Question about Sony DCR-HC38 Mini DV Digital Camcorder
My tape wont close,the tape won't go down for the door to close
    Genius:
  • 1,812 Answers
This is usually caused by a defective component in the tape detection circuitry and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Sep 03, 2010
Tape door will not go down
CAMCORDER TAPE DOOR WON'T CLOSE { C:32:11 } FIX ...
? 13:13
https://www.youtube.com/watch?v=CBqP-Q86UyM
Jul 9, 2014 - Uploaded by GotNoEvidence
Here is a fix that does not involve disassembling your camcorder, sending to the ... This worked for us when the tape door wouldn't close on our old Sony HDR-HC9. .... is you can use the same method to REMOVE a tape when the tray will not lift! ... Yes yourvideo helped me fix my DCR-HC96 camera.
Sony HDR-HC3 Tape Door Won't Close with C:32
Nov 18, 2015 | Sony Video Cameras
How do i get to the door ajar alarm in my 2002 kia sportage? Want to yank the alarm out.. Is it under the radio? Want to get an idea before i take the dash off again
there could be a bad or not totally depressed door switch/es when all doors are closed, assuming the alarm system module (not sure of the name, some manufacturers call it body control module-'BCM') is good. you may try the following:
1. if there is, tighten each lock nut (or mounting nut) of the door switches, to bring out each door switch so that they will be fully depressed when the doors are closed.
2. to find out which switch/es is not being fully depressed when door is closed: while (& all doors closed) door ajar alarm is on, open one door & manually depress the door switch (try to depress several times - might be sticking). if alarm turns off you found the switch, otherwise continue to the next door. but before proceeding to the next door, tape down that first door switch (you may have more than one?) once you found the switch that is not being fully depressed when door is closed, tape down that switch (to keep the alarm turned off). go back to each taped down switch. remove tape & close door, if the alarm turned off when the door was closed (switch is fully depressed=good), then go to next.
3. you can skip 2, just install spacer to doors. spacer can be a thin piece of plastic (or something weatherproof cardboard) to make the door switches to fully be depressed when doors are closed., not too thick that may prevent door from properly latching). tape them first, then use good adhesive if they work.
other possible causes are bad door switch, broken or detached wire, or bad BCM)
(note: the door switch is a push button which looks like a small protruding nail? & mounted at the door opening, which will be depressed by the door upon closing).
Oct 03, 2015 | Kia Cars & Trucks
Tape door won't open or close to release tape
Sony Handycam CCD-TRV58 Hi-8 Analog Camcorder
1. Per the manual on esupport.sony.com
- if the power is disconnected door won't open, and if the battery is the dead the door won't open.
Plug it in and hopefully you can get the tape out.
Did this work?
Feb 11, 2013 | Sony Handycam CCD-TRV58 Camcorder
My VCR/DVD combo wont play a VHS tape when inserted. Each time I insert a VHS tape, it shoots it right back out and sometimes unravels the tape around the apparatuses inside the VCR. It won't reco
the tape coming back out and unravels the tape means the loading mechanism is the problem----when a tape goes in it loads the tape down, then it pulls the tape out of the cassette and puts it up against the drum with the video heads-----many of these are belt driven and a bad belt or belts will cause this----it is called the loading and or transport mechanism.......when it fails the arms come back but the tape does not get rewound back into the cassette so it mangles it when the cassette door on the tape closes----most likely a belt or the drive idler which also rewinds and fast forwards the tape.
Oct 16, 2012 | Philips Magnavox DVD/VCR Dual Player
Tape door won't close i get error message reattach power. i've reset , used different power supply, still tape door won't close any goo ideas? chuck
big problem with sony as you can see im a pro tech but had the same fault with mine. and it broke my heart 4 weeks old and sony dont give a dam ironicly a mate told me slam my fist under the bottom and it will close after hrs of trying to fix it i took his stupid advice and after many hits it closed and worked great for a few weeks
Sep 12, 2011 | Sony Handycam DCR-HC96 Mini DV Digital...
The tape carrage wont load the tapes but it will go into the load position without.
I have a sony cam myself. If the cam is empty, you open the outer door(swings out), and the load/unload mechanism rises up and pops open allowing tape insertion. When a cassette is placed into the mechanism, you press where it says "push" and then the drive pulls the tape down and into the unit. Then the outer door is closed and you're ready to tape. IF YOU PUSH DOWN ON THE TAPE WHILE IT'S BEING PULLED INTO THE UNIT IT WILL STRIP GEARS INSIDE. The gears are made of nylon to prevent serious damage to motors and other circuitry. This transport setup cannot be forced at all. If any type of mis-alignment occurs, the mechanism is supposed to stop and back up--allowing the problem to be corrected. If it is damaged, the cam must be repaired. There is critical timing involved in replacing the tape carriage.---Rick
Sep 10, 2009 | Sony Handycam DCR-TRV33 Mini DV Digital...
I cant close the tape compartment
Its a mechanism problem , you need to take it to service centre , will cost about $100 in India
cannot help sorry
Apr 20, 2009 | Sony Handycam DCR-PC101E Mini DV Digital...
Tape door wont close
hi there, i have exactly the same problem but on a mv750i !!! If i put a tape and close the mechanism motors stars working but it doesn't go in... if i close it without a tape the motors doesn't work... is any possible way to manually push it in ???
Apr 13, 2008 | Canon MV730i Mini DV Digital Camcorder
I'm having a similar problem. The camera is a Sony DCR-TRV280. When you put a tape in the tray will not go down. However when the tray is empty and you push it shut it will go down. In other words the mechanism works fine without the tape but with the tape it doesn't. I hope the explanation is clear enough. Thanks
Mar 21, 2007 | Sony Handycam DCR-TRV525 Digital Camcorder
Sony DCR-HC38 Mini DV Digital Camcorder Logo
214 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
