Question about Philips LCA3113 Projector Lamp for LC5131, LC5141, LCA311
The projector turns on for about a minute and then the bulb goes out while the projector is still on.
  • Philips Master
  • 17,130 Answers
The projection lamp must be confimed to prove that it is working alright. If this proves OK then check on the power supply unit for shut down due to load.
Please check on the filters to ensure that the air flow is good.
If lamp is tested Ok then the power supply can be defective and if there is no visible faulty components, the power supply unit must be changed.
Posted on Aug 27, 2010
Optoma hd72
It sounds like you bulb is ready to die. First clue is picture quality. That happen to me and a new bulb remedy the problem. Bulbs are expensive though.
Jan 28, 2014 | Optoma HD72 Multimedia Projector
It quits projecting, the green light goes off and the red light of the bulb goes on. I've disconnected everything and reconnected, turn it on and it works for about two minutes and shuts off projector,...
Have you tried cleaning the fliters on the back of the unit? It's easy to do. Pull them out, and blow them clean. Also, is the projector well ventilated - mine overheats sometimes and shuts off. Otherwise, sounds like he bulb to me.
Oct 25, 2010 | InFocus Office Equipment & Supplies
Works good for 2 minutes, Then shuts down & light goes red. Remote wont restart , so turn power off then on, Works again for 1 minute then shuts down. Panasonic PT-AE900U... projector
change the Bulb if that does not work it could be a power supply or power supply regulator this should be done by a professional except the Bulb
how many hours of operation does the unit have ??
Sep 21, 2009 | Office Equipment & Supplies
How do I access service menu to reset lamp timer for Optoma H56?
In order to reset the bulb counter you need to access the Service Menu:
To access the Service Menu:
Turn on and warm up
press the following sequence:
Up
Up
Left
Give it a few goes, it took me 5 minutes to enter with the right timing. The Service Menu will appear, highlight factory reset and the counter goes to 0. Job done. Cheers, Matt.
Apr 15, 2009 | Optoma H56 Multimedia Projector
My TLP680U projector shuts off after 1o minutes of operation.
toshiba is not one of the most rliable makes im afraidi have seen this fault before and it turned out to be the bulb which i had recentley replaced and this was apparentley the wrong one and gave the same sort of results.
Feb 25, 2009 | Toshiba TLP 680 Multimedia Projector
LCD PROJECTOR GOES BLANK
Check the cooling fan/ air ducts - sounds like it's overheating and shutting off to prevent damage.
Mar 12, 2008 | Computers & Internet
InFocus LP725 light goes out after 10 minutes
The Projector will turn off after so many hours of running the same bulb module. The counter will turn on a replace bulb LED. Installing the new bulb module should reset the counter and turn off the LED.
Check the projector’s lamp to ensure that it is securely connected
in the lamp module. Make sure by removing it and reinserting it.
Check the cables for problems.
When testing, power up in this order. Projector, Computer monitor, Computer.
A minor power surge may cause the lamp to shut off. Turn the
projector off, wait at least 30 seconds, then turn it back on.
I hope these suggestions help
Feb 02, 2008 | InFocus LP725 and LP735 Replacement...
2300 mp stays on for only 3 minutes then turns off
ok..try to long press the power button to refresh the settings..
Jan 28, 2008 | Dell 2300MP Multimedia Projector
InFocus LP630
get it from projectordoctor.com or from infocus. do not get cheap replacements. you get what you pay for.
Sep 18, 2007 | 3M Projector lamp Projector Lamp
397 people viewed this question
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
