Question about Briggs & Stratton Garden
I have a B & S engine, Bolens MTD, no spark at all. Where is the kill switch?
  • adorablebich Aug 27, 2010
    Jerr, Lowes tells me this model has no kill switch. They suspect its electrical. Had another guy tell me it's probably the seat sensor, but that walking me thru the fix would be too hard by email and would require an on site visit. Thanks. -Joe
  • 2,926 Answers
Of course it has a kill switch, how would you shut down the engine? Do you have a model number for this equipment/engine?
Posted on Aug 28, 2010
No spark tospark plug
possible bad ignition coil or kill switch turned off...
Dec 11, 2013 | Tecumseh 5hp Engine Snow King Mtd Blowers...
No spark on my MTD Snowblower
ake sure your Kill wire that is hooked to your on/off linkage did'nt come off and is permanately grounded, or if it has a key switch ,make sure that it is not faulty, all else fails you are probably looking at a coil being bad. once you get the shroud off unhook the small wire coming from the coil and then roll over eng and see if there is spark then, if not it is bad coil.
Dec 04, 2011 | Tecumseh 5hp Engine Snow King Mtd Blowers...
What is gas oil ratio mix for bolens trimmer model bl100
50:1 here is a website that has parts list and threads for common problems, Hope it helps Tim:
http://www.ereplacementparts.com/bolens-bl100-41bd100g965-gas-string-trimmer-parts-c-27272_27749_27758.html
May 10, 2011 | Mtd Garden
No spark
Eigther the kill switch failed or ignition module. Disconnect wire to kill switch if you get spark then switch is bad. Still no spark with kill wire disconnected ignition module quit.
Sep 29, 2010 | Mtd Garden
No spark on sr230...got suggested new plug ngk...unit was hardly ever used.
The best test for an ignition coil is removing the wire(s) going to the kill switch at the coil. Most small engines will run with the kill circuit open & stop when you ground it. If you disconnect the kill wire & you have no spark, than it's a coil.. If you do have spark, check the switch & kill wire for a short
Sep 22, 2010 | Echo Garden
Eager ****** gas line trimmer will not start no spark at plug
The best test for an ignition coil is removing the wires going to the kill switch at the coil. Most small engines will run with the kill circuit open & stop when you ground it. If you disconnect the kill wire & you have no spark, than it's a coil.. If you do have spark, check the switch & kill wire for a possible short.
Sep 21, 2010 | Garden
What is the spark plug gap on a 4.5 HP 21" cut
With out the model # of engine or plug not 100% certian but 99% of those mower engines run a .8 or .9mm plug gap you will be preety safe setting it at that
Regards
Brad
Feb 05, 2010 | Mtd Products Yard Machines 158CC Tiller
I have a bolens rear tine tiller that will not run. The carborator has been completely cleaned, new gas, new spark plug, new oil, and new gaskets. It seems like it is not getting gas from the tank. Will...
is the fuel filter clogged? you may need to check the engine compression for bad valves or rings.if the compresion is off it wont get gas . check the fuel filter first though and keep me posted.
Apr 23, 2009 | Mtd Products Yard Machines 158CC Tiller
Garden Logo
93 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
