Question about Compaq Evo N610C Notebook
Laptop Messed up SETUP (F10) now computer reads when booting up: Invalid BOOT INI File Booting from C: windows How do I fix this - goes blank after this last message and then nothing!! Thanks, Betty
  • bettyhay May 07, 2008
    Thanks for taking the time to help me, but, still won't work??
You may want to try to reset the BIOS to DEFAULT setings.
If this does not work...Try this turn the pc on and then press F8 a few times to access controlled boot precedure. You will be given some options and you should select "Start Windows in Safe Mode" . Hopefully, you can boot and inspect you boot.ini file.
Hope this helps
Justin
Posted on May 06, 2008
DELL LATITUDE D130 SCREEN WENT BLACK AFTER USING TV WIZARD HOW DO I FIX
You may need to repair windows. Insert your windows disc and boot from it. Choose repair windows.
Aug 05, 2016 | Dell LATITUDE Computers & Internet
NTLDR is missing
Causes
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file..
  5. Corrupt boot sector / master boot record.
  6. Seriously corrupted version of Windows 2000 or Windows XP.
  7. Loose or Faulty IDE/EIDE hard disk drive cable.
  8. Failing to enable USB keyboard support in the BIOS.
Solutions
Many times this error is caused when the computer is attempting to boot from a non-bootable CD-ROM. First verify that no CD is in the computer, unless you are attempting to boot from a CD.
Nov 29, 2011 | HP Compaq 6710b Notebook
Sir i am getting this problem"memory address line faliure at 00027450,read FDFDFDED expecting FDFDFDFD to reslove this issue ,try to reseat the memory
What it means is that boot.ini file is either missing or corrupt. Here is a previous post from the late Alex Nichol, MVP about it and how to fix it.
That message is rather misleading. It happens because the boot.ini file
that tells the boot where to look for 'Windows' is damaged, so it is
looking for files in the wrong place - hal.dll just happens to be the
first one it looks for.
Set the BIOS to boot CD before Hard Disk. Boot the XP CD and, instead
of Setup, take the immediate R for Repair. Assume any password
requested is blank, and TAB over.
Use
Attrib -H -R -S C:\boot,ini
DEL C:\boot.ini
to delete the bad one
BootCfg /Rebuild
to search for Windows installations and make a new one
Sep 25, 2011 | Dell Inspiron 1525 Notebook
NTLDR is missing
  • Insert the Windows XP CD-ROM into the CD drive, and then restart the computer.
  • Click to select any options that are required to start the computer from the CD drive if you are prompted.
  • When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  • Press 1 (One) to select windows XP and then hit enter.
  • When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
  • At the command prompt, start typing
COPY D:\i386\ntldr C:\ (Considering that D is your CD Rom Drive)
COPY D:\i386\ntdetect C:\ (a file that may also be missing)
Then rebuild the boot configuration boot.ini file by
Attrib -H -R -S C:\boot.ini (if not found skip the next line)
DEL C:\boot.ini
BootCfg /Rebuild
Nov 12, 2010 | ASUS Eee PC 4GB Notebook
NTLDR is missing when booted up
DEL C:\boot.ini
BootCfg /Rebuild
Oct 23, 2010 | Acer Aspire 9412AWSMi Notebook
Well its just not doing anything turn it on it starts to flash INVALID Boot.INI file Booting from C;/windows/INDETECT FAILED
You've lost your windows partition. Hold the F8 button down during the startup text, and choose 'Repair my computer' from the options. Pick something like 'Return to factory settings'
If you don't have the 'Repair my computer option' you need to do a clean install by starting up from a genuine windows cd/dvd.
Jul 25, 2010 | Acer Aspire One AOA110-1588 Notebook
It keeps saying invalid boot,ini file booting from c:windows
get a boot manger as it is safe to edit in GUi mode than in text mode;and fix it
Nov 24, 2009 | ASUS Eee PC 900 Notebook
HI my sons acer travel/mate 6292 has crashed and will not boot up, the screen is black but its stating the NTLDR is missing and asking to press ctrl,alt, and delete to restart, yet when I do this it goes...
Hi tracey,
Cause for the NTLDR missing:
  3. Corrupt NTLDR and/or NTDETECT.COM file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable. are
Solutions:
Windows XP users
  1. Insert the Windows XP bootable CD into the computer.
  2. When prompted to press any key to boot from the CD, press any key.
  3. Once in the Windows XP setup menu press the "R" key to repair Windows.
  4. Log into your Windows installation by pressing the "1" key and pressing enter.
  5. You will then be prompted for your administrator password, enter that password.
  6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
    copy e:\i386\ntldr c:\
    copy e:\i386\ntdetect.com c:\
  7. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Edit the boot.ini on the root directory of the hard disk drive and verify that it is pointing to the correct location of your Windows operating system and that the partitions are properly defined. Additional information about the boot.ini can be found on document CH000492.
If you are getting this error message while you are attempting to upgrade to Windows 2000 or Windows XP from Windows 95, Windows 98, or Windows ME running FAT32 please try the below recommendations.
  1. Boot the computer with a Windows 95, Windows 98 or Windows ME bootable diskette.
  2. At the A:\> prompt type:
    sys c: <press enter>
  3. After pressing enter you should receive the "System Transferred" message. Once this has been completed remove the floppy diskette and reboot the computer.
If you are attempting to add a new hard disk drive to the computer make sure that drive is a blank drive. Adding a new hard disk drive to a computer that already has Windows installed on it may cause the NTLDR error to occur.
If you are unsure if the new drive is blank or not try booting from a bootable diskette and format the new hard disk drive.
It's possible your computer's hard disk drive may have a corrupt boot sector and/or master boot record. These can be repaired through the Microsoft Windows Recovery console by running the fixboot and fixmbr commands.
Additional information and help in getting into the Microsoft Windows Recovery console can be found on document CH000627.
If you have tried each of the above recommendations that apply to your situation and you continue to experience this issue it is possible you may have a seriously corrupted version of Microsoft Windows. Therefore we would recommend you reinstall Microsoft Windows 2000 and Windows XP.
If you are encountering this issue during your setup you may wish to completely erase your computer hard disk drive and all of its existing data and then install Microsoft Windows 2000 / Windows XP. Additional information about erasing the computer and starting over can be found on document CH000186.
This issue has been known to be caused by a loose or fault IDE/EIDE cable. If the above recommendation does not resolve your issue and your computer hard disk drive is using an IDE or EIDE interface. Verify the computer hard disk drive cable is firmly connected by disconnected and reconnecting the cable.
If the issue continues it is also a possibility that the computer has a faulty cable, try replacing the hard disk drive cable with another cable and/or a new cable.
ENJOY! RATE THIS SOLUTION RNJ VINOD KUMAR
Jul 03, 2009 | Acer Aspire 5610-4648 Notebook
Cannot open my computer, laptop model PCGK45.
thats simple ur windows xp is corrupted there is only one thing u can do that is put in the xp dvd and reinstall xp
Dec 17, 2008 | Sony VAIO K45 Notebook
Acer TravelMate 4150LCi
you have deleted one of the windows files similair to boot.ini files, there is a method of repair but too much to type here, please go to this link and follow instructions
Sep 19, 2008 | Acer TravelMate 4150LCi Notebook
Compaq Evo N610C Notebook Logo
141 people viewed this question
Top Compaq Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
