Question about Apple iPhone Smartphone
I have restored my i phone 4 and its now not switching on
    Sergeant:
  • 226 Answers
Hi mate
just hold the home button for 10 seconds, and then while still holding it down, hold the power button simultaneously, for 10 seconds, and should come to apple screen
nick
Posted on Aug 27, 2010
My iphone 4 shows the picture of itunes and usb cable and i cannot open my phone. I am using gevey sim.
switch off iphone and hold power buttuon for 5 seconds after 5 seconds while pressing power button hold and press home button along power button .. then connect to itunes ask to restore .. if u r having ipsw hold shift and press restore button on itunes if not without holding shift press restore button .. then it will be restored to the newest version of iphone
Sep 10, 2013 | Apple Iphone 4 16gb Black at&t Smartphone...
MY HTC DREAM switched off itself
Corrupted software
It isn't often that Apple gives specific directions about how to fix your problem! Restoring the iPhone 4 will erase everything on it, so make sure everything on the iPhone 4 is stored elsewhere prior to restoring. To restore, connect your iPhone 4 to a computer with iTunes installed. Click "Restore" on the iPhone 4 summary page (click on your iPhone icon on the left menu to find this page). Follow the directions to restore. If your iPhone 4 displays the text "Please wait. Very Low Battery," leave it plugged in. This charges the iPhone 4 enough to be able to restore. If the iPhone 4 hangs on this screen for long periods of time, you may need a new battery.
Force restore mode
If your iPhone 4 is hanging with an Apple logo, or exhibiting some other software problem that prevents iTunes from recognizing it, you can force it into recovery/restore mode and then use iTunes to restore the software.
If the device is powered off, plug one end of your USB cable into the iPhone 4 and leave the other end disconnected. Press down on the Home button, and keep holding it down while you plug the USB cable into your computer. After 5-10 seconds, you should see a "Please Connect to iTunes" image on the iPhone 4, and iTunes should prompt you to restore the software; follow the prompts and the instructions given above.
If the device is powered on, hold down both the power and home buttons until the device reboots and displays the "Connect to iTunes" image (generally, 5-15 seconds).
God bless you
May 24, 2013 | HTC Google G1/Dream Cell Phone Black...
Iphone is switched off
Press home volume down and power when phone comes on take finger off power then volume then home. plug into itunes and restore software after it has installed click on. re put on the last saved from list and this will restore phone to your last saved info.
Apr 05, 2013 | Apple For iPhone 4/8GB LCD Screen...
Automatic switch off while selecting ring tone settings,
SOLUTION FOR YOU
1. Click on Menu 2. Go to Settings> Restore Factory Setting 3. Enter the code (Default code is 12345) if changed enter the changed code. 4. Press OK to restore all the settings. 5. The phone will restart, and now the problem will be solved.
Hope this Helps.
May 19, 2011 | Nokia 1650 Cell Phone
My iphone 3GS was not switching on. what should i do
1. Open itunes 2. Connect the phone to the computer. If you have the white apple logo, you need to turn off before connecting. 3. Press and hold the power button for a min or until itunes recognizes the device. Do a restore. 4. After successful restore, the phone should turn on.
Mar 04, 2011 | Apple iPhone 3G
I do not have restore code please tell a solution?
Hello thanks for using FixYa
To format your cell
To format dial code *#7780# or *#7370# which restores the factory settings. it will ask you to confirm that press OK. it will take some time and your handset will be format & restored to original settings.
But if you format the whole phone memory then follow the procedure below
First of all Switch off your phone then press and hold 3 keys combined
  • Green dial key
  • Star key no *
  • No 3 key on keypad
then press the power on to switch on the phone.
  • In the process don't leave the 3 press and hold keys, After some time the phone will format completely
Note: Remember one things this will deletes all your messages, all contacts, photos, notes etc in the phone memory.Your phone is like a new phone. So better is first save all your data and then restore it.
Default security code for nokia is 12345
See my TIP & TRICK to format Nokia Handsets which will help you out briefly
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using fixya
Feb 07, 2011 | Nokia 5200 Cellular Phone
Lost my nokia 5233 security code , how can i restore my phone
*#7328748263373738# to reset security code to default.
Default security code is 12345
i hope this helpful
thank you for using fixya
Why my phone is slow?
If your phone memory is low then your phone will slow.
or there may be a virus.
Try to format your phone try one of the following
*#7780# (*#rst0*) - This will soft reset your phone. It is different from *#7370# because all data, like contacts, calendar and notes, are not removed.
It will only reset the phone settings, such as profiles, themes and shortcuts.
The default lock code is 12345.
or try this(But it will fully format your phone)
Method 1:
Three Finger Reset for Nokia Phone
1. Switch off your Phone.
2. Hold down the following three keys, Green (call answer button) * (Star) Key, and Number '3' key.
3. While holding The Three buttons, press the power button for switch on the phone.
4. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Method 2:
Hard Format of Nokia Mobile Phone
2. Now Press following key-*#7370#
3. Enter Default lock code is 12345.
4. While holding All of the buttons, press the power button for switch on the phone.
5. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Method 3:
Soft Reset of Nokia Mobile Phone
1. Switch off your Nokia phone
2. Now Press following key sequence *#7780#
Please Note:
The formatting method will erase all of your Phone data.
Please take a backup before you Format.
Dec 20, 2010 | Nokia E71 Smartphone
Deleting yahoo go from collecting software. Mobile immeatily switched off.3110c. Next time switched on only blinking immeadely getting switch off
try taking out the battery in mobile, then put it back in this might help.
(or)
Solution:-
1. Switch Off Phone (Remove Memory Car And SIM).
2. Star Phone Without Memory Card (But Now You Can Insert SIM)
3. Restore Your Phone (Factory Settings) Change Theme (Less Than 100KB In Size) Leave it Switch On For 10 Min.
4. Switch Off Phone And Leave it For 10 Min. (Remove SIM Card Also).
5. Insert Memory Card + SIM Card And Switch On Phone. 6. Enjoy.. :)
NOTE : -
1. Make Sure To Leave Free Space For Phone Memory Between 500KB +
2. This Will Effected For Next 4 - 5 Months … 3. If Phone Restarts, Then You Know What You Have To Do Now?
Sep 05, 2010 | Nokia 3110 Cellular Phone
I cant format my nokia3500.....it is askin me 4 a security code wen i try to restore...i tried 12345,0000,00000.....pls help
Try to format it
Option 1: --->>*#7370#
Option 2: --->>
STEP: 1. Switch off your Nokia Mobile,
STEP: 2. Press-> Call button, press-> 3, press-> *,
STEP: 3. Now Switch on your Mobile.
Option 3:
*#7780# -Restore factory settings
Option 4:
*#2640# -Displays security code in use
Jan 11, 2010 | Nokia 6300 Cellular Phone
Apple iPhone Smartphone Logo
12 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
