Question about EPoX EP-MF4-J3 Motherboard
Bios do not start - EPoX EP-MF4-J3 Motherboard
Ideapad Z560 neither accessing BIOS setup or is starting normally
Your bios seems corrupted. You will probably need to reflash from a thumb drive which is bootable. The F2 should get you to booting screen to access the thumb drive to boot from to flash the bios.
Dec 23, 2012 | Lenovo IdeaPad Z560 Notebook
How do you flash the BIOS
What happens when you turn the computer on?
If the bios is working enough to enable you to boot from a CD download the new bios from asus along with there AFUDOS.exe flash utility and make a bootable CD and copy both to it.
If the bios is completly none functional you should be getting this msg when you turn the computer on,
Boot Block Compatible Version Ver .010
Bad BIOS checksum. Starting BIOS Recovery
Checking for floppy . .
Floppy not found
Checking for CD rom . . .
CD not found
Floppy not found
CD not found
Repeat adinfinitum.
If this is the case you need download the most recent BIOS from compaq and either copy it to a bootable CD if you have this capability or buy a floppy drive for $5 and make a bootable floppy on a working computer and copy this BIOS file to it. Then rename the bios file to A8N32SLI.ROM.
You may not even need make the floppy bootable but I would just in case.
Stick the floppy in the drive turn the computer on and you will see
Checking for floppy . . .
Floppy found.
Reading file "A8N32SLI.ROM" . Completed.
Start Erasing...
Start programing . . ./
Please turn off your system and power on again to get system back.
and happy days will be here.
Jun 29, 2012 | Compaq Presario CQ61-310US Laptop
Won't start bios at start up
Disconnect everything but the RAM, Video and Keyboard and see if it will boot to BIOS. If it does let the BIOS boot remove the RAM and see if that allows BIOS to come up. If it doesn't there is a problem with the Motherboard. If it does with the RAM removed you have incorrect RAM installed or too much.
Nov 18, 2011 | Abit IP-95 Motherboard
BAD BIOS CHECKSUM, STARTING BIOS RECOVERY...
I have seen this be a CMOS battery many times. Also, you can try flashing the BIOS if you continue to have troubles after replacing the battery. You should be able to find that information on the motherboard manufacturer's website.
May 05, 2011 | Computers & Internet
After BIOS upgrade from fdd motherboard C2SBX Supermicro does not starting. Coolers are starting, but not video and not starting BIOS.
Reset the bios (use the proper jumper or rmove the cmos battery for some minutes) and start the pc. Enter the bios settings and locate and load "setup defaults". Save and reboot. If everything works fine make any changes you need at bios settings. I assume that the bios update procedure finished normally, without crash or power failures.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Aug 10, 2010 | SuperMicro C2SBX Motherboard
I have a problem with my motherboard K8U-X.The problem is on the bios.When I start my PC he write a masage that missing something and when I get out the batery start and go to bios to configure and save...
You should be able to get to bios with battery installed (I assume you mean motherboard battery) otherwise changes can't be saved. Usually it is by tapping the "del" key during start-up. If that doesn't get to bios try "F1", "F2" or F10" upon start up.
Sep 12, 2009 | ASUS K8U-X Motherboard
Won't start up
when your computer it should say f1 to stup if you go into to the setup menu and scroll around untill you find bios and if you are going to use it dont turn it off if you are not going to use the bios it will help your computer if you turn that off rate me thanx
Apr 19, 2009 | ASUS P4P800SE Motherboard
Bios
Each BIOS has a differrent access key. Try pressing any one of these keys while your computer is starting up: DEL; F1; F12; ESC. its trial and error since i dont know which BIOS you are using, and do it quickly, dont press all at once, one at each start-up. if that doesnt work then look for the prompt to access bios and quickly press the key while windows is starting up. you need to be really quick to do this, once in bios play arround untill you find the bluetooth settings which should be under Advanced Settings. Enable your bluetooth. WARNING: DO NOT MAKE AND SAVE ANY CHANGES OTHER THAN THE ENABLE BLUETOOTH SETTINGS!!. Save the settings and procceed to start-up.
itJSN
Sep 02, 2008 | Toshiba Satellite Pro M10 Notebook
Bios Set
hai, Harish
your problem seems not BIOS related.
The problem is that some of your installation is not completed.
If you have the XP CD, insert it and complete the installation.
For changing the BIOS setup, just after switching on the computer, press DEL or F2 (refer motherboard manual for the correct key) to start the BIOS utility program to start.
Be careful before changing anithing in the BIOS.
Rabby
Jun 15, 2008 | Intel P4 System Configurator (P4SDRAM1) PC...
BIOS
The BIOS is the Input/Output System of the PC which will coordinate the start up when you start a pc.
Theres no BIOS within the mfc/dcp brother printers.
Nov 30, 2007 | Brother MFC 420CN All-In-One InkJet...
EPoX EP-MF4-J3 Motherboard Logo
Top EPoX Computers & Internet Experts
David
David
Steven Wander
Steven Wander
Are you an EPoX Computer and Internet Expert? Answer questions, earn points and help others
