Question about Kenmore 22422 Top Load Washer
I have a Kenmore Ultra II 90 series washing machine (#11092561400) it fills & agitates but wont drain & spin/rinse? Any solutions.
  • jmstosic Aug 27, 2010
    Lid makes clicking noise but still wont go into drain/rinse cycle. Timer also stops before the cycle also.
  • Kenmore Master
  • 2,696 Answers
Lift the lid up a few inches and close it down a few times,if you don't hear it clicking you have a broken lid switch,also try to stick a pen or something in the hole on the top and see if it spins,let me know what you find
Posted on Aug 27, 2010
  • 4 more comments
  • Sal De Aug 27, 2010
    try advanceing the timer by hand and see if it will drain,if not you could have something stuck in the pump,let me know what happens
    one more thing you could have broke the motor coupling from overloading the washer,does the motor run or make a noise but nothing happens,you need to take off the pump,then remove the two screws and pop off the motor clips and pull the motor off,on the back you'll see the motor coupling,if that's broke nothing will work,are you sure it was agitiating or did you just hear the motor running?
    not sure if you know how to get into the washer,remove the two phillips screws that hold down the top console,flip the console up,it's on hindges.now with a screw driver pop the two metal clips and between them disconnect the white plastic harness,that is the lid switch connection.now open the lidgrab the frame,pull it back and up and the whole frame will come away from the washer,you'll see the pump down the bottom,with a screw driver pop off the two metal clips and pull the pump forwards,now take out the two screws and pop the two metal motor clips and slide the motor forwards,on the back you'll see the motor coupling,that's most likely your problem
    the part number is 285753A for the coupling,one part has to be tapped onto the back of the motor and the other part gets tapped onto the tranny,put the rubber piece on the tranny part of the coupling and spin it so there is two opening holes on the bottom and one hole out of the three holes on top,now position the motor part of the coupling so there are two of the three arms on the bottom and one on top so when you line them up they will slide into the other piece,also check the four corners of the motor,if any of the four rubbers are off find them on the frame and slide them back on the motor pins before you try to line the motor up,it's to hard to do if you don't do this,let me know how you make out,it sounds like it's hard but it's only a 20 minute job
  • Sal De Aug 28, 2010
    they changed this site around,i don't know if i have to hit reply and answer you but anyway i wrote some things for you to check in case you didn't get notified
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 Series Washer
CHANGE THE LID SWITCH
Apr 18, 2009 | Washing Machines
My Kenmore Washer Model 100, 90 series fills and agitates but
most common solution is to replace the lid switch. (the machine thinks the lid is still open)
Dec 26, 2008 | Kenmore 23822 Top Load Washer
You have a broken lid switch. Its # ll in the diagram. Part # is 3949238. Let me know if you need info on how to replace it, Dave www.washermd.com
Dec 17, 2008 | Kenmore 23822 Top Load Washer
Washer on the fritz
ck motor coupling probably broke or cracked not engaging gearcase
Sep 09, 2008 | Kenmore Washing Machines
Kenmore 90 series that wont agitate or spin
Could be the door switch, do you hear a clicking sound when you close the lid?
Does the motor hum at all in drain/spin?
Mar 12, 2008 | Kenmore 45981 Washer
Kenmore 22422 Top Load Washer Logo
162 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
