Question about RTO Esab Handy Plasma 550 W/25' Pt 31XL Torch 0558002612
Powers on airs on air starts wen triggers pressed no arc.
    Scholar:
  • 97 Answers
Inside the unit their is a part witch looks like a spark gap and that is what it is if this part gets dirty of has like a magnetic fuzz in it it will need to be cleaned as well the gap should be reset you will need to contact the manufacture for the specks do to different units have different settings wile you have the side off look for lose connections as well as arking marks for passable shorts their is a variety of things that can go wrong with thease units but what i said is most common do not use high pressure ari to blow clean a metal chip can damage transformer windings and then short out be careful of capacitors they can hold a nasty charge and aslo can be lethal if your not sure i highly suggest you take to a service center for the unit you have hope this helps.
Posted on Aug 30, 2010
How to fix air pump
The crossman phantom is a spring powered air rifle which means that you pull the barrel down through the arc of its travel until the piston locks up to the trigger mechanism in one continuous movement
Feb 08, 2016 | Crosman ® Phantom .177 Pellet Rifle with...
My paslode IM350 nail gun wont spark but wen i remove the fan cover and unplug the fan it sparks nothing is loose and everything is connected but cant see what the problem is can anyone help thanks
With gun assembled but gas cell REMOVED look at LED on handle, with battery fitted LED will flash. Now press it against work piece, LED will stay lit whilst still watching LED press trigger. LED should blink off (it may blink red) this indicates that the spark unit has sent the spark. If this works it sounds like either the spark lead has been damaged and spark could be shorting across back of cylinder head or you actually have a gas problem. Check cylinder head O ring, use by date on bottom of gas cell. Depending on age of gun it may have another O ring on the sleeve (pre 2006). Check sleeve is clean do not add oil to working parts (except a smear when cleaning sleeve and around O rings when reassembling gun)
Mar 21, 2014 | Air Tools & Compressors
I HAVE A FEDDERS AIR CONDITIONER MODEL AED24E7F-C THIS UNIT TRIPS THE RESET BUTTON ONCE IN A GREAT WHILE IT RUNS FOR HOURS OR DAYS ON END AND THEN TRIPS. IT TAKE AWHILE AFTER THAT BEFORE I CAN RESET...
The reset button is part of the cord. The cord has built in arc detection. This is a complex circuit that monitors the unit and senses potentially dangerous sparks or arcing inside the internal components of the A/C (motors, switches, etc.) It sounds like the problem is getting worse - as they usually do. Sparking and arcing happen when dirt, corrosion, etc. accumulates and can result in pitted contacts. All of these conditions only make the sparks and arcs worse. Page 1 of the manual (left column) says this:
If the Arc Detection Device has tripped, the
reset button will pop up.
Follow these steps to reset the Arc Detection
Device:
1. Unplug unit from electrical outlet
2. Press the reset button
3. Plug the unit back into electrical outlet
4. Check to see if power has returned to the unit
Testing
You should test the Arc Detection Device
equipped power cord monthly, after every major
electrical storm, or if power to your Room Air
Conditioner has been interrupted.
Follow these steps to test the Arc Detection
Device:
4. Press test button. Unit should trip and reset
button will pop up.
5. Press reset button again for use
If above test fails, stop using the air
conditioner and contact customer service by
calling the following toll-free number:
1-800-332-6658 or email:
customerservice@fedders.com
I hope this helps & good luck!
Aug 30, 2011 | Heating & Cooling
Thermal Dynamics Drag Gun Pac 10, Push Trigger, Labored Sound, Cuts Off and wont cut or flash arc. Cleaned Air Filter allways, All New Consummables, Allways kept clean, Has a rattle when trigger pressed...
Hi:
Your plasma has a start arc pilot inside the machine, this one must be faulty, check your owner's manual and request the part to your nearest welding store. It is easy to replace.
Jun 21, 2011 | Welding Tools
Impact wrench is not working at all.the air is coming out of the hole at the bottom of wrench next to where the air hose is hooked up.
fill down the air pipe wit penatrating oil hold trigger and keep movin forward and reverse wen in frees up fill wit airtool oil
Aug 10, 2010 | Craftsman 1/2" Impact Wrench
Working on and off
if you have to tap the tourch to get it to work then something in the tourch is loose or worn,have you tried to replace all the consumables in torch,check that all leads are tight.as far as parts go to your local welding store(praxair,midwest air gas, s j smith)not a hardware store,
Apr 02, 2010 | Welding Tools
Spectrum 2050 plasma cutter will not arc
Possible failure of the trigger switch and or the cable back to the unit. Use an ophmmeter to check that the trigger and cable are good,
Then with the ohmmeter check the continuityu of the cable to the electrodes,
Connectors are always suspect.
These are starting ponts to check.
Mar 04, 2010 | Miller 903777012 SPECTRUM 2050 PLASMA...
No arc. Power and Air OK
if the main power cable is cut that is your problem,unit uses high frequency.the two leads go to the gun trigger back to unit,no fuse or fuseable links in the gun.
May 13, 2009 | Welding Tools
No power to the cutting torch when the trigger is pressed
check to make sure all torch parts are in good shape and is put in correctly
Mar 11, 2009 | Welding Tools
Thermal dynamics cutmaster 50 2004 yr.
Check contacts in tip and be sure it is all lubed correctly. If you have good air pressure and flow it should arc after pulling the trigger for about 2-3 seconds.
Sep 27, 2008 | Welding Tools
RTO Esab Handy Plasma 550 W/25' Pt 31XL Torch 0558002612 Logo
213 people viewed this question
Top RTO Welding Tools Experts
Bill Boyd
Are you a RTO Welding Tool Expert? Answer questions, earn points and help others
