Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
I have an above ground pool 18' round 52" deep. I purchased the intex saltwater system. I have had it run everyday for 8hrs a day and the ph is high and reads no chlorine. What to do?
    President:
  • Intex Master
  • 1,378 Answers
Salt generating systems cuase pH to rise over time so you generator appears to have been working. What is the salt level in the water? Perhaps your pool is low hence no more chlorine generation.
Posted on Aug 27, 2010
Intex Krystal clear saltwater system
I had nothing but trouble with that unit and it made its way to the dump minus the cord which I re-used as an extension cord,, I had a above ground 18 foot across and 4 foot deep and it never would make chlorine, which if your salt level is correct the machine does....
Mar 23, 2016 | Intex Automatic Salt Water System for ...
I have a Intex above ground Pool 18 feet by 9 and 52 inches deep. How do I over winter this pool?
no you cant keep an above ground pool full water unless you live in a warm climate area that dont feeze
Oct 19, 2014 | Intex 18 X 52 Ultra Frame Pool Set with...
I have a 15foot round pool that is 48 inches deep. My pool is still cloudy after putting clarifier in it. Plus it get shock in it weekly. I also boost it weekly. The salt machine reads normal However...
first balance the pH and then test other chemicals BALANCE pH FIRST. and rum pump continuously for a few days. and then about 8 hrs a day.
Jay the pool pump repair guy in longwood Florida.
Feb 28, 2018 | Intex Automatic Salt Water System for ...
Can you change an Intex - chlorine above swimming pool to a saltwater?
Sure no problem. Just make sure salt level and other chemistry (PH, ALK, Hardness) is within normal ranges. There are number of Salt system available these days, some designed specifically for above ground. Your best bet is to visit a local pool retailer, and ask them for their recommendations based on your pool size type, and type of equipment
Sep 17, 2010 | Intex Automatic Salt Water System for ...
I have an intex salt water system for my 16ft round pool. My FC level is reading 0. Should I proceed to boost the system. PH is high also. Thanks.
run your generator for the full 12 hours. You need some serious sanitizer or you will be going green soon.
Also add some stabilizer so that the chlorine level does not drop so easily
As for the ph hit it with some ph down
It wouldnt hurt to get a bottle of non foaming algacide also
Jun 24, 2010 | Intex Automatic Salt Water System for ...
Do I have to drain my 24 ft round above ground pool to install an intex salt-chlorine generating system? I have just opened he pool and the ph and chlorine levels are where they should be.
no need to drain go to the intex web site and look up your pool size for the starting amount of salt you need.
After ading it run your filter for at least 24 hours before trying to generate use this web site and click on the english version for pump 8110 once it downloads go to page 13 14 15
to find the salt amount you need
chlorinehttp://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?source=intexstore
Jun 06, 2010 | Intex Automatic Salt Water System for ...
Just added an Intex salt water Gernerator to my existing above ground pool. Water is green, can I add chlorine shock to speed up the process. And Ph is low. Can i add PH increaser or should I just wait and...
Yes, you can add chlorine. Liquid chlorine will raise the ph a bit. Don't know what kind of shock you are adding, but wait a day, recheck ph level, than adjust.
Apr 18, 2010 | Intex Automatic Salt Water System for ...
Green light not working on Intex Saltwater System, model #8110
It is easier to explain than to type it all out you can call me at 586-625-2300
we have never had any issues with water clarity
in general I will say you are not filtering enough in normal mode
Mark
Jul 08, 2009 | Intex Automatic Salt Water System for ...
High ph, algea, salty taste
You are going to need to buy chemicals anyway (acid for sure and probably algaecide) so find a good pool store tech and have them test your water and recommend the proper doses.
In summary though, you should not taste the salt in the pool and being able to means the salt content is to high. Chlorine generators will not work if the salt is to high and the fix is to drain water and dilute the remaining water until the salt content is no higher than max. No chlorine could explain the algae.
Generators also cause the pH to rise over time so you will need to keep acid on hand to counteract that.
Jul 05, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
547 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
