Question about Intel Computers & Internet
I have a "p4 processor with 3.06ghz speed";i recently having problem of overheating and my temperature is rising to 100degree when CPU utilization is 100%.. .This all happened when i took out my heat-sink for cleaning..but i brought a 200rs cooler master thermal paste and my temperature is now controlled i.e. it is not overheating but still my processor temperature goes to 100 degree ,my motherboard is "d102ggc2 "PLEASE I NEED A URGENT HELP
    Sergeant:
    Champion:
  • 389 Answers
You should make sure that the heatsink and fan are clean and dust free, then you should clean all the thermal paste off with som alcohol(preferably 90% pure isopropyl alcohol)but 75 will work too make sure the top of the processor is clean also,then reapply the thermal paste.that should help,but if temps still run high then you should look for a better cooler.
Posted on Sep 02, 2010
Overheating issues with laptop
Following are the reasons for overheating, just take care of these things::
Stop Overclocking your CPU
Make sure your Heat Sink is placed properly above the processor
Clean the Processor fan, Heat Sink and other peripherals
Use High Speed fans
Use CPU Heat Sink Paste in the processor
Make sure your dint restrict the speed of CPU fan.
Use proper ventilation in your room
Shut down your computer at least two hour a day
If it didn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of overheating
Sep 23, 2013 | Toshiba Satellite Computers & Internet
Sony VAIO VGC-RA810G Desktop overheats and freezes.
- Clean the Processor fan, Heat Sink and other peripherals
- Use High Speed fans
- Use CPU Heat Sink Paste in the processor
- Stop Overclocking your CPU
- Make sure your Heat Sink is placed properly above the processor
- Make sure your dint restrict the speed of CPU fan.
- Use Additional Cooling Units
- Shut down your computer at least two hour a day
Finally i will suggest you to get system utility program like PC Fresher. because it is a very useful tool that cleans your computer of temp files, history and cookies. Its also used to fix any registry errors that cause of overheating
Sep 16, 2013 | Sony VAIO PC Desktop
Fan dose not slow down
It seems that your system is overheating so follow these instructions first
- Shut down your computer atleast two hour a day
If you are unable to perform above tasks then use a single utility tool like PC Fresher that will fix windows errors that cause of overheating
Aug 27, 2013 | HP TouchSmart Computers & Internet
Overheating intel 915 2.8ghz processor 50degrees
The overheating problem (ie. thermal shutdown) is most likely caused by a faulty CPU fan or dust clogging the CPU fan and heatsink.
Check the BIOS CPU fan speed could be set too low, check the fan speed/temperature setting.
If this problem is not fixed, then the CPU will eventually fail.
Check the fan to see if it spins freely, if not then replace the faulty fan.
If the fan and heatsink are cligged with dust, loosen and remove the dust and use a can of compress air to blow away the dust.
Sep 22, 2010 | Intel Pentium D 915, 2.8 GHz (BX80553915)...
Intel D865GBF hangs for error thermal event
The solution to your problem can be found at this webpage : http://www.intel.com/support/motherboards/desktop/sb/CS-012552.htm.
It guides you on how to solve overheating problems. Personally I think you need to unseat your processors and refix after cleaning and applying a fresh coat of the Heat Conducting Paste and re-seat it very, very carefully. Gently in the beginning and once u are sure that it has got into its slot smoothly then press harder until u hear two cliks, like a double lock. Fix the Heat sink &see that the retaining clips are snug tight. Try it & post the results........sodeep
Quote "High Temperature Alerts
If Intel Active Monitor or Intel Desktop Utilities alerts you about temperatures above set thresholds, there are a number of steps you can take.
Check for proper airflow:
  • Make sure the processor and chassis fans are running.
  • Check the cabling; make sure cables are not interfering with proper airflow through the chassis.
  • Check that nothing is blocking airflow into and out of the chassis' airflow vents. This is common in direct airflow systems (BTX). Chassis manufacturers may apply a dust filter in front of the CPU fan inlet. Check that the filter is clear and free of dust buildup.
  • Make sure that the air intakes for the external fans are unobstructed and are located at least several inches away from walls and other items.
  • Make sure that the power supply fan is running properly and any other external case fans are running properly.
  • Consider adding another chassis fan.
Other troubleshooting steps:
  • If your PC uses an Intel® Pentium® 4 processor in the LGA775 package, be sure the heatsink is properly installed and 'locked'. Pay particular attention to the proper orientation of the locking pins and give a good push down on the pins (sounds like a double click) to lock them into place. For complete processor and heatsink integration information, refer to Boxed Processor Installation.
  • Verify the chassis/case and power supply are appropriate for the processor model and frequency and the motherboard you are using.
