Question about Acer Aspire 5100 Notebook
Received a blue crash screen, Alt,F10 for erecovery, showed copying files, then tried to reboot and shut down without completing reboot. Now when try to start, showes windows small window and moving dots like trying to open and keeps up for 30 seconds and then shuts down again. O/S is Vista Home Premium. Tried to get recovery disks from Acer and told yesterday they have gotten rid of them and computer only 3 years old. Can't afford to buy a new one now. Do you know where I can get a set of recovery disks for an Acer Aspire 5100-4720 with Vista Home Premium? Please HELP!!!
    President:
  • 2,571 Answers
You can use a torrent site like isoHUNT, to download a copy of the Acer OEM vista disc, this is a little illegal, but if you use your own Windows key from your COA sticker, it should register and activate ok.
You may have to download your drivers seperatly from from ACER.
You will need a torrent client like UTorrent, and the download could take a day or so
Posted on Aug 27, 2010
Aspire zg5
aspire netbook to factory defaults Save any files or folders on your Acer Aspire One with flash drives. Drag and drop files onto the icon of your flash drive. Go to "Start" > "Restart" to reboot your netbook. Hold down "Alt" and "F10" when you see the Acer logo on the screen. The recovery menu will load. Hit "Enter" and then "Next" to see your recovery options. Choose "Factory Restore" to set your netbook back to factory settings. Follow the instructions on the screen. Choose your time zone and language when the customization menu appears. Reboot the netbook when you are prompted. Restore your saved files from the flash drive. or Click on the Start menu. Then, select all programs, Acer Empowering Technology and Acer eRecovery Management. If this is the first time you have opened the program it will prompt you to set up a password and create a backup CD. Click the Restore button and select the option that reads "Restore system to factory defaults". Wait for the computer to finish the restore process and reboot. Restoring for the Boot Screen If your computer will not boot up properly, you can attempt to reach the restore option by pressing the Alt button and the F10 button at the same time. When the eRecovery menu appears, choose "restore system to factory defaults". Wait for the recovery process to complete and the computer to restart Hope this helps.
Jan 21, 2013 | Acer Aspire 5720-6661 Notebook PC
I wont to restart from factory
If you need more help with this post a reply
Hope this helps.
Jan 11, 2013 | Acer Aspire One PC Notebook
Corrupt files windows system32 config system
The easiest way to fix corrupted windows system files is do an Acer eRecovery. On power-up, while the Acer logo is showing, press the Alt-key and hold it down while pressing the F10-key repeatedly. Wait while screen shows eRecovery loading. On the eRecovery menu, select restore of system software to factory condition. This will delete all user data from the hard disk and once the restore is complete, you will have to re-enter your initial system configuration settings.
May 25, 2011 | Acer Aspire One PC Notebook
Factory reset for Aspire one without disk and alt + F10 doesnt work
The disk-to-disk recovery may be disabled preventing the Alt + F10 key sequence running eRecovery. To enable disk-to-disk recovery, you must do the following... (do not have an external monitor attached)
1. activate the BIOS utility by pressing F2 during Power On System Test (while Acer logo displayed)
2. select Main from the categories listed at the top of the screen
3. find D2D Recovery at the bottom of the screen and use F5 and F6 keys to set this value to Enabled
4. exit the BIOS utility and save changes.
The system will reboot.
5. while the Acer logo is showing, press the Alt key and the F10 key at the same time repeatedly
6. wait as Acer eRecovery starts up then follow onscreen instructions to perform system recovery.
Alternatively to the above, if Windows can be accessed, the recovery can be done by launching Acer eRecovery Management by running the program from the Acer Empowering Technology program group in the Start menu.
Mar 22, 2011 | Acer Aspire One PC Notebook
My Acer D250 netbook starts show a white screen the reboots it self, sometimes it not only shows white screen but also gray or it run colourful lines then it restart. When it restart it start working fine...
Suggest using Acer eRecovery Management to attempt problem resolution as follows...
1. begin with the D250 powered off ...
2. if present, remove any external monitor (unplug its VGA connector from D250 left side)
3. power on and immediately press F2 to enter the BIOS / setup utility
4. using the right cursor key, cursor over to the Main tab of the InsydeH20 Setup Utility
5. if D2D Recovery is not enabled, cursor down to it, press Enter key and enable in pop-up
6. save any changes by pressing F10 to save and exit, otherwise press Esc to just exit
7. press Alt and F10 together while the Acer logo is showing to get entry into eRecovery.
8. eRecovery entry is indicated by message at bottom of screen "Windows is loading files...".
