Question about HP Officejet 7210 All-In-One InkJet Printer
Error: 0xc0620004411:lib_micci2c - HP Officejet 7210 All-In-One InkJet Printer
2 Suggested Answers
SOURCE: lcd screen is flashing error:
Please try the following steps:
Make sure unit is plug directly into a wall outlet and not connected to any power strips or surge suppressors
Note : Power strips and surge suppressors can sometimes prevent enough voltage from reaching the product.
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
  2. Remove the cartridges from the product.
  3. Wait for the ' Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Your printer should be back in a working condition after this. Let me know if this has been of any help. Thanks for using Fixya.
Posted on Sep 09, 2011
Linker error:Unable to open file 'TCLASSS.LIB'
this is the basic lib class required by the compiler make sure your libs variable to pointing to the correct location the the libraries required by the compiler.
Sep 25, 2012 | Borland Turbo C++ 3.0 Full Version...
Error:0xc0620004411:lib_micci2.c is flashing on the green window. Printer refuse to work.
Check inside the printer to see if any paper or object stuck up in there, there may be something something in there,take out whats in and start the printer.
Aug 16, 2010 | HP PSC 1610 All-In-One InkJet Printer
I need tv.lib file in c++ compiler
you can find your answer easily in http://www.codeproject.com/
Good luck
Feb 13, 2009 | Computers & Internet
Error Code 0xc0620004411:lib_micci2.c
reinstall your driver and also check usb connection cable.
Jan 03, 2009 | HP PSC 1610 All-In-One InkJet Printer
0XC0620004411:lib_micci2.c error on PSC1610
Try doing power drain.
By Isolating printer from power and computer.
Press and hold power button for 5 sec.
Then try turning on. without connecting to the computer.
Sep 04, 2008 | HP PSC 1610v All-in-One Printer
Same Problem Again - Mega Raid.... Unknown Error
Hi
The title of your post suggests that you have "Maga RAID" errors. Maga RAID messages would be in line with issues on the LSI PERC sub-system.
However, the extract posted in your suggests network problems.
Any number of physical to driver and configuration issues can result in network problems.
Try the basic checks;
1. Change or try a known patch cable
2. Run "ping" test to a known good system connected to same network switch or direct connect with a "cross-over" cable and check for dropped connections.
3. Is the NIC and switch set to Auto-Negotiation or static at 10, 100 or 1000Mbps speed
4. Can you try another switch
5. Check and load correct or latest manufacture's drivers
Reply with more info.
Mike
Jan 23, 2008 | Dell PowerEdge 1800 Server
Event ID 11
Please perform a erase operation and check if the drive does it, If its not then go ahead and check the SCSI controller if you have a spare one replace it.
Aug 22, 2007 | Sony AIT Library LIB 152E/A1 (LIB-152E/A1)...
Event ID 11 error
Wonderign if you tried to install this on the RAID controller....big nono and cause this very issue...try a different SCSI controller...hopefully you ahve one onboard NOT raid. hope that helps
Aug 17, 2007 | Sony AIT Library LIB 152E/A1 (LIB-152E/A1)...
HP Officejet 7210 All-In-One InkJet Printer Logo
80 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