  • Verify the thermal solution for the processor is adequate for the processor and frequency of the processor.
  • Make sure the processor fan cable is connected to the correct fan header (specifically for the processor). Refer to your motherboard documentation for more information.
  • Make sure that the thermal interface material or the thermal grease is applied to the processor properly.
  • Update the system BIOS to the newest version. This will often correct problems with how the system measures temperature.
Fan Control Behavior Changes after BIOS Updates
After updating to the latest BIOS version on certain Intel Desktop Boards, the CPU fan may not go to full speed operation until the processor reaches about 72°C (162°F) and all system fans go to full speed at 75°C (167°F). You may see temperature alerts in Intel Desktop Utilities.
Previously, certain processors' thermal values were not available to the BIOS so the BIOS was unable to perform the appropriate fan control (the fans ran at 100% constantly). With recent BIOS updates, the thermal values are available and the BIOS will run the appropriate fan control. This means the processor may reach temperatures of up to 75°C (167°F) before the fan will go to full speed. The fan control now allows processor temperatures to rise to optimal levels while the slower fan speeds improve acoustics.
Setting Temperature Thresholds in Intel® Active Monitor or Intel® Desktop Utilities
By default, the temperature thresholds in the hardware monitoring software are set as follows: Zone Intel® Active Monitor
Intel® Desktop Utilities (ver. 2.0.11.46 and earlier)
Intel® Desktop Utilities (ver. 2.1.8.63 and later) Processor 75°C
(167°F)
75°C
(167°F)
75°C
(167°F)
Zone 1, Zone 2, or Motherboard Zone 50°C
(122°F)
50°C
(122°F)
65°C
(149°F)
If you've checked for proper airflow and performed the other troubleshooting steps listed above and you still consistently receive high temperature alerts in any of the temperature zones:
  • If you are using Intel Active Monitor, you may increase the temperature threshold. You can safely increase the Zone 1, Zone 2 or Motherboard Zone threshold up to 60 Degrees Celsius (140 Degrees Fahrenheit).
  • If you are using Intel Desktop Utilities version 2.0.11.46 or earlier, upgrade the software to the latest version, which sets the zone default thresholds to 65°C.
  • It is not recommended that you increase the Processor Zone threshold.
Downloading these utilities:
Intel Desktop Utilities".........unquote"
Feb 19, 2009 | Intel D865PERL Motherboard
Toshiba a30-931 what is largest posible cpu
Franky_J knows nothing you could go for a P4 2.8 cpu which would work much better than the Celeron in fack any P4 over 2.0 would out perform the celeron if you want speed get rid of the Celeron and get a P4 it should take up to an 3.2 P4 chip.
Franky if you dont understand cpu's then you shouldn't really be answering this question in the cpu world a 2.8 ghz cpu is not always a 2.8ghz cpu for instance this one has half the cash of a P4 cpu meaning it can only do half the work at the same time so in P4 terms this is only a 1.8 P4 equivilent so a 2.8 P4 will be a big improvement.
Nov 25, 2008 | Toshiba Pentium 4, 2.88 GHz (P000382340)...
Intel P4 3.06GHZ 533FSB !OVERHEATING PROBLEM!
First of all. Pentiums are infamus for this, they overclock them to get faster CPU's and they dont get the right heatsinks for them and they over heat.
Do you have system fans?
You should have as many pushing air in as you do out to keep a constant displacement of heat.
Second of all, Go into your bios and see if itt has an option for a temperature Alarm for the cpu. If it does, turn it on.
If the Alarm is going off after running it for a while then you have a problem, the machine will shut off to protect the system.
IF its not going off then you may not be having any problems and your just fretting. Mine runs at about 50*C and is constant and never has problems with heating for 5 yeears now.
You tend to want the out fans at the top and the intake fans at the lower part of the case because heat rises up and is more easily displaced that way.
Good luck.
Apr 13, 2008 | Intel P4 3.06GHZ 533FSB 478PIN PPGA...
MB Asus P4T
By this, it appears you suspect your cpu is overheating.
If the computer hangs or crashes resets itself.
then it should,nt be an issue.
If you are concerned, you could check the fan is working correctly. ( these tend to get clogged with dust )
Secondly, you could remove the CPU Heatsink. And check The Thermal-tape Or Compound. Use A good quality thermal paste such as arctic Silver.
Hope This Helps.
Feb 17, 2008 | ASUS Intel 850 Chipset P4T-E (P4T-E/WOA)...
Rise in cpu temperature
You need more air movement through your case. Add bigger case fans (front and back) and a better CPU fan
Jan 08, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Computers & Internet Logo
129 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
