Question about Solis Master 5000 Espresso Machine
Grounds holder is stuck under the flat piece of the grinder. How can I free it up?
  • Solis Master
  • 1,711 Answers
Could you please let us know the model of your machine and also some more details of your problem and how did you have this problem it will help us to understand better and be mor especific with our answer to you,
We remain
Posted on Aug 27, 2010
Grinding problem
That is a good idea. Also one or both brushes brushes could be stuck in the holder. If stuck I would just replace the brushes so I could count on it working a long while.Give the brush holders a good cleaning if you decide to replace or not.
Aug 03, 2014 | Dewalt D28493N 9" 230mm Large Angle...
I cannot adjust the grinds its only cming out fine even if I turn the screw in the center
You should call your vendor for service.
*** The following is for information only. Service should be done by a qualified tech.***
* Check bunn.com for a free download of the G3 manual
* If turning the dial does not change the grind size then the inner burr spring is broken, stuck, of missing (it broke into small pieces to fall into someone's coffee grounds). Call vendor for service.
* If turning dial is very loose then the lock screw is loose. check setting then tighten down to lock into place. It's usually a small 1/4" hole on the side of the knob.
* The burr plate may be gummed up and stuck in place. Especially if oily beans or 'flavored' beans were ground in this machine often.
* It's possible the Grinder is WAY out of calibration. It's so far out of adjustment that the only setting is fine when the dial is set on course ground. This grinder was not assemble correctly. Check the parts diagram. Call your vendor for service.
Aloha, ukeboy57
Jan 18, 2014 | Bunn -o-Matic G3 (3 lb. Commercial Coffee...
Brushes are in the way of reassembling my grinder. most brushes have access from outside housing. my Hilti DEG 600-P DOESNT I need to remove them temporarily so I can reassemble my grinder the brushes...
Hello
Take a look at the brush holders and see if you spot a series of holes on the front of the holders.Push the brush back and pin the brush back with a piece of wire.There will be a way to pull the wire through a vent.You can do alternators on cars like this,just go to an alternator rebuilding shop.Brushes used to be under a dollar. Thanks for choosing FixYa.com.
May 15, 2011 | Garden
What do you do when the grinding blade will not come off for cleaning?
Hi
With the bean hopper on, turn the grinder upside down. Rotate the bean hopper to loosen any grounds that might be holding the burr holder. Now remove the bean hopper and try again to remove the holder. Only the outer burr comes off, this way.
Jul 19, 2010 | Solis Maestro G385 Electric Burr Grinder
Have Rancilio Rocky for about 3 months. Noticed grinds around base from time to time. Yesterday picked up machine, saw accumulation. Tapped base, more came out. Took off base, about 2 oz. of grinds inside....
Hi There could be a piece broken around the chute where it comes out of the grinder and enters the grounds chamber. There is a rectangular opening in the plastic that can get broken causing the grounds to enter the machine.
Feb 07, 2010 | Rancilio Rocky Doser Espresso Grinder...
Knocked out spent coffe grounds come out mushy not like a puck
Adjust the grind on the machine, or the amount of coffee the grinder puts into the chamber.
Jan 12, 2009 | Saeco VIA Venezia
My solis 5000 is making a grinding sound and I have tried to reset the machine with no succes
Sometimes the grinder has grounds "jamed" in the coffee grinder outlet. First, while grinding try turning the "quantity dial" (has + and - on dial inside coffee bean holder) back and forth to see if that breaks the coffee loose. Next, Use a small brush to clean the coffee grounds channel inside the machine. To do this, remove the brewing section, liquid tray, and spend grounds holder. On upper portion of machine, just above the area where the brewing unit is a small "trap door" where coffee grounds are delivered to the brewing unit. slip the "trap door" open (it's spring loaded so you will need to hold it open) and with a small brush gently brush the accumulated grounds out of the channel. (There may be a large accumulation of grounds if you are using dark roasted "oily" coffee. Good luck! hope this works for you
Jan 05, 2009 | Solis Master 5000 Espresso Machine
Can't disasseble burr set
take an oil filter remoover for cars(the model with 3 legs and gears will do better job). 2 man required one holding grinder other one start turning left and right the upper holder(during turning hold down the brake pin.) it is bit boring and job wich requires patience. but i think you will manage it
here is the diagram:
http://www.partsguru.com/images/Img844.jpg
Jul 12, 2008 | Gaggia MDF Coffee Grinder
Kicthen Aid Coffee Grinder BCG100
The two small little guides you refer to are a pair of switches that get depressed when the top is pressed down. In the top is supposed to be a plastic pin in the top of each one of the grooves. When both pins push both of the switches down (look like black dots) the grinder wil operate. The proper solution would be to replace the top.
May 24, 2008 | KitchenAid BCG100 Electric Blades Grinder
Cleaning grinding blades
mazzers have 3 springs in grinder body, each one support for upper burr holder. check for them , if it is not the case than consider that the spring could come with coffee. often we see stones and metal parts geting between burrs.
clean it again and look good for 3 springs , if they are in their place, close the burrs to finest than go back for half of circle and grind coffee.
Mar 25, 2008 | Mazzer Grinder-doser MINI MOD. B Electric
Solis Master 5000 Espresso Machine Logo
26 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
AZBen
AZBen
gbob59
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