9. if not successful, power off, wait a minute then power on again and immediately
10. press Alt and F10 at the same time - do this several times while Acer logo showing.
11. once in Acer eRecovery Management (V7.0.10) screen, just leave it there........
12. if after a day or so, the screen has not changed, the problem is likely NOT hardware.
13. on the other hand, if your screen problem occurs after awhile, then it is hardware.
14. if it is not hardware, then your Operating System is likely corrupt or has a virus.
15. If it is not a hardware problem, you can completely restore system to factory defaults.
16. board level hardware repairs best done by sending D250 to Acer's authorized shops.
Dec 28, 2010 | Acer Aspire One PC Notebook
How do i get a back door password for my acer aspire 5315 as i forgot my password
There is no back door password but you can try this
At the Acer splash screen, you can press Alt and F10 to bring up a DOS style version of eRecovery. The unit is able to reload Windows from this mode faster then from CD. If the hard drive is replaced the system loses its eRecovery features. These features are on the hard drive and cannot be reinstalled
  • Be sure that you back up your data files before performing this option. All of your personal data files and applications are erased during the recovery process.
  • Due to the large number of virus and Spyware threats on the Internet, it is recommended that you disconnect all Internet connections before performing the recovery. After the recovery, antivirus and firewall software can be installed, and then the Internet connection can be re-enabled to update the antivirus definitions and perform Microsoft® Windows Updates.
  1. Remove all CDs or DVDs from the optical drives.
  2. Turn off the computer, using the normal Windows shut down process.
  3. After the computer is turned off, disconnect all USB devices except the keyboard and mouse. This includes USB devices such as a printer, scanner, removable storage, or camera.
  4. Turn on the computer. After the Gateway BIOS logo appears, press ALT+F10. The easiest method is to hold down the ALT key and repeatedly press the F10 key.
5.Windows loads files. 6. If you get EDIT BOOT OPTIONS for Windows Setup hit the ENTER key 6.1. If you get EDIT BOOT OPTIONS for Windows 7 , Try ALT + F10 (ALT on the right side of the Space bar) 7. You will get the Recovery console , Select completly Restor to Factory Settings.
Dec 08, 2010 | Acer Aspire 5315 Notebook
I have a Acer Aspire 5745 (CPU: Intel i5 processor 2.5GHz RAM: 2GB OS: Win 7 Home Basic) which is only 2 months old. Yesterday I started a installation setup of a game, when suddenly the system restarted....
Hi, I do apologize for the inconvenience you have been facing.The reason why the laptop does not reboot to Windows even after reinstalling Windows is because the issue is with the hard drive not being recognized the reason for which you get a blinking line on the screen after the Acer logo .In this case I would suggest that if the laptop is under warranty please contact the Acer Technical support and have an order placed for repair.
Thank you for your time and best wishes for your effort.
Nov 19, 2010 | Acer Computers & Internet
I'm trying to restore my acer mini netbook to factory settings.
Nov 04, 2010 | Acer Aspire One PC Notebook
Reboot my Acer Notebook
Run Acer eRecovery Management Copy the Acer factory default backup disk Image Create backup of the system Create a complete backup Creating an incremental backup Erase a backup point Using the option ‘‘Burn Disk’’ Burn a backup disc with the factory default settings Burn a backup disc with the parameters of user Copy the current system configuration to disc Burn a disc backup software Restore the system Restore system to factory default settings Restore system from backup user Recover the system from CD / DVD Re-install applications / drivers Other means of System Restore No Restore CD / eRecovery / password / ALT + F10 or F10
Mar 05, 2010 | Acer Aspire 3100-1405 Notebook
ERecovery won't finish
Hi - mjune - to be able to boot off the cd, your cd/dvd has to be listed as a boot device ahead of your hard drive in your BIOS. As soon as you turn your pc on, it should say on the screen hit alt-F10 for recovery and something like <del> or F2 to enter setup. Hit whatever it says for setup. Once your in, go to the boot section. Your devices should be listed in the order they try to boot from. Make sure your cd/dvd is listed ahead of your hard drive(it may say primary, secondary,etc) If it is not, it will tell you how to move it up in the order. Usually you just highlight the device you want and use the + and - keys on your keypad to move it up or down. Once you have it, save and exit. Usually F10 but it can be done from the tool bar at the top. It will reboot and while it's rebooting put the cd in. If you don't catch it in time don't worry just leave the cd in and reboot. It might say press any key to boot from cd drive. Just press any key. Try this and let me know what happens.
Thanks,
Jeff
May 08, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Notebook Logo
143 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
