Question about Comdial Digitech 7714S-FB Corded Phone
Comdial 7714S phone has no dial tone and no tone
SOURCE: GE portable phone model # 26928GE1-D No dial tone-installed new battery still no tone
what does it mean what your phone is out of range
Posted on Sep 06, 2008
whosale
  • 24 Answers
SOURCE: Phone has a dial tone but will not dial
I would first verify that the line is good. Take a known good corded phone. YES corded phone !!! and try dialing with it and make sure it dials on the line every time. Also make sure that the Pulse/Tone setting is set for your service( there is still a few area without Touch Tone belive it or not)
Once you verify that the line is ok check each phone and take the defective ones back to where you bought them.
Posted on Dec 29, 2008
  • 50 Answers
That isn't a whole lot to work with. Get a working phone and take the cord out of the base of the GE and plug it into the working phone.
If the working phone gets a dial tone, look into the modular receptical on the GE base and see if the contact wires aren't out of place.
If you don't get a dial tone on the working phone, try changing the connection cord between the phone and the wall. Also look for the same problem in the wall receptical as discribed above for the GE base.
Posted on May 28, 2009
SOURCE: how do you restore dial tone to line 1 on all
help with phone to have tone
Posted on Nov 23, 2009
SOURCE: 4 phones on a boat,model # KX-T7030 No Dial Tone
pdf.textfiles.com/manuals/.../Panasonic%20KX-T7030%20Reference%20Manual.pdf -
Above is a user manual, below is your reference manual.
http://www.scribd.com/mobile/documents/8790207
below is the circuit diagrams.
http://www.eserviceinfo.com/downloadsm/4832/Panasonic_KX-T7030.html
These phones all operate across pairs of wires. Usually the phones plug into a main box called a EMSS, (Electronic Modular Switching System) It has to be set up first, sort of "Programmed" before it will all work together. You need to also obtain the information on the EMSS unit, as this is the "Brains" of it all. The EMSS unit has a power connection, the phones generally do not. There must be wiring from the EMSS module out to each phone.
Once you sort that out, the phones should all simply work, when connected.
Posted on Nov 13, 2010
The comdial digitech 7714s in the back office does not ring. The phones in the front. There is no on off ringer switch as there is on the executech. Can't find FAQ in the manual I downloaded
I believe the ringer volume is low or at minimal or turned off, that's why you don't here any ring. Try this; press the arrow (left and right or up and down button) on the phone constantly. This should increase the ring volume if actually it is low. Or, call the phone with another line, while the comdial digitech 7714s is ringing and press the arrow buttons without picking up the phone.
Try this as well;
  1. Press optionS
  2. NEXT (twice)
  3. RING
  4. Then UP or DOWN to choose a ring tone
  5. Press SPEAKER to set.
Let me know if this doesn't work, so that I may direct you further.
Good luck.
Apr 04, 2011 | Comdial Impact 8124S Corded Phone
I have an old Comdial Executech 308B system. I ju...
Let me think. On the face of the cabinet, there are 10 or so modular jacks, one for every 2 lines and one for the 8 stations. If you plug the lines into a regular (not Comdial) phone, do you still get a dial tone?
You would get lines 1 and 3, as line 2 would be the second pair of the first jack.
If the box still lights up, I'm guessing that whatever fed dial tone into those lines got disconnected. Is this the part where you tell us you went to VoIP or cable dial tone and they disconnected the local phone company interface?
May 20, 2010 | Lands Phones
Programming issues
I think you ought to start with the proper manual and a proper phone.
The XE series systems were made in the 90's, about 5 or 6 years after your 616x. They took advantage of the new phones, with display, and the 66xx and 67xx series sets. Your 616 uses the 64xx and old 35xx sets. So, which phones are you using? Start on page 47 of this manual http://public.carl.airpost.net/Comdial/Executech%20XE%20System%20Manual.pdf and make sure you program the ports on pdf page 58 (pgm 61) according to the phone types you have. Once you properly define the pones, everything will start to behave.
Carl
Apr 30, 2010 | Comdial Executech 6414 Corded Phone
Comdial Executech 6714x-PG We have nearly 20 phones. All of them get a dial tone but nothing happens when you press 9 to dial out, none of the phones will dial out. Calls can come in only. Thank you
they are either restricted or what you are hearing is intercom tone and not dial tone. the phones may be set to dial out from a diffrent line grop as well have you tried dialing 81 82 instead of 9 and see what happens
Jan 05, 2010 | Comdial 6714 14 Button Executech Phone
Comdial phone system Extension number
In a standard Impact system the entire universe of numbers is 10-41 in a standard E-80PT. You could dial 0 or 10 from the unknown extension and read the display, or just start dialing each unknown or sequentioal number until it rings.
Carl
Dec 28, 2009 | Comdial Impact 8124S Corded Phone
Need to know how to change time on Comdial GCA70-281
  1. Programming the time and date for a Comdial Impact digital phone system must be done from the attendant's station, usually the phone located closest to the Comdial controller. Go to this station before attempting to change the time.
  2. Step 2 set-clock_thumb.jpg Now the phone system's clock is ready to be reset. Without picking up the handset, press the "Intercom" button on the phone. Dial * # 0 1. The digital display2.gif should read "Set Clock"
  3. Step 3 Set the year by dialing two digits (00-99)
  4. Step 4 Set the month by dialing two digits (01-12)
  5. Step 5 Set the day by dialing two digits (01-31)
  6. Step 6 Set the hour by dialing two digits (01-23)
  7. Step 7 Set the minutes by dialing two digits (00-59)
  8. Step 8 set-clock2_thumb.jpg Comdial Impact phone with updated day and time. Pick up the handset and set it back down to set the programming changes. The new date and time should display immediately on all phones connected to the Comdial system
Nov 04, 2009 | Comdial Impact 8124S Corded Phone
Can i set up dial by name on a Comdial DXP? Or
yes you can set up dial if you are given the dialing code from the server internet generating company then apply with any software given to you by them by installing it to enable fast connection of your dialling code.
Jul 09, 2009 | Comdial Impact 8024S-PT Corded Phone
Can't hear when the call is on speaker.
Try two things. Ensure the system has set this phone up for handfree activation.
lastly, if you can not hear a dial tone through the handfree unit then you may have a bad speaker
Oct 10, 2008 | Comdial DSU II (DSUIISW05)
Message light won't turn off...Comdial 8212S
Try dialing (from that phone)
Intercom # 3 then that extension number(exp. 100)
Nov 27, 2007 | Comdial Impact SCS 8212S Corded Phone
Comdial Digitech 7714S-FB Corded Phone Logo
44 people viewed this question
Top Comdial Lands Phones Experts
Starnley Johnwells
Starnley Johnwells
k24674
Are you a Comdial Lands Phone Expert? Answer questions, earn points and help others
