Question about Freezers
I have a commercial reach in Turbo Air 2 door freezer that is 1 year and 2 months old. The compressor is going out.....Why would it happen?
  • Dennis Boxerman Aug 29, 2010
    what do you mean "going out?". does it not stay running or what?
  • Patty Oakley Aug 29, 2010
    I was told by a repairman that the points are going out on it..... He wanted $456 for labor only....parts are covered under warranty
  • Freezers Master
  • 1,250 Answers
I've never heard of "Points going out" and I've been doing commercial refrigeration since '85. I can only guess that he is referring to either the potential relay or the current relay. In either case, the part costs about 30 bucks and takes about 30 minutes to install. I'd look for a second opinion for sure.
Posted on Sep 02, 2010
My artic freezer f22cwf4 compressor is not turning on. I have replaced the thermostat and all the fans are working. The unit is only 6 years old.
Not an expert opinion but seems that either you have low refrigerant and maybe the compressor is not therefore starting or the compressor has an issue, or the power to the compressor is missing.
Oct 16, 2014 | Artic Air Used F22CWF4 White Commercial...
Hi - We've got a Turbo Air TGF-23F mrechandising freezer that freezes - down to -15 and then suddently begins to warm up about 1 degree per minute. In about 15 minutes its just over 0 degrees and...
Did they test the thermostat? I would think that the compressor would kick on before you got that much of a fluctuation, unless the thermostat is not sensing the change fast enough.
The run and start capactiors and relay, did they give you a reason for that? When the compressor kicks on does it surge the power? Light dim or something? It is hard to guess without being able to put an o'scope on your machine to be able to see what it is doing, but just based on what your write-up was, I can't see the parts you said they want to replace will fix the problem.
Jun 08, 2011 | Turbo Air Freezer 23 cu ft Single Glass...
Hi, I have a Turboair Problem with the Turbo Air
Tried to find the code "CO" in service manual but to no avail and please furnish the proper model number as none you list appeal. You stated that the unit sat for 5 months so I am wondering if your unit has developed a restriction in the capillary tube as this unit uses R 134A which has this problem.
Nov 30, 2010 | Turbo Air 49 cu. ft. / 1388 liter...
Turbo air frz goes into defrost compressor continous to run. Does not stop during defrot
Hi, Please set your thermostat a bit warm and observe the compressor. Also check your freezer for leaking.
Nov 06, 2010 | Turbo Air 49 cu. ft. / 1388 liter...
Fan runs but the compressor does not run no
While moving the unit you may have jammed or budged the start capacitor which is keeping your unit from turning on. It is located in the back of the unit near the compressor it is oval shaped and silver in color with two wires running out of it. Get the number off of it, go online and search for beverage-air commercial freezer parts. You will need to have the model number to make sure that you get the right parts. Please rate
Jun 03, 2010 | Beverage-Air 11.8 cu. ft. / 334 liter...
Temp. can not reach 0 degree.
things that need checking:
refrigerant level. Super heat. Condenser clean? Compressor effeciency.
These are things that an experienced tech can check. If you have some experience and gages/ tools, I can give you some things to do but most of this requires experience.
Let me know if I can be of any further help.
May 30, 2010 | Turbo Air 49 cu. ft. / 1388 liter...
Where can I order extra shelves and support clips for GST 40GF
Call Rick at Restaurant Parts and More in Ohio. Give him the model and serial numbers and he can match what you need. FYI, most Turbo Air freezers are also Masterbilt. Turbo Air does the private lable thing for Master bilt.
Hope this helps.
Mar 11, 2010 | Turbo Air Freezer Green World by Bottom...
I wondered how long the defrost cycle was supposed to run on this Turbo Air TGF 49F freezer as I am not sure if a door was left ajar or if it is stuck on defrost if possible. I would like to manually over...
If it's frosted up, it's best to defrost manually with heat gun. Find the timer and advance until it goes back into defrost. The timer looks like a residential fridge. It cut the compressor off and the heaters on.
Please rate solution
Sep 06, 2009 | Turbo Air 49 cu. ft. / 1388 liter...
Freezers Logo
63 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
