Hi, i have a belkin adsl2 modem with wireless- g router model f5d7632-4 and it was working fine but now i am getting no connection at all (no adsl light) checked all my wires/filters am stuck! i am on talk talk broadband any help very welcome
  • 21 Answers
Check with your Network provider, and ask them if they can run a line check. No adsl can be problem with either the line or hardware.
But before that do check with your modem as well.
Posted on May 11, 2008
New Belkin router wont connect to internet.
your user name and password have been entered incorrectly, they are case sensitive and must be exact. Make sure your ADSL settings are set at 0/38 (you'll see where)
Nov 12, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin router is unable to connect to 2Wire ADSL modem/router. 2Wire router has DHCP server enabled and Belkin has DHCP server disabled. Belkin is set to obtain an IP automagically. 2Wire IP is...
If the Internet light is off then there is a problem with the phone line to the ADSL modem or the modem is faulty or there is a problem at the telephome exchange.
Disconnect the phone cable at the ADSL modem and connect a phone handset to this cable - check for a dial tone and that you can dial out.
If you don't get a dial tone, use a different or new phone cable.
If the phone line is OK then : -
Ring your ISP to get them to test your connection to your ADSL
modem.
Oct 17, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
I'm having issues with the belkin F5D7234-4 and intermittent connectivity with the network, i'm running a compaq c502tu and the belkin G/G+ router, which the router is hooked up to a general custom built...
Of the Belkin Modem Routers I have used and supported, around 60-70% had connectivity issues.
If the Belkin was cabled there appeared to be less issues than if it was used in a Wireless and cabled capacity.
I suggested to another person only moments ago to quickly sketch a diagram to show, how the network is set up. Add labels to the piccy's which provide the following info:
1. Computer Types (Makes, Models) and OS (Vista, Windows7, Leopard etc...)
2. Connection Types (Wireless / Cabeled).
3. The IP Nos.
4. Modem Types (Make, Model). ie, Belkin F5D7234-4 Router.
5. ADSL or ADSL2.
If it is possible to upload the diagram to FixYa then I suggest you scan the diagram (sketch) or take a photo of it and put it on the computer so it can be uploaded to FixYa.
I only discovered FixYa yesterday and joined, so I am not sure what is possible yet, as I have been focussed on trying to find solutions or provide suggestions on where to find the solution.
I would be proactive and submit your problem directly to Belkin via their website, I have provided the Australian Belkin website link below:
http://en-au-support.belkin.com/
I hope this is helpful to you, please rate it. Regards,
Sep 26, 2009 | Belkin F5D7234-4 Router
Belkin wireless G+ MIMO ADSL2 + modem routerF5D9630
You need to find out what settings need to be changed in the router to communicate to the new modem. Etisalat should have some type of instructions on how to configure it...Does the IP address get obtained automatically or is it manually configured. Does the modem require authentication..like a password. Did they replace the modem or just upgrade the system? You may just ahve to reset the modem and router to get reconnection. Most routers use the IP address of 192.168.0.1 or 192.168.1.1 to get to the router settings control panel. Just enter one of these addresses on internet explorer and a screen should ask for a password. The default password is usually ADMIN but consult the routers manual for instructions. Once you are in the router control manual you can configure the router to work with the new system.
Sep 08, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Re- belkin adsl2 plus wireless router
i think u have an adsl modem + router u have to connect the phone line on the back where it say. yes it can be used with other broadband services in that case you have just config it.
Mar 05, 2009 | Computers & Internet
I am replacing BT 105 modem with a Belkin adsl2 modem with wireless g router. The 105 has a blue cable with a square connector. I tried to put the yellow supplied cable in the back of my computer but it...
no, but you need to configure the router to connect to the internet, you should have a "quick start guide" that will help you connect to your router and set your ADSL dial settings (as it needs this to connect you to your internet service)
once these connection settings are set you should be able to connect to the internet
you can then explore the other settings including the wireless configuration of your router
Oct 03, 2008 | Belkin Computers & Internet
Belkin Wireless Router won't connect to ADSL
Turn off your modem and your router. Turn your modem back on wait for 2 mins then turn on your router. Try to connect. If that does not work. Connect your computer to the ADSL directly and check if you can get on. if not call your ISP.
Jul 27, 2008 | Belkin (F5D5231-4) Router
Need Belkin Disc; same problem with setup
R u connecting through the wired connection or wireless connection ?
Feb 24, 2008 | Belkin (F5D7231-4) Wireless Router
Belkin f5d7633-4 wireless g modem/router
when you upgraded did any settings from your isp change like passwords or usenames that your router may not be registering at your isp's server, or the line speed that you are now getting is not suported by the router.
type 192.168.2.1 in your web browser and check the connection settings.
Oct 20, 2007 | Belkin (F5D7633UK4A) Wireless Router
Computers & Internet Logo
108 people viewed this question
David Payne
David Payne
