Question about Refrigerators
Have a Electrolux refrig. french doors and bottom mount. model ei23bc56iso Its shut off. The display in front at the dispencer says OFF at frezzer side and OFF at refrig side. No other displays or error shows up. Tried to unplug and waited few min. then plugged back in. No beeps , nothing just the off lights came on in front. How do I wake this thing up? What two things do I touch and hold to turn the refrig on? Thanks
  • Tony Aug 28, 2010
    Hi
    there is no sabath here . Please try to uderstand , its off . thats it. I;m just trying to make operational again. Either something on the touch pad has to be done or the mother board in rear of frig. is bad.
    How do you re-boot it?
    Thank you
  • Tony Aug 29, 2010
    Is it possiable for me to get a reply on this problem from your man called PROTEK 480 . Hes helped me in the past. And was quite satisfied.
    Thank You
  • Refrigerators Master
  • 3,083 Answers
There is absolutely nothing on the net about this problem, however, there were a lot of reports of people having problems with their Electrolux refrigerators. Refer to your manual that came with it- it should have the error codes in it, near the back. If the unit is still in warranty, get them to replace or fix it. I couldn't find any info on the error codes for this unit anywhere, so you will have to refer to the manual or call Electrolux support. Here is their support page:
http://www.contacthelp.com/directory/Shopping/Home+and+Garden/Electrolux?ListingID=472
Good luck, thanks for using FixYa, and hope this helps.
Posted on Aug 30, 2010
  • 17,130 Answers
Not sure of this model but Just an advice unplug off overnight and plug back. If power does not resume, depress the menu/ temp /set for setting temperature while plugging on the fridge.
It can be also that the microprocessor has hung up or has some other issue.
So hope this works.
Posted on Aug 28, 2010
  • 2,272 Answers
  1. Bottom Mount Refrigerator Ice Maker. When the bottom mount refrigerator is placed in Sabbath mode the ice maker will be automatically disabled. Please be aware however, that although you have entered the Sabbath mode, the icemaker will complete the cycle it had already initiated. The ice cube compartment will remain cold, and new ice cubes can then be made manually in the freezer section (using a standard ice cube tray) as needed for that Sabbath/Holiday.
  2. Sabbath Mode and the Perfect Temp Drawer (if equipped). The Perfect Temperature Drawer should be turned off for the Sabbath/Holidays. Before putting the refrigerator into the Sabbath mode, turn the Perfect Temp Drawer off by pressing the drawer on / off button. The display will show "OFF" and the drawer will turn off. Then enter the Sabbath mode function on the main refrigerator display. The drawer display will now not illuminate and the drawer will remain off until Sabbath mode is exited and the drawer is turned back on. The drawer can still be used as a non temperature controlled drawer in this mode.
  3. Press the display button few seconds and recheck.
---------- Check out thanks.
Posted on Aug 27, 2010
Display panel on Electrolux wave touch French door refrigerator will not adjust temperature. Ice or water won't' dispense either.
Hello friend, thank you for your post!
Based off the information you are describing it sounds like your control panel is locked. Can you check to see if the control lock is lit up? If so, please hold down the control lock button for 3 seconds and it should allow you to operate the front panel. If not you could be experiencing a problem within your control panel and may need to have a professional come out to diagnose it. I hope this helps. -Matt
Sep 10, 2014 | Electrolux EI23BC56IS (226 cu ft) Bottom...
Side by side ice maker won't stop letting ice out of dispencer unles you open freezer door
It sounds like a sticking actuator switch. the door light switch shuts off the auger motor when you open the door.
Aug 15, 2014 | Refrigerators
Electrolux Ref. 3yrs old. ice maker will not make ice, water dispencer will work. I have replaced filter.Ice maker goes through the motion but, no water. can you help me?
either your fill tube is clogged or the water valve in the back of the refer has failed. Go to the back of the unit, if my memory is correct the yellow hose is for the ice maker, at the water valve disconnect the 1/4 hose from the valve to the ice maker only, place valve in a bowl, cycle ice maker. If you get water, fill tube is obstructed, if not water the valve has failed and needs to be replaced.
Good Luck
Oct 28, 2013 | Electrolux EI28BS56IS (278 cu ft) Bottom...
Maytag refrig (french door) water and ice on door stopped working at the same time.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
French door refrig..right door pops open when left door is closed
i would check the door closure, uderthe refrig door , sort of a "cam" style washer the wants to have the door close.. part number 67003638. $5 for the part
Nov 28, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Fridge on top of freezer is not chilling
if you have a french door (also known as bottom mount, freezer on bottom) and your fridge sections(cold air blows from freezer to refrig) is not cooling try this
1. ensure you hear the fan running, its it not, thats it(most likely fan motor
IF fan is running check these things
1. ensure refrig section light shuts off by holding down the switch
2. ensure door shuts
3. clean conderser coils (usually accessed from front through base grille)
4. check for icing in vents, freezer section contain them at top or back, and for a bottom mount the refrig sections vents are under your BIG drawer. if iced try a hair dryer from distance. or empty food into another fridge unplug open doors, and plug back in two days later this should defrost all ice build up
May 02, 2008 | Refrigerators
Maytag mfd2561 water dispencer and ice maker issues
ther first refrig id have to see for better idea of problem but hte second with the flaps open and closing is going to need a high voltage board part num(12920710)---thats the part number i get wehn i look it up with the model MFI2568AEW. dont know where you got 12002608(that to is a h.v. board. which ever itssan easy enough repair to do yourself, its mounted on the rear of refrig and comes with programming instructions in the box
Mar 12, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Refrigerator
it has a bad main control board call maytag they will most likely repair it in warranty for you
Dec 09, 2007 | Maytag MFD2560HES Bottom Freezer French...
Maytag MFD2561HES
Texas, sounds like your water reservoir is frozen up. Remove your 2 cripser drawers, you will see the reservoir behind them. Take a hair dryer and go over the tank and tubing ends. See if the water starts flowing. I find a lot of frozen water reservoirs on these french door models. They have a insulation kit for them. Catriver.
Sep 29, 2007 | Maytag MFD2561HE Stainless Steel Bottom...
Most likely it is the High Voltage Control board located in the unit compartment (take off the back cover where the water lines are) i have had lots of them failing and doing all kinds of odd things, so far it has been that computer. Part number 12002608
Refrigerators Logo
261 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
