Question about Estate TEDS740JQ Electric Dryer
How do you change the belt - Estate TEDS740JQ Electric Dryer
  • 5,911 Answers
If the model number you listed this question under is correct, changing the drive belt involves the following steps:
1. UNPLUG the dryer and remove the lint screen.
2. Remove the two screws that were under the lint screen and lift the top panel.
3. Unplug the door switch connector plug and any ground wire that may be installed on the casing.
4. Locate the two screws that hold the front panel in place. There should be one screw on each side in the cabinet interior.
5. With the door shut, lean against the front panel and remove the two screws that hold it in place. Once the screws are removed, grasp the front panel at the top center and lift straight up to remove.
You should now have complete access to the dryer interior. Release the belt tension, by pushing the idler pulley (tensioner) to the right (away from the belt) and remove the old belt from around the drum.
If the belt has broken, this may sometimes cause the idler pulley (tensioner) to come loose. This is normal with no tension on the pulley to hold it in place. To install a new belt and re-install the pulley, follow these steps:
1. Loop the drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
2. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
3. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and push the wheel to the RIGHT while pulling the belt over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for WHIRLPOOL and refer to diagram H (This model is manufactured by Whirlpool).
Replacement parts (if required) can be ordered on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The part number for a replacement belt is 341241. All these sites offer great service with competitive pricing, so shop and compare. The first three sites I have listed also include helpful exploded view diagrams that can help you locate and properly identify the parts you may need. you can view a diagram of the belt and tensioner under the "Cabinet Parts" section.
NOTE: If you still have the Teflon glide type tensioner, Whirlpool recommends you replace it with a conventional roller type idler pulley. The Teflon type tensioners caused premature wear to the drive belt. The part number is 691366.
Once you have the belt installed, re-install the dryer front panel by holding it as you did previously. Line up the holes on the inside bottom edge of the front panel with the small mounting cleats on the front edge of the side panels. This can be done by yourself, but an assistant may make it easier. Once you have the front panel in place, lean against it to hold it in place and install the mounting screws.
NOTE: Don't forget to reconnect the grounding wire and door switch connector plug. Without the door switch connected, the dryer will not run.
Lower the top panel back in place and reinstall the two screws.
NOTE: Placing a piece of duct tape over the dryer vent chute will help safeguard against dropping anything down in the blower fan assembly. If you drop any screws down the chute, you will need to remove the dryer back panel to retrieve them. If you have any questions about this repair, please post back and let me know. I hope this helps you.
Posted on Aug 27, 2010
How to change a belt on sewing machine
Google is your fried in such cases Mary :>) I can probably find you your manual if you give me the model number.
  • How to Replace a Sewing Machine Drive Belt - YouTube www.youtube.com/watch?v=8Voq7f5vT6E
    • BY SEARS PARTSDIRECT
    • 1 MIN
    • 23K VIEWS
    2015-04-23 · Video embedded · ... shows how to replace a broken drive belt in a sewing ... a broken drive belt in a sewing machine. ... to Replace a Sewing Machine Drive Belt
  • Brother Sewing Machine Diagram to Replace Belt ? ' Yahoo ... https://answers.yahoo.com/question/index?qid=20090426184749AAQ5W2y
    • RESOLVED
    • 4 POSTS
    • 3 TOTAL ANSWERS
    2009-04-26 · Best Answer: I am sure there are the diagrams you are looking for are online. ... After years of machine maintenance I would love to have a duplicate ...
  • Videos of how to change brother sewing machine belt bing.com/videos 2q==Click to view 43:10HD Brother PE770 repairs, motor belt.(Spanish Discription) YouTube zClick to view 1:00HD How to Replace a Sewing Machine Drive Belt YouTube 9k=Click to view 1:03:43 SINGER 95-1 BELT REPLACEMENT & RE-TIMING 081813 YouTube 2q==Click to view 1:42 How To Install Antique Singer Sewing Machine Belts YouTube See more videos of how to change brother sewing machine belt
  • Brother PE770 repairs, motor belt.(Spanish Discription ... www.youtube.com/watch?v=Cy-wNw8_kuU
    • BY VINCE J. ARCURI
    • 43 MIN
    • 25K VIEWS
    2013-05-19 · Video embedded · Brother PE770 repairs, motor belt. ... In this video I am showing how to access the machine's motor drive belt. ... Brother Sewing Machine ...
  • Can U Help Me Find A Diagram to Replace Sewing Machine ... https://answers.yahoo.com/question/index?qid=20090428210336AAvwslh
    • RESOLVED
    • 4 POSTS
    • 3 TOTAL ANSWERS
    2009-04-28 · Can U Help Me Find A Diagram to Replace Sewing Machine Belt ? ... I can get a Diagram that can show me how to replace a belt on a Brother Sewing Machine ...
