Question about Pioneer DEH-P7800MP
It turns on and then turns off when the detach face closes, but while its open i can see the lcd display and when it closes it goes off again.
Turn of when close
Posted on Aug 29, 2010
How to replace cmos battery on satellite p105-s6217 laptop
Turn the laptop over and remove the battery pack.
From the bottom of the laptop, unscrew the plastic shells securing the slots for memory,
Bluetooth, hard drive and modem.
You may have to remove more than one screw for each shell. Keep all screws in a small container, away from the work area.
Remove the memory (RAM) modules, the hard drive and any optical drives (CD-ROM or DVD-ROM).
Press the clips on either end of the memory slot to raise the RAM module and detach by pulling it out. Work slowly and carefully, to prevent damage to RAM modules or the memory slot.
Do the same for all modules, if you have more than one.
Slide out the hard drive and optical drive. If the drives seem to be stuck, look for any screws you may have missed.
Turn the laptop over and insert a pointy tool under the thin strip at the top of the keyboard. Use the tool as a lever to pry the securing strip loose, while working with your finger to release latches along the length of the strip.
Remove the keyboard by undoing two screws securing it.
Raise the keyboard and disconnect its cables.
Close the laptop lid and turn it around, so that you are facing ports on the back.
Remove two screws from the metal plate around the ports.
Open the lid and remove a single screw securing the wireless card cover; the screw is under the keyboard, which you already removed.
Disconnect cables from the motherboard.
Access the board through the space created by removing the keyboard. Unplug the speaker cable from the motherboard by carefully pulling at its head.
Unscrew and remove Wi-Fi antennas, and detach the wireless card from the motherboard. Unplug thin, ribbon-like cables from the video card.
Detach the display assembly from the base of the laptop.
Loosen any attachments, and pull the casing toward you to detach the display assembly, including the LCD panel, from the base.
With the motherboard completely exposed, unscrew and remove the video card.
Undo two screws from either side of the hard drive housing and detach the drive.
Dismount the CPU heat sink and detach the fan cable from the motherboard by removing five screws.
You can now access the battery board with the CMOS battery attached to it.
Undo two screws to detach the battery board from the motherboard.
Disconnect two cables running from the battery board, and carefully raise the board to detach it.
Replace the CMOS battery by prying it open with a pointy tool. Insert a new battery and reassemble the laptop.
hope this helps
Oct 04, 2012 | Toshiba Satellite P105S6217
PV-DC152D CAMCORDER, LCD Display only works if it is pulled out, turned 180 degrees and pushed back into place so the display is facing you. If you move the LCD display over 3/4" away from camcorder...
The most likely problem is a cracked ribbon cable that goes between the camera and the display. The cable needs to be replaced. Typical cost for this is around $40 or so plus labor. I would not suggest that you attempt this repair yourself as opening up these units is not easy without experience. Also, there are cables that can be damaged if opened incorrectly.
Dan
Apr 21, 2011 | Panasonic Cameras
Display not working
I have the same problem. There's a little ribbon cable behind the contacts for the faceplate. It gets folded as the face plate motors in and out and eventually breaks like mine did. I'm fixing it tonight and then I will disable the motorization. Followed by NEVER BUYING A PIONEER AGAIN. I reccomend you do the same.
Aug 05, 2009 | Pioneer DEH-P780MP CD Player
Black lcd display when fully closed with the lcd facing out
In that condition you should have picture on LCD and if you don't have, that means flexible wire between LCD board and camera board is cracked and requires replacement.
Let me know exact model of Sony camcorder to provide you part number info about flexible wire, in case you want to repair it by yourself.
Mar 28, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Display problem
there is a small switech near lcd which turns off and on your laptop lcd.
try making switech smooter problem will be sloved....
Jul 19, 2008 | HP Pavilion dv6000z Notebook
Face not detaching
HAVE YOU TRIED PRESSING THE eject switch located on the right hand bottom side just below the display ? this switch will work for just 2-3 seconds after u switch OFFthe iginition.
OR
With the stereo OFF (iginition turned ON) press the multicontrol to access face opening ON or OFF .select ON . and the face will always open when iginition is turned OFF .
rate me positively if you feel helped .thanks .
Jun 06, 2008 | Pioneer DEH-P6800MP CD Player
No display but fully functional regarding sound
More then likely the flex cable that connects main p.c.b to the connector keyboard plugs into is defective. For service manual email kstahl65@att.net
Jan 30, 2008 | Pioneer DEH-P6800MP CD Player
Pioneer powers off when face plate opens.
My first guess would be that the ribbon cable between the flip face and the mother board has gone bad. This is a very, very common problem. I'd suspect that above everything else at this point.
Jan 03, 2008 | Car Audio & Video
Pioneer DEH-P7800MP Logo
49 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
