Question about Microwave Ovens
Stopped working although power is still going to the fridge, the dials read - freezer 2 C and fridge 14 C...
  • flynny1387 Aug 27, 2010
    it's a fridge not a microwave...
  • Microwave Ovens Master
  • 17,130 Answers
Shut off fridgge and power on after some 6 hours. If the temperature in freezer goes to below -5( ideal -18) then the system is working fine. If the freezing stops after several hours then it is possible that the thermostat is not working or the auto defrost timer is not shutting off the system,
However is there is no cooling then the compressor or gas pressure is down.
check this out to confirm
Posted on Aug 27, 2010
The freezer is working but not the fridge fridge onm top freezer below I think it my be the thermostat
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 09, 2011 | Microwave Ovens
Fridge is cold and freezer works but condensation dripping into main part of fridge - everything is getting mouldy - help?!
heatman101
Aug 31, 2011 | Microwave Ovens
My lg fridge freezer has stopped freezing since yesterday, model number gwb207flqa. help all my food is defrosting. even the fridge side isnt cold.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 27, 2011 | Microwave Ovens
I have a ocean fridge freezer & want to know if No.1 is the coldest setting or No. 9 is the coldest on the temperature dial
9 is usually the coldest setting. Turn the dial all the way. The side with the click is off. If it does not click, then turn it all the way and listen for the compressor to turn on or off. What I just told you applies only to the freezer. The numbers on the dial for the fridge should be the same.
Jun 04, 2011 | Microwave Ovens
SMEG FA550X fridge freezer. The ice maker has stopped working, freezer has thick ice built up at bottom, fridge does not appear to be keeping food cold enough as milk etc is going off quickly. Two to...
Your Ice maker may be the cause. if it is not holding water the water may be landing on the bottom and freezing, causing the ice build up and obstructing the air transfer from the freezer to the refrigerator. You can remove or replace your Ice maker. Then you will have to defrost your freezer to get everything back to normal.
May 11, 2011 | Microwave Ovens
Hi. I have an Amana/Maytag Fridge. Model ABD2233DES bottom freezer. The fridge was working fine, then it seemed like the compressor or motor started to make a funny noise. Like it was working hard or...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Dec 24, 2010 | Microwave Ovens
I have a Teka A-FCI340 fridge/freezer. The fridge is too cold and freezes items put into it. No matter how I turn the temperature control dial it still seems to be too cold.
I had the exact same problem with the same model and mine was just 3 years old. My problems started when I defrosted the freezer. I spent 75gbp on an engineer who told me that I had probably 'spooked' the fridge when I defrosted the freezer, that this particular model of fridge wasn't designed to last longer than 2 years.
I would recommend you check the door is shutting properly (check the screws at the top, it might be just slightly out of alignment).... I turned the whole unit off for over 2 days to allow absolutely everything to defrost (both inside and on the back of it)... within 30 minutes of turning it on, the back of my fridge was already frosted over.
Engineer told me not to waste money calling them out again, and to buy another one...
Oct 17, 2010 | Microwave Ovens
I have a 21 cubic refrigerator with ice maker. its only 3 years old. just 3 days ago, the refrigerator section stop getting cold. but the freezer still works. i checked out the back of the frig to the...
Inside the freezer, at the back is another fan that circulates cold air from the freeze through out the fridge. Make sure it's running. Sometimes the blade will slip on the shaft and get jammed, or the motor could be defective.
Jun 20, 2010 | Whirlpool Microwave Ovens
Microwave Ovens Logo
50 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
