=firefox-a&um=1&ie=UTF-8&ei=fAR4TMu0IcT7lwfp2dDrCw&sa=X&oi=product_result_group&ct=title&resnum=1&ved=0CDIQrQQwAA
That is a link to the printhead for your printer which runs about 80$. After Installing your Printhead
You may need to perform a head cleaning routine after installation and the print head will need to be re-aligned, refer to your user manual on how to do this. Also if you haven't already try a printhead cleaning:
Perform print head cleaning to improve the print quality. Ensure that the printer is turned on and follow
the instructions below.
• Windows
Open the printer driver settings screen and click the Maintenance tab. Click Cleaning.
See page 14 for details on how to open the setting screen.
• Macintosh
Open the Page Setup dialog box and click Utilities. Click Cleaning. Here is a link to the guide as well.
http://gdlp01.c-wss.com/gds/2/0900005582/01/i9100quickstartguide_en.pdf
Thank you,
Lee
Posted on Aug 27, 2010
Black not printing
Canon Bubble Jet i560 Ink Jet Printer not printing black
Aug 01, 2010 | Canon BubbleJet i560 InkJet Printer
We just print black pages but the color cartridges run out. Do you use them for black printing?
No, but every time a printer is started  and after every 5 hours of printing(whatever you print) all the printing heads go thru a cleaning cycle - this cycle uses ink = your color inks are used a little at a time so the cartridges run out.
Normal behaviour.
Jul 20, 2010 | Canon Office Equipment & Supplies
Black ink cartridge holder not working , can not print with black ink cartridge holder, when i use the colored ink holder printer works ok
The problem you are describing is with the black ( BC-10 ) print head and not with the printer.
1. Check your black ink tank and be sure it is not dry.
2. Run the printer through one DEEP cleaning cycle and see if that improves the print.
If your black ink tank is full, and the deep cleaning cycle produces no improvement, you will need to replace the BC-10 print head.
Mar 11, 2010 | Canon BJC 85 InkJet Printer
Why am I still getting banding even though test prints are ok.
Sounds like you've picked up some dried ink on the print head or ink holder. I would suggest removing all the ink cartridges and the ink holder (see directions from Canon) and clean the bottom with rubbing alcohol and a Q-Tip or cotton cloth. DON'T use paper towel, it leaves lint. Check the rollers also to make sure they don;t have ink residue on them. Be cautious when working inside your printer.
Jan 24, 2010 | Canon i9100 InkJet Photo Printer
Black ink not working on canon i9100 - all other colours work
Black is the worst color for clogging the printhead. Go to abcink.com and order a black cleaning cartridge. It works like a charm!
Jan 16, 2010 | Canon i9100 InkJet Photo Printer
Why are only black and yellow printing?
The printer has two ink-cartridges: black and tri-color.
The black cartridge has ink left.
The tri-color cartridge has run out of 2 of the 3 colours of ink.
Buy a replacement tri-color cartridge,
and responsibly recycle the "empty" cartridge.
Nov 19, 2009 | Canon i9100 InkJet Photo Printer
Canon i9100: colors printing incorrectly
I've had the Canon i9100 since 2003 and have excellent photo printing results. In 2009 it started playing up and I'd gt some banding. More recently, black didn't want to print. It was as though the black ink in the print head got dry some days.
April 2010 - The colours started printing strange and I bought a brand new print head and installed it. Only takes a minute. Still had an issue with photo printing. Black and white was excellent but colours weren't true.
Found advice online to try cleaning the print head to print head carrier electrical contacts by rubbing them with a rubber eraser.
I did that and now I'm getting perfect colour photo prints again.
I had been thinking about buying a new A3+ printer but this is old printer is now working as good as new.
Nov 16, 2009 | Canon i9100 InkJet Photo Printer
Ink colour print problems
Ink that leaks out of the ink-cartridge when the print-heads are "parked" is absorbed into the "reservoir" tank. The tank is full. Get it emptied.
Sep 14, 2009 | Canon i9100 InkJet Photo Printer
Printer prints color, but not black even with new cartridge
First thing to do is a head clean then do a test print. Do you see any of the black lines?
If not, don't do a deep clean as this uses up too much ink. Remove the ink cartridges and then remove the print head unit.
Run the print head under a hot tap for a few minutes until all the run off is clear. Take it outside if you can and shake it dry vigourously. You can use paper towel if you like but try not to wipe across the nozzles. Make sue the contacts are all dry and refit it to the printer. reinstall the ink cartridges and print a few test pages - the first couple may well be wasted but then it should start to print properly.
Is the black still missing? If it is do another head clean and another test print. Any improvement? If you start to see some black do some more head clean routines and it may well come back to normal. If on the other hand you see no trace of black at all, it could be that the print head is worn out and needs replacing.
This printer is now of an age where the print head may well be failing. Mine had to be replaced last year as one of the colours stopped printing.
The head is not exactly cheap - but it's cheaper than buying a new A3 printer.
Sep 10, 2009 | Canon i9100 InkJet Photo Printer
The black ink will not print on my canon pixma ip4200
printer head problem remove ink put about ten drops of alcohol in where the ink goes in run clean cycle ten times
Mar 29, 2009 | Canon Office Equipment & Supplies
Canon i9100 InkJet Photo Printer Logo
47 people viewed this question
old marine
old marine
