Question about Brother MFC-9840CDW Laser Printer
I have opened the back door for the envelopes to exit out of, but the printer is now telling me it won't print until I close the back door.
  • 1 more comment
  • rachel466 Aug 27, 2010
    No.
    no.
    I do not see a piece of plastic. Could you send me a picture?
    Brigadier General:
  • 3,513 Answers
Hi
This is how you should be doing it. Drop down back door. Pull down grey levers underneath the two green levers. Set them for envelopes. Go into printer settings, change to multipurpose tray, and comp ten setting for envelopes. This should work. If not then please reset the printer to factory settings.
http://www.fixya.com/support/p643806-brother_mfc_9840cdw_laser_printer/manual-33406
Let us know if you have something more to ask else please accept the solution.
Thanks for contacting fixya.com
Posted on Aug 27, 2010
  • 10,515 Answers
Did you have any paper jam prior to it?
Thanks!!
  • taran_2005
    taran_2005 Aug 27, 2010
    Thanks for your response!!
    I have ONLY JUST managed to fix three of these extremely simply after months of having this fault keep coming up.
    * Open the back cover
    * Pull the flap down that hides the orange roller on the fuser
    (Careful it's Hot on that fuser!!)
    * Locate the thin piece of plastic that runs from the centre to the right hand side. This bar is the problem
    * 3/4 along the right hand side, there is a sticky out bit on this bar that should sit in a hole.
    * I have found three printers where this was not located properly. Once I located it properly, the 'door open' error went away.
    Let me know,if needed further assistance.
    Hope i helped you.
    Thanks for using ' Fixya ' and have a nice day!!
  • taran_2005
    I could try, if i could get an image.
    I can only describe it as a long thin piece of plastic that runs from the center of the fuser to the right side.
    On that bar is a lever which hits the paper as it feeds through to tell the printer paper is present. If that is broken or dislodged then you will get a solid jam or door error.
    Hope i helped you.
CLP-320N KEEPS TELLING ME TO CLOSE DOOR...ALL THE DOORS ARE CLOSED
Most likely you should check the 'door open switch', probably its broken.
Apr 24, 2014 | Samsung CLP-315W Laser Color Printer
HP Color LaserJet CM2320nf MFP Envelope wrinkles
On alot of printers when you print envelopes theres a back door on the printer to prevent the curling or wrinkles. Just open the back door when doing envelopes.
Best of luck and have a happy and safe 4th of July weekend!
Jul 02, 2010 | HP Office Equipment & Supplies
HOW DO I PRINT AN ENVELOPE ON THE IMAGE RUNNER 3025
On right sideway of machine is door, on this door is bypass tray wich you need to open.Open and place envelopes on it, use paper side guidances, envelope must be print side face down.
"Tell" the machine wich is format, type and confirm.
Under printer driver set according settings.
May 14, 2010 | Canon ImageRunner 3025 Black and White...
Wrinkled envelopes Brother mfc 9840cdw
Instead of moving the whole green lever to adjust that grey arrow to the envelope symbol, simply push the gray part that has the arrow on it. This will move the gray piece down to the env. symbol and will not move the green lever so you can close the back door. I used to have severly wrinkled envelopes. Now they print out perfect.
Sep 25, 2009 | Brother MFC-9840CDW Laser Printer
Brother MFC-9840CDW wrinkles envelopes. Brother says this is "normal", and that the only way to 'fix' it is to open the back of the printer EVERY TIME YOU PRINT AN ENVELOPE and make some kind of...
Problem Solved!
I have a Brother MFC-8480 DN all in one printer, copier, fax and scanner.
I discovered that envelopes wrinkle because users, like me, didn't know that Brothers built in a no-wrinkle, pass through exit for envelopes, labels and thick paper.
Envelopes were never to be printed by inserting them in the front and letting them wrap around a HOT roller and get cooked and wrinkled. The way it works:
An envelope is inserted in the front and goes straight out the back of the printer through an exit door, completely avoiding the hot roll-through mechanism.
Take a look. On the back of the machine is a large pass through exit door. Just snap it open. You will see one blue lever on each side of the opening. Snap them both straight down to the . . .ta da. . ."envelope icons".
Put three envelopes in the front and they will print straight out the back, perfect and wrinkle free. After printing your envelopes, snap the blue levers back up and shut the door. Takes about five seconds to open the door and snap down the blue levers down/up.
Happy envelope printing.
-Eric
Jul 11, 2009 | Brother MFC-9840CDW Laser Printer
When we try to print envelopes. It grabs the
Open the door on the back above the power cord. Rotate both blue levers all the way up so they change from "1" to "2". Wrinkle problem will be solved. This was in the troubleshooting section of the online user manual, page 95. You would think they would tell you about this in the envelope section of the manual.
Jul 01, 2009 | Brother HL-5240 Laser Printer
HP 712C Printer won't print envelopes
hi dear
Choose envelopes that are close to 20-lb paper in weight and thickness. Also, make sure that the adhesive on the envelope is capable of withstanding the heat that the fuser puts out to keep the printing on the page. If you don’t, the envelopes will come out of the printer already sealed. If envelopes are coming out of the printer wrinkled, they may be too stiff for the paper path. Open the rear of the printer and let them exit at that location instead.
oke
cropp
Mar 19, 2008 | HP DeskJet 712c InkJet Printer
Envelope printing
You need to insert the envelope in the manual feed area and open the exit door at the back this allows the envelope to go straight through the printer hopefully limiting creasing. Check the envelope settings in windows make sure that you are using the correct size and feed selection.
Thanks J
Feb 03, 2008 | Brother HL-2040 Laser Printer
Brother MFC-9840CDW Laser Printer Logo
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
