Question about Jenn-Air Refrigerators
I have a Jen air jJRSD 2490 T. My refrigerator side is set at a very low setting and it freezes everything almost solid whether it is on the self or in a drawer. The freezer side freezes normaly. can this be repaired or does it need to be replaced.
  • 944 Answers
This problem can be occur due to various reasons
1)Defrost Thermostat
2)defrost timer
3)Dust in condenser coil
http://romulusappliance.com/manufacturers/maytag/refrigerators/parts.htm
1)Defrost thermostat
I have a Jen air - efabbcb.jpg Defrost Thermostat.It may be located under the floor of the unit, or it could be found at the back of the freezer. If you have a side-by-side refrigerator, the defrost thermostat is found at the back of the freezer side.
This could be a defective one.You have to replace it.
2)Mechanical defrost timer.
If your refrigerator has a mechanical timer, set the cold control to the coldest setting and then advance the defrost timer. You can manually advance the timer with a screwdriver. Insert the screwdriver into the advancement pinion and turn clockwise a 1/4 to 3/8’s of a turn.
3)You can use a condenser coil brush to clean the coils.
Because the coils exchange heat, any dust, lint, or dirt on them cuts down its ability to exchange heat.
post a comment for further assistance.
thank you for using fixya have a nice day:-)
Posted on Aug 27, 2010
I have a side by side jen air. The refrigerator side quit working altogether. The freezer side maintains a temp that the refigerator side usually runs at...
Check contol settings. Vacuume out bottom fridge coils carefully. Factory settings are the middle number on both controls. If all else fails turn the freezer control up a couple numbers.
Jan 28, 2011 | Jenn-Air Refrigerators
JCD2290HES Side by Side Refrigerator: my jenn air side by side is freezing everything an...
i have the same problem i clean the coils and work for two weeks and now is freezing need solution thanks
May 16, 2010 | Jenn-Air JCD2290HES Side by Side...
Warm refrigerator cold freezer GE side by side TFX24ZH
Check air passage between the freezer and refrig. compartment for a blockage (condensation freezing )
May 13, 2009 | Refrigerators
Jen-Air Refrigerator does not cool ---freezer works
you have a defrost problem, most common problem component for the jen air refrigerators is the defrost control board pt#61005988. until you change the board you will need to defrost your refrig  manually about once a week. the board is located in the control housing in the refrig compartment and is fairly easy to replace yourself.
Jan 22, 2009 | Refrigerators
My refrigerator freezes my food solid
There are vents that allow the cold air to flow from the freezer to the fridge. If those vents become clogged with ice or fail mechanically, they can become stuck open or closed. The temp adjustment should move the damper in the vents. But if they are frozen open, then the fridge will become too cold.
Thank you for contacting us.Please do rate fixya if you like the solution.
Dec 10, 2008 | Samsung RB2155 Bottom Freezer Refrigerator
Manuel - User's Guide
I'm not sure if this will help or not, but the manual number is 12828144A.
I recently purchased the same jen air model and have a problem with everything that is in the vegetable and fruit drawers freezing solid! Does you mother have the same issue?
Jul 24, 2008 | Jenn-Air Refrigerators
Refrigerators Logo
48 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
