Question about Kenmore 57029 Side by Side Refrigerator
Both sides (freezer & Fridg) stopped getting cold. I can hear a fan running but nothing is cold. Prior to this it was "clicking" from under the fridg.
  • Kenmore Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Aug 28, 2010
Kenmore refrigerator (bottom freezer)
U MAY HAVE BLOWN THE COMPRESSOR RELAY DUE TO THE TRIP? U CAN REMOVE IT FROM THE COMPRESSOR AND SHAKE IT IF U DONT HAVE A METER TO TEST IT, IF IT RATTLES THEN ITS BAD? IF THERE IS A CLICKING WHEN COMPRESSOR IS TRYING TO RUN ITS BAD, OTHER WISE I WOULD SUSPECT A BAD COLD CONTROL THERMOSTAT ESPECIALLY IF UR TURNING IT FROM UNDERNEATH AND NOT JUST THE KNOB? DID U USE A SCREWDRIVER TO GET INTO THE TINY SLOT UNDER THE TIMER AND TURN IT SLOWLY TILL U HEAR A CLICK? TURN AGIN AND THE NEXT CLICK SHOULD TURN IT BACK ON U SHOULD HEAR THE COMPRESSOR AND THE FAN WORJKING
Mar 14, 2015 | Kenmore Refrigerators
Side by side refrigerator stopped getting cold (freezer stopped also). When plugged in, all lights and sounds still run fine.
If all fans are running and no cold at all check to see if compressor is running(under rear panel). If you hear it try and start then a click then the start relay pack may be bad,
Oct 28, 2010 | GE GDS18LBR Bottom Freezer Refrigerator
The freezer and fridg just stop getting cold I get a clicking
Hi,,
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Sep 26, 2010 | Kenmore 54662 / 54664 / 54669 Side by Side...
My refidgerator & freezer stopped getting cold. It is running but no cold air on both sides. (It was making a clicking noise that was coming from the circuit board on the back of the unit) but that has...
Replace the mother board. (it's the board you heard clicking) The only thing you hear running are fans. Check your model and serial number with your parts supplier, as you may be able to get the board free. (only certain models / serial numbers qualify)
Nov 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Warm in freezer and refrig
On some Amana refrigs , the defrost thermostat has to close before the fan will come on . The coils will get cold and since the bimetal clips onto the coils , it will get cold as they do . When cold enough , bimetal closes and the fan will come on . Are the coils getting cold ? If so , then the compressor is working . You could also have a bad fan motor instead of bimetal . Recheck to see if you hear the fan in freezer now .
Aug 15, 2009 | Amana 23.1 cu. ft. Side-by-Side...
Freezer works fridg dosent stay cold
When plugging it back in, check to see if you can feel air circulation (from vents in the top-rear) on the refrigeration side.
Check again after the fridge starts to warm.
There is a fan which is supposed to distribute the cooled air from the freezer to the fridge; this may be failing after the fan has warmed from operation. The bearings in these is primitive and can get sticky impeding the fan's rotation. Replacement of that fan is not covered by the (longer) compressor warranty.
Jul 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The fridge side by side door. Freezer & fridge stop working I can hear the motor trying to go but doesn't cool
When you say motor I assume compressor. No start compressors can be an electrical component like the start relay or the compressor itself. Eric
Jun 14, 2009 | Frigidaire FRS3R5EMB Side by Side...
No cold air coming into the fridg
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
Now, why is that cold air not getting over to the Ref side?
1. The little door is not open.
check your control setting. You should be able to feel air coming through the channel on the Ref side.
2. The fan in the freezer is not working.
You can hear this fan running when you open the freezer.
3. The coils on the freezer side are clogged with ice which won't let the fan circulate the air over to the Ref side.
This is a failure of the defrost system.
You can melt this ice manually for a temp fix but the defrost system needs to be checked. Turn it off, take everything out of the freezer, use a hair dryer to warm the back wall. Do this for as long as you can without anything thawing then put it back in, turn it on and you will be good for a couple of days.
Nov 21, 2008 | Jenn-Air JCD2389G Side by Side...
Fridge not getting cold enough
listen for the compressor running in the back at the bottom. when you hear that running, open the freezer section. do you hear a fan blowing inside the freezer? if not, the evaporator fan motor is jammed with ice build-up or it's bad. hope this helps.
Nov 01, 2007 | KitchenAid Superba Architect KSCS25INSS...
Kenmore 57029 Side by Side Refrigerator Logo
18 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