  • Replace Belt ' Brother support.brother.com/g/b/faqend.aspx?c=eu_ot&lang=en&prod=mfcl8850... Replace Belt. Follow the steps ... Close the front cover of the machine. Reset the belt unit counter. Press (Settings). ... please contact Brother customer service:
  • How to Replace a Sewing Machine Belt ' eHow www.ehow.com > Crafts > Sewing & Textile Crafts > Sewing
    • BY RUTH O'NEIL
    How to Replace a Sewing Machine Belt ... When you smell this, you know it is time to change the belt. Changing a sewing machine belt is fairly easy; ...
  • Sewing Machine Belt Sizing - Sewing Parts Online ... www.sewingpartsonline.com > Home > Maintenance & Repair Home Maintenance & Repair Sewing Machine Belt Sizing. ... How to Replace Sewing Machine Gears December 5, 2010. How To Replace A Sewing Machine Motor May ...
  • Brother Sewing Machines and Accessories: Rubber Drive Belt https://www.brothermachines.com/sewing/491/Rubber_Drive_Belt Brother sewing machines, parts and accessories ... Brother Emb. Cards; ... Home Sewing Machine Rubber Drive Belt
  • Sewing Machine Belt - Sew-Classic shop.sew-classic.com/Belts_c3.htm Click here to download for FREE How to determine the correct belt size and how to adjust/install a sewing machine belt. ... Sewing machine motor belt ... Brother Elna ...
  • Sewing Machine Repair Tips: Change / Replace The Belt on a ... sewingmachinerepair.blogspot.com/2008/01/change-replace-belt-on... 2008-01-27 · Although it may initially look complicated to change the long leather belt on a ... brother sewing machines. April 27 ... cover over the belt on the sewing ...
  • http://www.bing.com/search?q=How+to+change+brother+sewing+machine+belt+&qs=n&form=QBRE&pq=how+to+change+brother+sewing+machine+belt+&sc=0-42&sp=-1&sk=&cvid=B1D6E61981414EB7A56CB3A4C0D371A3
    Jun 18, 2016 | Brother Sewing Machines
    1996 Mazda Protege with 100,000 miles. Should the serpitine belt be changed? What is approximate cost?
    Drive belts are replaced every 5 years
    Your thinking of timing belts 80,000 miles
    Mar 08, 2011 | Mazda Protege Cars & Trucks
    I bought used Optima 2004 with mileage around 120k, i'm worried about the timing belt. Should I change it now? When should we make second or third change after the 60k timing belt change.
    to be on the safe side id change the belt every 55,000 to 65;000 miles make sure u change the belt tensioner as well they fail more than the belt
    Feb 23, 2011 | 2004 Kia Optima
    What is Ford's recomendation (mileage) for replacing the serpentine belt on a 1998 Ford Explorer?
    Theres no mileage to change just to check it, the way to check the belt is to look at the inside of the belt and you will see grooves in which the belt rides, if you see cracks in the belt then its time tom replace. the belt should be looked at every oil change it thats no time to check. hope this is helpful.
    Jan 22, 2011 | 1998 Ford Explorer
    I have 151,000 miles on my 2002 4cyl Camry and have not changed the timeing or the sepeitine belt: Is it time to have it done?
    Hi:
    It is overdue time to change your timing belt and waterpump, as you are on borrowed time on the timing belt. The waterpump and tensioner should be changed along with the timing belt, as they can ruin a new timing belt if they fail. Your serpentine belt should be inspected and replaced if needed too.
    Mar 24, 2010 | 2002 Toyota Camry
    Peugeot Expert Van Cambelt change
    Most cam belts need to be changed every 60,000 miles. I would change again somewhere around 126,000.
    Oct 28, 2009 | 1991 Peugeot 405
    When to change timing belt on 2004 honda civic
    Honda reccomends timing belt change at 100k. Most Honda dealers like you to change the belt at 90,000 miles (90k). some auto repair places will want to change the belt at 60k but that is not necessary (Note: if in a severe cold or hot climate like florida or canada you would change the belt before 90k or if the belt is over 7 years old.. Good luck:
    Oct 01, 2009 | 2004 Honda Civic
    Timing belt
    Timing belts are suppose to be changed every 60,000 miles.
    Aug 02, 2008 | 2004 Kia Sorento
    Estate TEDS740JQ Electric Dryer Logo
    42 people viewed this question
    Top Estate Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Terry Schneider
    Are you an Estate Dryer Expert? Answer questions, earn points and help others
