Question about Microsoft Xbox 360 Console
My powerbrick light is red all the time,does it mean i need a new one
  • 864 Answers
It could and maybe not first diagnose the problem with what i oultine below. To see if anything fits into the category of your problem. Then try to hook up the power brick to another outlet in another room. If it does it there you can narrow down the cause of the problem.
THE CAUSE This problem occurs when the power supply detects a problem. The power supply has several built-in safeguards to help prevent damage to either the console or to the power supply. The power supply will turn off if: There is too much current. The voltage is too high. The temperature of the power supply is too high. When any of these things happen, the light on the power turns red. THINGS TO TRY Here are some things you can do to try and fix the problem.
Solution 1: Make sure that the power supply is cool The red light might indicate that the power supply is too hot or that it has overheated. Follow these steps if the power supply light is red: Turn the console off. Disconnect your Xbox 360 Power Supply from your Xbox 360 console and from the wall outlet.
Let the power supply cool for two hours in a well-ventilated space. Do not connect the Xbox 360 power supply to the console or to the wall outlet during this time. After the power supply has cooled for two hours, reconnect the power supply to the console and to the wall outlet, and then turn the console on. If the power supply light is still red, try the next solution. Solution 2: Make sure that the power supply is plugged in Make sure that the power supply is directly plugged into a working wall outlet. Problems might occur with the power supply if it is connected through an extension cord or surge protector.
If the power supply light is still red after you connect the power supply directly to a working all outlet, try the next solution. Solution 3: Plug the power supply into a different wall outlet To check the possibility that the wall outlet you are using is faulty or that there is a blown fuse, plug the power cord into a wall outlet that you know is working.
If this does not solve the problem, try the next solution. Solution 4: Order a replacement Xbox 360 power supply If you've tried all the solutions above and your power supply light is still red, you should contact Xbox Support to order a replacement power supply.
MORE INFORMATION To help the power supply work correctly, follow these guidelines: Do not block any ventilation openings in the power supply. Do not put the power supply on a bed, a sofa, or on any other soft surface that might block ventilation openings. Do not put the power supply in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well ventilated. Do not put the power supply on a stereo speaker, an amplifier, or a heat source such as a radiator or a heat register. Do not use an unlicensed accessory, such as a third-party power supply or any accessory that plugs in between the Xbox 360 console and the power supply. Plug the power supply directly into a working wall outlet. The power supply might not work correctly if it is connected to an extension cord or surge protector
if you need an explanation or further assistance please let me know. I will be glad to help, Thanks -Midwest-tek
Posted on Aug 27, 2010
I HAVE AN OCTOBER 2008 XBOX AND A 150W 12.1 AMP POWERBRICK FROM A NEWISH XBOX . PLUG ON POWERBRICK WILL NOT FIT SOCKET ON XBOX
The power cords for the Xbox 360 and the Xbox 360 slim have different shaped plugs. If the plug you are using is not fitting it is likely that you have purchased the incorrect cord. If this is the case you will need to purchase a new cord.
When you purchase your new power cord make sure that it is designed for the original Xbox 360 NOT the Xbox 360 slim.
Jun 13, 2011 | Microsoft Xbox 360 Console
When i turn my xbox 360 onto stanby the powerbrick light is on orange,but when i turn my xbox console on i get 3 red rings and my powerbrick light is on red?
Hello there
From what you have said it sounds like you have the RROD - 3 LIGHTS
The main causes are Hardware failure, overheating or wear & tear.
You may need to perform simple maintenance, clean or in some cases adjust settings.
To get the best advice on where to start I recommend a GOOD REPAIR GUIDE, From this you can fix the problem at home and avoid any large repair bills. Its easier than it sounds when you have help from the guide.
I used Gamer Fix to get the best guides
The other solution would be to send the console off to its manufacturer, This is free if your still in warranty. If your console is out of warranty then the usual price of repair is $150
I am Glad I could help and You can help others by rating this Post or leaving a comment.
Many thanks
Peter Fix
Dec 24, 2010 | Microsoft Xbox 360 Console
My xbox 360 wont turn on and the orange light on the powerbar isnt on either
move it to a new outlet if that dont work your powerbrick might be fried you can get them perty cheap just dont buy the used you might get one that is defetive
Dec 01, 2010 | Microsoft Xbox 360 Console
What is wrong when the red light is on in your xbox 360
Either
1) Overheating,
2) Problems in GPU,
3) Problems in powerbrick.
Nov 11, 2010 | Microsoft Xbox 360 Console
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
Nov 21, 2009 | Kodak EasyShare M863 Digital Camera
I get a red light on my powerpack
i think that means that the connection between the power brick and the xbox isnt working, either your xbox needs repair or you need a new power brick, ask a friend with a 360 if you can borrow theirs and also their wires for the powerbrick and if it works then YOU need a new powerbrick and if it doesnt then your xbox is broken
Jun 14, 2009 | Microsoft Xbox 360 Console
360 powerblock works when not pluged but dosnt when is plugged
It is the power brick. If you are under warranty you can have microsoft send you a new one for free, otherwise a new powerbrick is around 80 dollars.
Feb 06, 2009 | Microsoft Xbox 360 Console
Apple 23" cinema display
thats supposed to mean theres a faulty powerbrick, however i have the same problem on mine and replacing that didn't solve it
Oct 28, 2008 | Apple Cinema Display 23" HD Monitor
No power!
Duke, take a look at the big 'powerbrick' that powers your xbox, on the front of it there will be a small LED, it should be red/orange if your xbox is turned off. If you see NO LED light then your powerbrick is no longer functioning.
If you DO see a LED, then its likley the Xbox is at fault.
Hope this helps!
Dec 26, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
205 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
