Question about Refrigerators
Have older matag fridge,water once every coupleof days is visible from under fridge
  • bryceaitken Jun 12, 2008
    have water in the bottom of the fridge (hgowever food is fine?) answer seems to be to clear the defrost drain.
    So how about some help here, where is the defrost drain and how do I clean it please
    Thanks for your help
    Bryce
  • cjg_64 Jan 06, 2009
    water collects on the bottom of the freezer..then freezes. next time during defrost, water no where to go so leaks on floor. the drain in back is clogged. manual says to use baster and solution of baking soda and hot (not boiling) water, and use baster to inject water into drain to unclog. QUESTION...does it drain into a pan AND does this pan need to be removed and emptied/cleaned...if so how is this done? thank you :)
    Genius:
  • 1,073 Answers
Clean out the defrost drain
Posted on May 06, 2008
I am getting water leaking from under my fridge freezer it stops when I turn the mains supply off for the water filter.
I would check the water lines that supply the water to the fridge, and any visible lines on the fridge itself. I used to have a problem where the plastic lines would get brittle and snap at the ends - I also use a product called Floodstop that has sensors that automatically shut off the water to the fridge if any of the sensors detect water leakage - plus it tests the valve once a month to make sure it actually works when you need it too -
Oct 07, 2017 | Refrigerators
Viking fridge Model DDRB364RSS dripping water unto bottom cooler drawer and later under fridge - once a day or so. Door Gasket is a bit torn.
problem water in a fridge is moisture from the atmosphere--normally from opening the door but in your case from the damaged door seal
any tear regardless, compromises the compartment so have the seal replaced then see if you have a problem
Oct 26, 2016 | Viking Refrigerators
My Maytag refrigerator is leaking water from under it. Model MFI2569VEM
Just how old your fridge is I don' t know. But is your defrost timer working on your freezer. It should defrost at least once a day. You may want to check out the drain on the bottom of the fridge also. It may be partly clogged up. Then newer models have the coils go over the pan to help evaperate the water.
Aug 05, 2012 | Maytag Refrigerators
Water accumulates under vegetable bin (bottom of refrigerator) every couple of days
If this is an older style top mount refrigerator than most likely the drain is clogged causing the water to leak into the fridge during the defrost process. What's the model number?
Jul 06, 2011 | Refrigerators
My matag diswasher fills with water without being used. The process is gradual and takes several days.
two things, your water inlet valve could be going bad. your drain hose from dishwasher is lower than the sink, so whenever the sink is being used, water will slowly back up into dishwasher. if this is the case, just loop the drain hose under the sink, this should solve your problem
Feb 03, 2011 | Maytag Dishwasher
GE Profile REfrigerator: Model PFSS6PKWASS Problem with loud clicking coming from icemaker every 2-3 seconds. Will do this for 30-60 minutes constatntly, then will stop clicking for the same period of...
i have same fridge with same prob makes 6 cubes of ice in a day with a lot of noise like you discribed also i have water collecting under crisper drawer of fridge i have to clean out water once a month or so still trying to figure out how to take ice maker out to fix
Jan 25, 2011 | GE Profile 26.6 cu. ft. Side-by-Side...
Water not going to ice maker
That happened to me once and while it was with an older fridge, it's possible it could be the same problem. In my case, the water inside the supply line actually froze. Tried using hot towels and such on the water supply line but in the end, I had to empty out the Fridge and defrost it for a day. Water for the ice maker worked again after that... and I had a clean fridge!
Hope this helps...
Mike
May 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
WE have an older fridge. Water is now collecting
Good day,
On some of the older models when the refrigerator went thru it's automatic defrost cycle, the condensate water ran down the back wall, under the crispers and out that drain plug you described.
You can verify if that is your model by looking at the back wall of the machine. If there is no drain tube running down the back, then that is the model you have.
If that is the case, just remove the plug. The water should run directly into the drain pan.
Clean the plug and opening and that's it.
Apr 05, 2010 | Maytag Admiral Top-Freezer Refrigerator
Kitchen aid refrigerator superba
hi there,
the drain pan is under the fridge behind the kickplate. the kickplate is the vent-line panel located under the door. it's held on by 2 screws. unscrew the screw and remove the kickplate. the drain pan will slide out. careful, as it's probably pretty full.
Oct 01, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
87 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
