Question about HP DesignJet 5500PS InkJet Printer
Hp designjet 5500 system error 0b0004 00000012
    Champion:
  • HP Expert
  • 202 Answers
Hi...Pls check the cable from iss to supply st is correctoly connected.
APS may be faulty,check replacing the APS if error continues then the problem in main pca replace them .
your problem may be resolved 100% .
Posted on Sep 12, 2010
0B0007
The error code means the vacuum fan is not detected.
Replace the vacuum fan. If that does not fix the problem, replace the Main Logic board. The fan can be ordered from: Designjet 5000 5500 Vacuum Fan and the PCA from: HP Designjet 5000 5500 parts
Jun 26, 2014 | HP DesignJet 1050c plus InkJet Printer
Hp designjet 5500 error code 0b0006
Hello. This error code indicates that the 5VDC and ground are shorted together by the trailing cable. Replace the trailing cable.
May 21, 2014 | HP DesignJet 1050c plus InkJet Printer
Hp designjet 5500 error codes
Error code 0C0040 is caused by the drop detector not detecting drops from at least 2 print heads in the same area. Run print head recovery on all the print heads and see if that clears up the problem. If not, then clean or replace the drop detector. Drop detector can be ordered from: http://www.lpscomputer.com/p-2512-c6072-60179-designjet-5000-5500-drop-detector.aspx
Sep 30, 2013 | HP Designjet 5500 (42 in.) InkJet Printer
After converting our 60" HP
Have you tried to revert back to the dye inks?
If that solves the problem, then your UV ink tubes have a bad control board.
(you did change the ink tubes system, printheads and ink ?)
If the error code continues, replace the Main PCA.
Jul 19, 2011 | HP DesignJet 5500PS InkJet Printer
How to find ip address in hp 5500
To locate the IP address with the HP Designjet 5500, follow these steps below:
Press the Down Arrow keys on the front panel until the Setup Menu is displayed. Press ENTER. Go to the Utilities menu and select Test Prints.Press ENTER. For the HP Designjet 5000 series, select Service Config. Press ENTER. For the HP Designjet 5500 series, select Network-card Config. Press ENTER
Feb 12, 2011 | HP Color LaserJet 5500 Printer
I have problem with my 5500 hp: check printhead path 2
The most common cause of the Check Print Head Path Error 2 is a worn out carriage belt. Open the top cover and locate the carriage belt. It is the long thin belt that extends the full length of the plotter. Use a light and look under the belt for debris that looks like pencil erasure crumbs. If the crumbs are there, the belt is disintegrating and needs to be replaced. See: http://www.lpscomputer.com/c-732-designjet-5000-5500-belt.aspx
Dec 01, 2010 | HP Designjet 5500 (42 in.) InkJet Printer
After print heads alignment its getting error 1004
The trailing cable is probably runing the printhead. Try replacing the printhead and trailing cable together. Parts available at: http://www.lpscomputer.com/c-622-designjet-5000-5500.aspx
Oct 13, 2009 | HP DesignJet 5500PS InkJet Printer
HP DesignJet 5500PS InkJet Printer Logo
771 people viewed this question
Seeker5211
Seeker5211
