Question about Robinair Cool Tech 34700Z Recovery, Recycling, Recharging
How do you calibrate the scale on a robinair 34700z A/C Machine?
    President:
  • 180 Answers
Robinair Model-34700Z,for scal calibration follow as bellow:
Form the main menu go to ''CHANGE DEFAULT'' then press 5454 & YES key (passwoed to access default option).Once you enter to default menu,go to "SCALE CALIBRATION" & press YES key. now follow the on screen text.
NOTE:you should have 9KG/20LBS of weight for scale calibration. Do not change ''TANK TARE''. it must be on factory setup 16.30 lbs OR 7.40 kg.
Hope this will help you to solve thr problem & if my solution is useful to you please vote for it
Posted on Aug 27, 2010
34288 scale calibration procedure
the machine came with a calibration check weight in the menue you can check the calibration. if it fails contact your local service center the machines have to be calibrated with certified weights unlike the older machines.
Jul 07, 2012 | Robinair Cool Tech 34700Z Recovery,...
How do I recalibrate scale on Robinair 34134Z
Robinair Model-34700Z scal calibration follow as bellow:
Press main menu then press up or down arrow till scree appear ''CHANGE DEFAULT'' then press 5454 from the keypad & then YES key (passwoed to access default option).Once you enter to default menu,go to "SCALE CALIBRATION" & then press YES key. now follow the on screen text. Once you calibrate scale then press STOP key to exit.
NOTE: You should have 9KG/20LBS of weight for scale calibration. Do not change ''TANK TARE'' or any other setting it must be on factory setup.
Hope this will help you to solve the problem & if my solution is useful to you please vote for it
Apr 04, 2011 | Robinair Cool Tech 34700Z Recovery,...
WE HAVE A MODEL 34700Z & IT IS GIVING MESSAGE WE YOU TURN IT ON ( SCALE ERROR UNIT DISABLED).REMOVED THE TANK & MANUALLY REMOVED TANK PRESSURE & DIDN'T MAKE A DIFFERENCE.
Your have to calibeate the scal.For Robinair Model-34700z scal calibration follow as bellow:
Feb 28, 2011 | Robinair Cool Tech 34700Z Recovery,...
Over charges. machine seems to operate normal, but it over charges every time. I tried to recalibrate the scale. this didn't help.
It seems to be your last calibration was not correct!
Aug 15, 2010 | Robinair Cool Tech 34700Z Recovery,...
Over charging won't recover scale don't work
It is not clear which model of robinair machine you have! However your machine need to re-calibrate the scale.
Aug 05, 2010 | Robinair Cool Tech 34700Z Recovery,...
How do you calibrate the scales on A robinar 34800
Form the main menu go to ''CHANGE DEFAULT'' then press 5454 (old typ machine 8787 without F1 botton on key pad) & YES key (passwoed to access default option).Once you enter to default menu,go to "SCALE CALIBRATION" & press YES key.now follow the on screen help text.NOTE:you should have 9KG/20LBS of weight for scale calibration.
Hope this will solve you.
May 19, 2010 | Robinair Cool Tech 34700Z Recovery,...
Wont vacuum
With machine power OFF,remove old pressure transducer & replace new one.now power ON the machine & go for calibration.Calibration step for Robinair 34700Z machine.Form the main menu go to ''CHANGE DEFAULT'' then press 5454 & YES key (passwoed to access default option).Once you enter to default menu,go to "SCALE CALIBRATION" & press YES key.now follow the on screen help text.NOTE:you should have 9KG/20LBS of weight for scale calibration.
May 21, 2010 | Robinair Cool Tech 34700Z Recovery,...
RECALIBRATE SCALE ON ROBIN AIR MACHINE
Form the main menu go to ''CHANGE DEFAULT'' then press 5454 & enter (passwoed to access default option).Once you enter to default menu,go to "SCALE CALIBRATION" & press ENTER botton.now follow the on screen help text.Hope this will solve your problem.
Mar 24, 2010 | Robinair Cool Tech 34700Z Recovery,...
PROBLEM WITH WEIGHT CALIBRATION
Calibration procedure for Robinair AC machine.
NOTE:FOR SCAL CALIBRATION YOU SHOULD HAVE 9KG/20LB OF WEIGHT.From main menu go to change default (press 8787 for old type machine or 5454 new type machine)
then press enter/start key.after enter to default nenu you have to select calibrate scal option.press again enter/start key then follow the on scree message.once you done so,press stop/exit key to complete the prcess.
Aug 18, 2009 | Robinair Cool Tech 34700Z Recovery,...
Machine will not clear existing pressure
Please check your unit compressor also & make sure compressoe haveing minimum 13''Hg suction.
Jul 03, 2009 | Robinair Cool Tech 34700Z Recovery,...
Robinair  Cool Tech 34700Z Recovery, Recycling, Recharging Logo
2,195 people viewed this question
Top Robinair Measuring Tools & Sensors Experts
Mike
Jay Finke
Jay Finke
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
