Question about Brother HL 1440 Laser Printer
Flashing red light
My printer red light is just flashing. what should i do?
  • 3 more comments
  • Anonymous May 10, 2008
    my alarm and data lights blink every minute
  • REGINALD MISQUITTA May 10, 2008
    my alarm light and data light keeps flashing does not print
  • Anonymous May 13, 2008
    I have the same problem where the alarm shows red light. I have changed the toner to see if that could be a problem but the printer does not seem to work.
  • Anonymous Mar 19, 2009
    red and green light flashing. changed toner cartridge but same problem
  • Anonymous Mar 22, 2009
    How long does a lazer printer print as opposed to the other kind?
    Novelist:
  • 105 Answers
On the alarm and data light blinking, it is saying the toner cartridge is empty. You will need to replace it. Once in a while you can remove the toner cartridge and shake it and have it work for a little while longer. This does not work all the time however.
If you can't get it to work by shaking it, you will need to purchase a new toner cartridge.
When you have the new cartridge, you will need to slide the blue corona wire cleaner back and forth. This is just in front of the toner cartridge in the drum unit on the top of the drum unit. There is a small light blue colored piece of plastic with an arrow in it that you will just push back and forth. This will help the drum unit do its job better.
Posted on May 13, 2008
What is the solution
Posted on May 10, 2008
Red light flashing
Power off your printer, open the cartridge lid; take out the cartridge and put them back again.
Power on your printer and check whether the red light still flashing?
For further assistance, you can also avail our technical support services by visiting our website: http://www.vtechsquad.com.
May 20, 2013 | Epson Stylus C60 InkJet Printer
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
I am having trouble changing the cartridge on the printer. The
im so sorry for the inconvineince that your having on this printer but let me help you.
if :
Red paper.jpg paper and red inkout1.jpg ink light flash alternately and green power.jpg power light is off possible problem: Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. If the lights are still on, that means the printer is having a hardware issue if: Green power.jpg power light is off; red paper.jpg paper and inkout1.jpg ink lights flash (quickly) possible problem: The printer may have an internal error. Turn off the printer, wait a few seconds, and turn it on again. If the lights are still flashing , that means the printer is having a hardware issue
Feb 10, 2010 | Epson Stylus C88 InkJet Photo Printer
The red light is blinking and it doesn't print.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
Oct 02, 2009 | Kyocera FS-920 Laser Printer
Red light flashing on my printer canon i350
Kindly click the link below to download or read the light flashing of a printer. Every light flashing on the printer has different meaning. So please read or download file below to help you solve your problem.
Download Printer Light Flashing
If you need more assistance please reply to this post.
Thanks
Jul 31, 2009 | Epson Stylus C46 InkJet Printer
Kyocera fS-920KX. Not printing
YBC (/\)
Jun 01, 2009 | Kyocera FS-920 Laser Printer
Kyocera Ecosys FS 920
YBC (/\)
Mar 24, 2009 | Kyocera FS-920 Laser Printer
Lights on printer are alternating between red and green flash
try to reset the printer by opeing the front cover and close it again.
Mar 17, 2009 | Samsung ML-2510 Laser Printer
My printer has two flashing lights
try to rest the printer by opening the front cover (not the paper tray) and closing it again.
Epson C48 red and green lights flashing alternately
Only Solution is Re-burn printer firmware.
Mahesh DG, Pune
Sep 08, 2008 | Epson Stylus Photo 1280 InkJet Printer
Brother HL 1440 Laser Printer Logo
508 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
