Question about Sony Playstation 3 (PS3) Console
Disk reed plese help this subject
I dont know see if the disk is clean it happen to my xbox 360
Posted on May 06, 2008
Lights
Check this and adjust it:
If the console takesbatteries, replace them. If this does not work or your console does not requirebatteries, check the reed switch or optic sensor. Reed Switch:Unplug the treadmill and remove the motor hood cover. The reed switch is mountedon the frame next to the front roller pulley. There is a magnet glued into thefront roller pulley. When adjusting the reed switch, make sure it is pointingdirectly at the magnet. Move the tip of the reed switch within 1/8" of themagnet. Also, check to see that the wire is not damaged, and is connected tothe console.
clip_image001.gifOptic Sensor: Unplug the treadmill and remove the motor hood cover. The optic diskand sensor are located either at the end of the motor or the right hand side ofthe front roller. The optic disk spins between two sensors on the optic switch.The disk must spin freely without touching either sensor. The sensors can bemoved by loosening the adjustment bolt holding the switch to its bracket. Theswitch can then be slid. Center the disk.
11_29_2011_3_44_52_pm.gif11_29_2011_3_45_23_pm.gifGood luck. sincerely
E.CUADRA
Nov 29, 2011 | Epic View 550 Treadmill
Plugged in the mains the light comes on at the base but the console at the top does not come on its a sonic treadmill
clip_image001.gifOptic Sensor: Unplug the treadmill and remove the motor hood cover. The optic diskand sensor are located either at the end of the motor or the right hand side ofthe front roller. The optic disk spins between two sensors on the optic switch.The disk must spin freely without touching either sensor. The sensors can bemoved by loosening the adjustment bolt holding the switch to its bracket. Theswitch can then be slid. Center the disk. 11_18_2011_6_50_12_pm.gif11_18_2011_6_50_51_pm.gif
Nov 18, 2011 | Exercise & Fitness
Power is going into machine but console does not light up and work
If the console takesbatteries, replace them. If this does not work or your console does not requirebatteries, check the reed switch or optic sensor. Reed Switch:Unplug the treadmill and remove the motor hood cover. The reed switch is mountedon the frame next to the front roller pulley. There is a magnet glued into thefront roller pulley. When adjusting the reed switch, make sure it is pointingdirectly at the magnet. Move the tip of the reed switch within 1/8" of themagnet. Also, check to see that the wire is not damaged, and is connected tothe console. clip_image001.gifOptic Sensor: Unplug the treadmill and remove the motor hood cover. The optic diskand sensor are located either at the end of the motor or the right hand side ofthe front roller. The optic disk spins between two sensors on the optic switch.The disk must spin freely without touching either sensor. The sensors can bemoved by loosening the adjustment bolt holding the switch to its bracket. Theswitch can then be slid. Center the disk. 11_18_2011_6_53_40_pm.gif11_18_2011_6_54_25_pm.gif
Light blinking, not working
If the console takes batteries, replace them. If this does not work or your console does not require batteries, check the reed switch or optic sensor. Reed Switch: Unplug the treadmill and remove the motor hood cover. The reed switch is mounted on the frame next to the front roller pulley. There is a magnet glued into the front roller pulley. When adjusting the reed switch, make sure it is pointing directly at the magnet. Move the tip of the reed switch within 1/8" of the magnet. Also, check to see that the wire is not damaged, and is connected to the console.
Optic Sensor: Unplug the treadmill and remove the motor hood cover. The optic disk and sensor are located either at the end of the motor or the right hand side of the front roller. The optic disk spins between two sensors on the optic switch. The disk must spin freely without touching either sensor. The sensors can be moved by loosening the adjustment bolt holding the switch to its bracket. The switch can then be slid. Center the disk. 11_15_2011_12_05_38_am.gif11_15_2011_12_06_02_am.gif
Nov 14, 2011 | Exercise & Fitness
Motor runs but nothing turns on
Optic Sensor: Unplug the treadmill and remove the motor hood cover. The optic disk and sensor are located either at the end of the motor or the right hand side of the front roller. The optic disk spins between two sensors on the optic switch. The disk must spin freely without touching either sensor. The sensors can be moved by loosening the adjustment bolt holding the switch to its bracket. The switch can then be slid. Center the disk. 11_13_2011_11_53_47_am.gif11_13_2011_11_54_16_am.gif
Nov 12, 2011 | Epic 425 Mx Treadmill EPTL88105 !
Belt and incline wont move.
Optic Sensor: Unplug the treadmill and remove the motor hood cover. The optic disk and sensor are located either at the end of the motor or the right hand side of the front roller. The optic disk spins between two sensors on the optic switch. The disk must spin freely without touching either sensor. The sensors can be moved by loosening the adjustment bolt holding the switch to its bracket. The switch can then be slid. Center the disk. 11_16_2011_4_32_00_pm.gif11_16_2011_4_32_24_pm.gif
Oct 29, 2011 | Epic View 550 Treadmill
I have a Life Fitness 9100, and the display is dead, it worked fine the last time it was used two weeks ago. Thanks!
Adjust and clean very softly.
Oct 22, 2011 | Life Fitness 9100 Next Generation...
Proform crosswalk, the walking belt will not go no matter what speed its turned to. It will move if i pull it and register speed on console but will not go by itself.
Optic Sensor: Unplug the treadmill and remove the motor hood cover. The optic disk and sensor are located either at the end of the motor or the right hand side of the front roller. The optic disk spins between two sensors on the optic switch. The disk must spin freely without touching either sensor. The sensors can be moved by loosening the adjustment bolt holding the switch to its bracket. The switch can then be slid. Center the disk. 11_15_2011_8_35_57_am.gif11_15_2011_8_36_26_am.gif
Sep 15, 2011 | Proform Crosswalk 500 Treadmill
Screen is blank
Optic Sensor: Unplug the treadmill and remove the motor hood cover. The optic disk and sensor are located either at the end of the motor or the right hand side of the front roller. The optic disk spins between two sensors on the optic switch. The disk must spin freely without touching either sensor. The sensors can be moved by loosening the adjustment bolt holding the switch to its bracket. The switch can then be slid. Center the disk. 11_14_2011_4_33_45_pm.gif11_14_2011_4_34_07_pm.gif
Nov 14, 2010 | Proform 380 CS Treadmill !
Sony Playstation 3 (PS3) Console Logo
14 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
