Question about Whirlpool WTW5100S Top Load Washer
My 14 month old Whirlpool top loading washer WTW5100VQ has begun making a high pitched noise during the wash cycle. It's also noisy during the spin cycle, but not as loud. It seems to be fully functioning, just noisy. What to do?
    Genius:
  • 1,417 Answers
what this sound simply indicated on the washer is that they has been a bridge up of wires(motor) connected to the drum on the body of the washer .
what you are to do to fix up this problem is first of all put off all form of power supply then carefully unscrew (open) the washer with a screw driver then trace wires, that is, the main power supply down to the drum ,you will fine it connected to a motor /propeller round in shape .
then you should make sure that both are well position with out touching one another including the main body of the washer couple it back carefully then connect it back to the power supply and see the problem solve .
thank you and thanks for using fixya.
Posted on Aug 27, 2010
Samsung front load washer, jerks and makes noise when it first starts spinningthen it smooths out, and works fine.
on many machines that is normal, the shaking continues until the load is distributed relative evenly around the spinning drum. It is also possible it is the main bearing but I am not sure. The noise I am talking about would have been there since new. These links may help. Washer has noise during spin cycle Whirlpool Maytag Sears GHW9100LW1 Washer is Making Loud Noise
How To Fix Washing Machine Making Noise During The Spin Cycle
http://www.partselect.com/Repair/Washer/Noisy/
May 28, 2016 | Samsung Platinum Front Load Washer -...
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Our whirlpool top loading washer starts making a high pitched whirring noise in the beginning of the first spin cycle. Once it gets going full speed the noise stops. What could be?
If you can hear the motor humming during the spin cycle, it could signal a defective motor drive. It's possible for the motor to fail in just one direction, which may be why you only hear it some times.
This kind of issue often requires the help of a professional. To learn more about this issue, read Washing machine will not spin but will pump and agitate. I hope this helps.
Sep 12, 2012 | Whirlpool Washing Machines
Kenmore - high pitch noice during spin cycle
Sounds like bearing squeal,providing no leaks or shake leave meantime
Jul 01, 2012 | Kenmore Washing Machines
Excessive noise during the spin cycle. we have owned the washer for 16 months. problem started 1 wk. the machine is level.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Jan 03, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Maytag washer makes loud grinding noise during the spin cycle
if it's making a noise then either your drain pump bearing is going out or your thrust bearing is going out (assuming the noise happens in both spin and wash). Tip the washer backwards so that you can get underneath of it. Take the belt off and spin the pump pulley on the right side. This should spin effortlessly.
The middle pulley is the trustbearing pulley. Spin this--- one direction it should have a little bit of resistance--- the other should have more resistance
Aug 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Whirlpool washer; spin cycle not draining
It sounds like your water pump is broken. there is a motor inside that pumps the water out when the machine computer changes to spin cycle
Aug 06, 2009 | Whirlpool 4.0 Cu. Ft. Plus Washer
GE Top load washer 15years old. noisy when spinning
washer making a load cluck noise when the spin cycle starts.
It only happens when the motor turns slow for the first minute during the spin cycle. Otherwise it works fine.
if the motor is proper then the bearings in the motor got rusted and that needs replacement.the beasrings are located on the back of the motor.
Apr 03, 2009 | GE WVSR1060A Top Load Washer
Noisy Spin Cycle
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
Jun 12, 2008 | Whirlpool LSR9434PQ Top Load Washer
Whirlpool LHW0050PQ Front Loading Washer VERY NOISY during spin cycle
remove the top access panel 3 screws in top rear.
now look around and push on the drum from top
it has suspension shocks and springs like your car they should resist any movements.
look/wiggle the concrete balance blocks , no cracks or loose.
inside the tub are the arm solid /not loose.
run it with the top open what do you see/hear and where
look under the rubber flap in front did anything get under the tub
Dec 29, 2007 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool WTW5100S Top Load Washer Logo
35 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
