I have a vintage german console stereo. The turntable that is in it is a Dual 1008 record changer. These were only made for console units. The Stereo is a tube type from the early 60's and functions well. I am having the turntable refurbished but the connection that is the sound output is one with three pins and is a ceramic type connector. Does anyone know the best way to connect this?? Can I get a connector cord with a ceramic connection anywhere or is there a viable replacement that will work well with the stereo??? Any help or sources for parts would be appreciated. Thanks
  • brentchoat52 Aug 27, 2010
    I am the one with the issue of the Dual turntable. I actually have 2 of the ceramic type cartridges and two new needles. Before the turntable needed to be refurbished the sound quality was great from the cartridge. It is not the issue. I have a cable to connect the turntable to the tube stereo, the only thing is I wanted to replace it if they make any sort of cable that replaces the ceramic end but retains the 3 pin design. I have tried connecting with rca's before but the 3 pin has 2 ground connections and sound connection. I don't want to break open my vintage stereo as it has sentimental value in it's current configuration as well. My father brought this back from Germany when he served in the US Army The current cable I have has been cut short and I don't know if you can lengthen them or find a replacement type.
    Thanks alot.
    President:
  • 1,851 Answers
The problem in cases like these is not the connector (you can connect direct the cables), it's the type of the pick-up cartridge. Those days the cartridges were crystal/ceramic type. This means that I think you will not be able to find a replacement for this cartridge. Since the whole console (including the turntable) is in good condition I suggest you to replace this cartridge with a moving magnet (the last type that used the turntables, just before the moving coil ones) but you will also need a phone preamplifier in order to feed the signal to any line in input of the system. If you like rebuilding the oldies it's a good idea.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, accept my solution. Please consider leaving a 4-thumbs rating; I'd appreciate it greatly.
Thanks and regards
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Posted on Aug 27, 2010
  • 10,319 Answers
Ebay has sellers with this style
Posted on Aug 28, 2010
Can you replace the turntable in a vintage Zenith Console sterio with a newer turntable?
Generally speaking all you need to do is find the left and right channels leads from the old deck to the amp, cut them off or if thy plug in somewhere unplug them, then you can connected the playback leads of the new deck to the amp and it will then play back.
Jun 22, 2014 | Audio Players & Recorders
My Dual CS 1264 Does not work. The arm swings out over the record, drops slightly and then returns to its resting position on its base
It seems that the special grease is old. There is a wheel moving the toneam. Remove any old grease from it and try again. If you need further instructions or a way to get new grease please refer to www. dual-board.de This is the worlds largest knowledge base for vintage Dual turntables. It is in german, but feel free to post in english, most people here in germany speak english, too.
Mar 24, 2012 | Dual Audio Players & Recorders
I have a vintage magnavx console stereo and the turntable speed is off....how can I fix this?
Depends on the drive method of the old turntable. Sometimes grease/dirt can build up. If it's an idler drive then the rubber wheel that rubs on the rim of the turntable can become worn.
Aug 28, 2011 | Audio Players & Recorders
I have a Vintage 1965 Magnavox Console Stereo. It is in excellent condition, (everything works on it). No dings and even still has a new needle, all original paperwork with it. I would think there must be...
Hi mesha
To answer your question;
Of course the value is in the eye of the beholder but i`d say go to Ebay and search for your model number or look into vintage stereo systems for something that would be equivalent.
It should give you a pretty good idea of it`s estimated value.
Hope this help Good luck
Mar 15, 2010 | Audio Players & Recorders
Vintage turntable turns slow for few minutes then speeds up,,,why
The tubes are only in the audio amp portion of the stereo, and have nothing to do with the motor that turns the turntable.
Most likely it's that the grease on the motor is old and gummy, but becomes less viscous when it warms up.
Jan 24, 2010 | Numark TTX Turntable
Vintage Zenith Turntable starts record in middle.
Check the speed it is set at as the speed setting tells the turntable what diameter of record it will be playing.
Aug 30, 2009 | Audio Players & Recorders
Record player ''ejects'' frequently!
A very common problem with vintage turntables is that the old grease on parts of the mechanism underneath gets thick and gummy like varnish and then the parts do not move freely. One must carefully free up gummy parts with WD 40 and relubricate them with 3-In-1 oil. Look for gummy slider or trip mechanism parts that are actuated by tone arm movement.
Nov 25, 2008 | Audio Players & Recorders
Magnavox Console Stereo turntable does not turn at correct speed
I'm in Nashville, where can I have my 70"s Magnavox stereo console serviced to get bugs out of it as well as get new cartridges?
Nov 24, 2008 | Teac AG-V1050 Receiver
201 people viewed this question
 Grubhead
Grubhead
