Question about Sanyo AVM-3256 TV
I have a sanyo avm3256 with no sound but good picture. any idea what ic or cap or other component that might need replacing?
  • 1 more comment
  • gunnufsonr Sep 01, 2010
    do you know what ic that would be? I don't have schematics for this tv.
    Thanks,
    Rick
  • gunnufsonr Sep 02, 2010
    i need more info to fix this.
    i don't have schematics for his tv. Can you tell me which IC it is and where it's located?
    Thanks,
    Rick
  • 666 Answers
Sounds like your audio fuse has blown or one of the connection to the main power supply has been severed and will require a technician to change out the part however the part itself is inexpensive and the procedure is pretty easy so labor and parts cost should be at a minimum
hope this helps
Robb
Posted on Sep 08, 2010
  • Sanyo Master
  • 5,807 Answers
Hi
the only component that can cause a good picture and no
sound are Transistors
these transistor are controlled from the Micro .
Look for the transistor that mutes the Audio Input
of the Audio Amplifier and :
extract or disconnect temporarily just for troubleshooting
purposes only.
Another option is to check if audio is set to Main not SAP
Another option is to check if there is audio on the
headphone socket.( if available )
I will post further if you need further assistance
Posted on Sep 03, 2010
  • 2 more comments
  • Rommel Cana
    Rommel Cana Sep 03, 2010
    here could could be similar to yours:
    These IC could be good , if there is audio on the yellow line
  • Rommel Cana
    here is your muting transistor:
  • Rommel Cana
    • But check on the solder joints as well, ( Audio IC )
    include to check on the supply pins.
    I just hope you have already checked the speaker.
  • Rommel Cana
    Rommel Cana Sep 12, 2010
    I just hope these answers your problem
    Sergeant:
  • 252 Answers
Your sound output chip is your problem. These go out regularly and are enexpensive. This is your problem.
Posted on Sep 02, 2010
  • Sanyo Master
  • 6,993 Answers
firstly, connect the TV to a DVD player and observe if there will be any sound. If there is still no sound, then you can look forward to the replacement.
The replacement to a TV sound problem would be a sound chip or sound IC. This should be the reason the TV is not bringing out sound .
Therefore you can replace the sound IC/chip of the TV.
Take care.
Posted on Aug 27, 2010
THe volume goes on for abou one minute, then silence. Picture is great
Check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
May 20, 2015 | Sanyo Televison & Video
Sanyo dp42848 with soud no pic
There is sone short circuted components at its main board. Contact a technician. This is not a user repairable work.
Apr 27, 2013 | Televison & Video
No audio on sanyo ds31520 after replacing vertical IC.
Replacing vertical output IC won't poise this type of problem. Check the voltages at the audio output section.
Jun 22, 2012 | Sanyo DS31520 31" TV
No Picture
It sounds like the veritcal ic has failed, and./or a cap in the verical circuit, When replacing the vertical ic, always check for a fuse resistor near the ic, it could be blowen aswell.
Sep 01, 2009 | Televison & Video
I have a Sanyo 32 inch tv, model # DS31650, that has no sound
there is an SIF coil (sound-intermediate-frequency) that goes bad on these units. it will be near the video jungle ic and marked sif on the board. since your sound is poor anyway you could try to adjust, in very small incremens at a time to see if audio picks up. sometimes dirty connections in the coil will cause poor conductivity, by turning this will move contact to new position mch
Mar 08, 2009 | Sanyo Televison & Video
Picture tube
no you have no vertical bad chip ic
Oct 21, 2008 | Sanyo DS27820 27" TV
Tv in video mode
sanyo model: AVM-21 MB
problem: during tv mode the reception will loss and back
in turn to blue color then back to channel frequency!
at video the picture is okay but ther is no audio!
can you please suggest me how to solve this problem
can you send this to my email add.
albertdlc_12yahoo.com thank you and more power!
Jul 21, 2008 | Sanyo AVM-3259S TV
No picture, but power light and sound OK
The problem you have there was a loss of vertical deflection followed by a complete failure of Q301, the vertical Ic LA7833S.
It may have been in part due to the feed caps located in that circuit and there will likely be NO outward signs of the failure.
The Ic needs to be replaced and the electrolytics in that circuit need to be measured with and ESR meter and replaced if bad.
If it's starting to sound a bit beyond your ability I strongly suggest having a qualified shop do this because you can overheat the vert Ic easily just soldering it in...
If you have a shop do it you might ask what they charge to replace the vertical Ic and ESR the caps in that circuit. Explain to them what you have here with regards to how it went out, dropping to a horizontal line before going completely dead... The more detail you can give the easier it will be for the tech to troubleshoot the problem.
Good Luck!
Bill
Nov 24, 2007 | Toshiba 50H72 50" Rear Projection...
Relay "Chatter" with good picture and sound
Sanyo Model AVM-1304 This TV has a loud mechanical "chatter" (or clicking)that appears to be coming from RL001 on the motherboard as soon as ther TV is turned on. I can feel the mechanical vibration on the component. The Picture and sound are very good. The chassis is G6Y-13040. Any ideas? This TV has a loud mechanical "chatter" (or clicking)that appears to be coming from RL001 on the motherboard as soon as ther TV is turned on replace relay as it is easily available or make it direct. .
Sep 11, 2007 | Televison & Video
DS25390 Verticle foldover
If you have a picture but the top is folded over, your vertical IC is probably good and you need to replace the pump-up capacitor next to the IC. When the pump-up cap (typically a 47 or 100uF 35V cap) is open then the picture will have white lines and foldover at the top. The typical vertical output IC is the LA7838, but I am not familiar with exactly which output IC your set uses.
Jul 02, 2007 | Sanyo DS25390 TV
Televison & Video Logo
24 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
