Question about Pioneer DVR-S111B DVD RW Dual Layer Burner
Where do i find a replacement power supply cord ive looked everywhere
Is it possible to change the fuse in a sewing machine?
the only fuses ive ever seen inside a sewing machine was located inside the foot switch assembly and ive taken apart a few dozen now , but now ive seen quite a few broken power cords and sockets in that few dozen , seems the power cords sure take a beating on these ?
Jan 14, 2016 | Sewing Machines
Ive tryed 3 power cords and it wont turn on
The fault should be to its main power supply regulator board; not with the power cord. Check and replace this board as card basis. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 17, 2014 | Televison & Video
Hello heres my problem the power cord tip gets so hot and burns even ive replaced the battery ive replaced the cord and the tip and its stil happening help please
Seems that your notebook's power socket, where you plug the power cord, is damaged & is causing a loose connection. The loose connection causes the power socket as well as the power cord's tip to overheat & burn.
Oct 30, 2009 | Compaq Presario M2000 Notebook
Need power supply model ad-13d-2 ultra 30" hdtv
d2d45c4.jpgHi!
If anyone would like a Power adapter for their Ultra LCD30-500 and LCD40-500 - please email me Acosta.cal@gmail.com... And I’ll be able to order one…
I too own a Ultra Lcd40-500 HDTV. Bought it from HSN.com back in 2006.
My power adapter burned out 2 weeks ago, and to my dismay PWW, or should I say POS has gone bankrupt.
I looked everywhere online and here in San Jose,CA thinking I would find a replacement or at least someone that could repair the blown capacitor( 630v vpmm), thermitors(IRFD460A) and varistor( SCK206).
After calling every power supply company, distributor, and retailer, had no luck finding a match to this crazy looking 9din pin adapter. Disappointed I gave up on a replacement and took it to various repair shops for repair and was told without schematic would be nearly impossible to replicate the power Output. Finally this one shop was able to replace the burned out components and it seem to work at the store. When I got home with it..no luck..red light would come on…but no light on screen. L
Not wanting to give up or trash my LCD. It was time to dig further…I did some research through my employer; a SemiConductor company here in Santa Clara, CA.
Needless to say this power adapter has driven me crazy….It has been exhausting... But finally just yesterday I got the break needed…I found a manufacturer in Taiwan that has these power supplies for both the Ultra lcd 30" and 40". I was told they only sell to Component or Electronic Suppliers. I’ve asked my employer to see if I would be able to order one on their behalf using their account.
Happy ending! My power supply is on it’s way. I was told it could take up to 4weeks for delivery. But I’m just glad to have a replacement.
Jun 08, 2009 | Ultra LCD30-500 Television
LOST USB CORD FOR BLUE OPAL MP# M4002
you can buy online from the internet or from an electronic store.
Mar 03, 2008 | RCA OPAL M4001 MP3 Player
Akai CFTD2011
You need to repair the SMPS - - common problem! Open the back and locate the SMPS (Power Supply) On it you'll find a series of electrolytic caps with position numbers. Replace C31 (1000 25v), C32,35 both (1000 Uf 25v) and C33 (680 Uf 25) and you should be good as new...
Bill
Dec 01, 2007 | Akai CFTD2011 20 in. EDTV-Ready LCD...
Playstaion 2 dc power socket broken
i sujest you call playstation and tell them if they can fix it or if you can buy the part hope it helps.
Jun 07, 2007 | Sony PlayStation 2 (PS2) Console
Where do i get a power cord?
first, try the internet...http://www.pricegrabber.com/ and search for your model and then for optional accessories. if no-go, then... remove your car battery, then devise a makeshift 2-wire cable to deliver 12 volts to the proper pins on the back of your monitor. look for polarity markings 12v at 6.5 amps (70 watts) may be hard to find as a "universal" supply. many older pc case supplies (pre-ATX they are free at recycling centers) have the 12V available...just ensure the yellow and black (ground) wires only are used...may also need to ensure that "power ok" signal is set to activate said supply
May 27, 2007 | ViewSonic VP181b 18.1" LCD Monitor
Pioneer DVR-S111B DVD RW Dual Layer Burner Logo
49 people viewed this question
Top Pioneer Computers & Internet Experts
Computer Links
David
David
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
